LinkBack (4) Thread Tools Display Modes
Old 07-03-09, 08:33 AM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Garage
12H-T 3" exhaust installation in HJ61
Hello,
I've had a 3" exhaust installed on my HJ61 to help the 12H-T breathe a bit better. The results: impressive.
I can pull up long hills a whole lot better and hang onto the higher gears longer. In short, it gives more torque and makes for a more enjoyable drive.
The standard dump pipe on the 12H-T is a good flow design and does not need replacing if the new exhaust is following the same route as standard.
The new exhaust exits through a hole cut in the guard, and down to the rear on the outside of the chassis rail but inside the line of the body. It then ducks back inside the chassis rail at the rear wheel and follows the regular route with a resonator at the outlet.
I did this to give me more room for extra tanks inside the chassis rails.
Although the existing dump pipe is okay, leaving it in place would have led to too tight fit against the chassis, so the new exhaust was built onto a flange on the turbo.
I'd recommend this mod to anyone wanting more torque. It is also an important step in unleashing the power of these engines with extra boost and fuel - neither have much point with standard exhaust.
Tim
1989 HJ-61 12H-T, 5 speed, Jap NATO spec, 24v and Redarc Charge Equaliser, Goodyear 694LT 265/75 16 on 16x8 steel rims. Start up on diesel, cruises on 100% WVO since 2005. 15psi boost, 3" exhaust and no intercooler.
Tim-HJ61 is offline   Reply With Quote
Old 07-03-09, 01:13 PM   #2 (permalink)
Tapage's Avatar
Garage
any chance to get a video .. ? and pictures of your rig ..
HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul !
Tapage is online now   Reply With Quote
Old 07-04-09, 01:36 AM   #3 (permalink)
Garage
Hi Tapage,
This link will take you to my latest journey through Western Australia.
Click on this link to see a Movie of start up smoke and exhaust note
There is also a posting I made at my local off road forum on increasing power in a 12H-T
and my gauges mounted in the overhead unit. Gauges are vege oil temp, vege oil pressure, Turbo boost, EGT.
and I put some H1 HID inserts into the high beam, centre, lights. Outer light is still high/low beam. Inner light is HID only and switched separately as if they were spotlights. i.e. only coming on when high beam is on, AND their own switch is on. I power each of the 12v HID ballast separately from each battery via a 24v relay switched as I have described.
I'm looking for some locking diffs, and I could be talked into an intercooler if it would fit behind the grill and not be too difficult to fit.
Tim
Old 07-04-09, 01:45 AM   #4 (permalink)
did you dyno the engine before and after the exhaust mod without playing with the fuel ande boost? the reason i ask is on my hj 61 i dropped the exhaust just before the big standard muffler at the three bolt flange (so it only had the engine pipe attached to the turbo) and dyno ran it than hooked up original exhaust and re-dynoed and results were it lost torque and a single horsepower (1 bhp) with the 'exhaust dropped' although i hadn't played with boost or fuel. just a point of interest what boost is your engine running and what effects does it have, economy,power, reliability ect as i'm thinking of upping both fuel and boost but wondering what was the best compromise for the 12ht was with reliability economy and driveability being paramount. i don't want to destroy a great engine in search of max power or be unable to afford to keep fuel up to it
plumma is offline   Reply With Quote
Old 07-04-09, 03:17 AM   #5 (permalink)
Garage
Hi Plumma,
Always the big question isn't it!
Have a look at this link in the forum by my mate Graeme who has led me astray with the mods I have done to my IP.
No, I didn't get any baseline readings on the motor before making changes. Free and easy access to a dyno with readout would be a nice thing to have.
Standard boost is 7psi and I've been running 12.5psi for a year or so. It all went fine and all I needed to do was watch EGT's when towing.
When I added the big exhaust I immediately noticed more torque. I drove from Perth to Geraldton, 450km, and could hold gears on the long slow hills on the highway much more than I could before. I used to lose speed if I couldn't maintain 2000rpm and full boost going up a hill, power would drop off quickly once it went. After the new exhaust this wasn't the case and the increased torque was quite obvious. The big exhaust is essential I believe in enabling excess gas to escape quicker. I found EGT's are less with the big exhaust, perhaps 100°C at full power.
In Geraldton I unwound the fuel screw first one, then two full turns. Boost was left at 12.5psi. Power increase was immediately noticeable and the fully loaded car zipped up hills. I really had to keep an eye on EGT as with all that extra capacity for fuel, EGT rose if overfuelled.
Once I got back to Perth, I did my other tests with removing the waste gate control and found EGT's did not rise as much with the extra air supplied by the turbo. Power was, umm, substantial!!!
I've pulled back to 15psi boost and don't get to that very often. I mostly don't rev past 3000rpm as there is plenty of torque and max boost from 1800rpm to 3000rpm and well beyond.
Am I risking my engine? Maybe a little, probably not so much. There is plenty of reports around that 14 - 16 psi is fine for these engines. Extra fuel is always controllable by your right foot. High EGT's are the nasty thing to avoid that will melt stuff, load up your coolant and oil systems.
Yota put a light on the dash that switches on at 14psi, called the overboost light. I figure that Toyota say 14 psi is enough for them, so why not increase boost to that level? I've also got a posting at this link on power boosting, showing how I did it.
Tim
Old 07-04-09, 03:51 AM   #6 (permalink)
sounds the goods but would have been nice to know how much of an increase was gained, what is the fuel bill like, is yours a manual or auto. i have an 86 manual with 35 bfg and my brother has a 87 auto with 33 and mine has about 150 k more kilometers on the clock at over 450 k. saying that he is unable to keep up as mine has more grunt up hiils or on the flat and both engines seem to be stock ,factory boost ect similar weight ect but would always like a little more poke
Old 07-04-09, 07:04 AM   #7 (permalink)
Ive seen upto 170hp by just tweaking fuel and boost in 12ht... 200hp and beyond with modifications, Most limiting factor seems to be the clutch...
-87 HJ61, 12HT engine, pto winch, 33"x12,5" mud-terrains, ~420 000km
blis is offline   Reply With Quote
Old 07-04-09, 07:25 AM   #8 (permalink)
well don't keep me in suspense, details, photos. 170hp 12ht i want one :w rench:
Old 07-04-09, 07:26 PM   #9 (permalink)
Hendrik's Avatar
Check this link: G Bentink 12HT Performance Build
60 Series Tribute / Snorkel / Just wrong
Henry
1986 HJ 60 Sahara - Upgrading...
1986 HJ 61 Sahara - Parts
1999 YZ 400
2001 KX 500
2007 Hayabusa / 178bhp
Hendrik is offline   Reply With Quote
Old 07-05-09, 02:24 AM   #10 (permalink)
"12ht performance build" promises alot but doesn't really deliver. hopefully that will change and we'll see some results because it does have some interesting points
Old 07-05-09, 02:47 AM   #11 (permalink)
Hendrik's Avatar
Originally Posted by Tim-HJ61 View Post
...and my gauges mounted in the overhead unit. Gauges are vege oil temp, vege oil pressure, Turbo boost, EGT.
Forgive my ignorance, but that overhead console looks original - I have not seen one like that before. I have an 86 HJ61 Sahara but it does not the overhead console.
.......I'm looking for some locking diffs...Tim
Cable lockers, auto-lockers, or ARB selectable ?? Just curious as I am looking at 2 x lockers myself.
Henry
1999 YZ 400
2001 KX 500
Old 07-05-09, 06:22 AM   #12 (permalink)
heres one dynograph, standard boost and air to water intercooler...
http://img171.imageshack.us/img171/4...nokppyrnv0.jpg
Old 07-05-09, 07:58 PM   #13 (permalink)
Garage
Jap import. Used to have indoor and outdoor temp gauge and an altimeter and I squeezed in the four gauges.
Tim
Old 07-05-09, 08:05 PM   #14 (permalink)
Garage
Torsen / Truetrac would be nice. Not air lockers. Click click lockrights would be fine. Standard LSD wears clutches too easily and is running like an open diff.
T
Old 07-06-09, 10:29 AM   #15 (permalink)
Tapage's Avatar
Tim great fitment of gauges on the overhead console .. I have it too .. but seems to be complicated toute the vacc line of the boost gauge up there .. ?
Old 07-06-09, 06:43 PM   #16 (permalink)
Garage
Persistence, good luck, and an endoscope all helped. I used small nylon airline that was easy to poke through up the passenger side of the door frame. All the wiring was then strapped on and dragged through. The gauges cost me a fortune (A$550 I think) so I wanted them to look cool.
There was no space for the proper brackets in the console, so they are glued into place. This is now a problem as I want to replace one of them, the vege oil pressure, for one with a lower range. I suspect I will use the one in the console for engine oil pressure and mount a new vege oil pressure gauge on the dash somewhere.
I would have preferred to angle them better so they were looking at me as the driver, but again lack of space meant I had no room to tilt them.
Tim
Old 07-08-09, 09:56 PM   #17 (permalink)
Rookie
I have a 12h-t 24v sahara 1988 turbo. I am trying to find somewhere to get an alternator for it. Toyota say it can be 30amp 0r 40amp. My auto electrician says he cann't see a number.
Any idears where I can get one.
cbpsary
cbpsray is offline   Reply With Quote
Old 07-12-09, 07:58 PM   #18 (permalink)
Hi Plumma, yours has 0.84 final drive, your brothers has 0.716 final drive. Allowing for 35" vs 33" you still have a 10% shorter diff ratio which equals 10% more wheel torque at any given speed. Manuals also have a larger exhaust hiousing on the turbo which brings boost later, but will make more torque once revs get past ~ 2200rpm. I'll bet he beats you on fuel economy on long runs. Would like feedback on that.
Cheers,
Current Project:
Big Boost 12H-T
1988 VX HJ61 Auto
Previous project:
Sold 114kw @ 4 Wheels 1HD-T VX-Ltd 80 Series Auto
gbentink is offline   Reply With Quote
Old 07-12-09, 08:10 PM   #19 (permalink)
Well I can't argue that there has been no deliveries yet, BUT, the engine has been sold to a friend of mine and I will report on its progress. I have decided to do a stroker version of the 12HT, so I sold it.
The engine shown in the twin turbo thread will be intercooled, run max 18psi using a modded CT26 and a big exhaust. I will tune it on the pyro. It will be fitted to a manual, not auto as mine was to be. If funds allow, maybe he will go the twin turbo route. Unlike myself who likes to tinker, he does actually need the car daily so it isnt a practicle R&D vehicle.....
I fully expect some serious performance from this motor and will be sure to get Tim a drive of it once it has been run in and tuned up.
Dyno graphs are misleading. I looked at the graph posted with great interest, BUT if you dont know what smoke it was billowing or what EGT's it was running or if it was corrected flywheel or actual wheel power there is just too much to interpret to get something meaningful.... 161rwhp T such low boost would equal high EGT's and smoke. Tim has his set up nicely, I just wish he would install an intercooler ;-)
Current Project:
Big Boost 12H-T
1988 VX HJ61 Auto
Previous project:
Old 07-13-09, 03:49 AM   #20 (permalink)
g'day gbentink, i'm assuming when you talk about final drives you are talking about the difference in ratios in the transfer cases ( one being an auto and the other manual ) as i'm pretty sure the ratios in the diff 4:11 are the same. As on the subject of economy, i believe mine gets slightly better economy (manual) against my brothers (auto). we have done a few trips side by side over about 500km one way and on the highway mine (manual) was getting about 10.5 litres per 100 which really ***** him as mine uses less fuel and has more power. win win for me and his doesn't seem to blow any more smoke than mine. if you could tell me the difference between a manual and an auto injector pump would be much appreciated thanks plumma
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/292141-12h-t-3-exhaust-installation-hj61.html
Posted By For Type Date
Pan's 60 - Page 6 - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 10-19-09 05:56 AM
Pan's 60 - Page 6 - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 09-01-09 01:34 AM
Pan's 60 - Page 6 - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Pingback 09-01-09 01:19 AM
12H-T power boost - Perth4x4.net Forums This thread Refback 07-03-09 12:39 PM
