Old 07-03-09, 10:53 AM   #1 (permalink)
24 volts sensor
I put a water temp sensor of a FJ40 81 and the pressure sensor of a fj40 1975. I keep my factoyry 24 volts cluster... Did I do somethings wrong ? I try to find at toyodiy.com the part number to know if all if ok.. but I didn't find answer
Owner of a bj40 1979 with rebuild B 3.0L engine
FJ40 1975 4.2 double Baril
Wedg3 is offline   Reply With Quote
Old 07-03-09, 09:07 PM   #2 (permalink)
Tobugrynbak's Avatar
I've checked my Factory service manual regards the differences between 12/24volt instrumentation.
It seems they use the same senders and instruments. There is a dropping resistor on the back of the cluster which drops the voltage from 24 to 12 volts and is then fed to the instruments voltage regulator.
What problems are you having?
A man generally has two reasons for doing a thing
one that sounds good
and a real one..
UNDERSTEER is when you hit the wall forwards.
OVERSTEER is when you hit the wall backwards.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far the wall moves after you hit it.
Tobugrynbak is offline   Reply With Quote
Old 07-04-09, 07:44 AM   #3 (permalink)
The problem that I have is my pressure sender unit that work but the pressure isn't good. The max pressure with a mec gage tell me 80 psi, the normal 60 and the max low pressure 35psi. So every LC guy know that the idle pressure is as low as 5psi... In a long run my pressure is 30psi. so I don't even see the needle on the gage.
For the water unit all is ok, but just want to know if the temp is good or not
Old 07-04-09, 08:22 AM   #4 (permalink)
Stand and deliver
roscoFJ73's Avatar
How many miles has the engine done?
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 07-04-09, 12:04 PM   #5 (permalink)
The engine is fresh rebuild. The pressure sensor is new and the water sensor to.
Old 07-04-09, 01:58 PM   #6 (permalink)
Have you tried swapping in your old oil pressure sender?
When you put the thread tape on the sender, did you block the tiny hole?
Is your truck still 24 volts? If you've converted to 12 volts you will need to remove and bypass the dropping resistors on the back of the cluster.
You may also have a gauge issue, it happens on older vehicles. You may fix the big problem, but its all the extra little ones that get you.
and a real one..
