Old 06-25-09, 01:39 AM   #1 (permalink)
Question that I haven't been able to get an answer too
I understand the concept of turbo charging an engine. I want to turbo charge my 3B.
I know that you need a manifold, turbo, and oil piping for the charger.
What do you do for the fuel side? Is there anything special that needs to be done to the injection system? Do you need to get more fuel in there or do you just leave it alone? Do you just richen it up so it is ALWAYS pumping in more fuel? How do you do that?
wallybanger is offline   Reply With Quote
Old 06-25-09, 05:06 AM   #2 (permalink)
Tobugrynbak's Avatar
It all depends on how much boost your looking for. More boost needs more fuel.
So yes adjustments to you injector pump will be necessary to some degree.
Fun costs money how hard do you want to laugh?
You won't need more fuel at idle but as you increase rpm and as the turbo kicks in you'll need to have the Injector pump enrich the mixture. There are "Tuners" who modify Injector pumps on a regular basis, best to ask around your local area for the best place to go.
Cheers
Pez
A man generally has two reasons for doing a thing
one that sounds good
and a real one..
UNDERSTEER is when you hit the wall forwards.
OVERSTEER is when you hit the wall backwards.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far the wall moves after you hit it.
Tobugrynbak is offline   Reply With Quote
Old 06-25-09, 03:42 PM   #3 (permalink)
Well it's a 3B with Pre-cups so I'm thinkin' around 5-8lbs should be safe (but I'm not entirely sure). How is the modification to the pump made? Is it internal or is there a linkage that is monkeyed with. Could a guy do it himself or is it advisable to take it to a professional?
Old 06-25-09, 04:23 PM   #4 (permalink)
Tinkering with injector pumps and injectors is best left to those who have the right tools and training. Even my dad with 40 years experience in all things diesel won't tinker with it himself.
That said there are some external adjustments that you can attempt to fiddle with, as long as its done with moderation.
You can adjust the Injector Pump to broadly enrich the fuel. As your only going for lo blo turbocharging, you shouldn't need to do anything radical. Having an exhaust pyrometer will help in your tuning.
The Factory service manual for the engine will have detailed instruction on overhauling the Injector Pump. That will give you pointers on whats what as far as adjustments go.
and a real one..
Old 06-25-09, 07:14 PM   #5 (permalink)
cruiser_guy's Avatar
TLCA# 16387
When you turbo the 3B the fuel adjustments are dependent on the individual application.
My BJ60 needed no adjustments at all to maintain 10psi boost and 1250 F pre-turbo on the EGT's. The FJ55 on the other hand was overfuelling significantly and had to be turned down alot to avoid going to 1250 F on the EGT's pre-turbo.
Where are you located? No doubt there is someone nearby you on this list.
www.wirrell.com
cruiser_guy is online now   Reply With Quote
Old 07-05-09, 01:27 PM   #6 (permalink)
One important mod you need to do, at least a 2 1/2 inch exhaust. With a turbo you increased inlet air you need to allow the exhaust to flow out the added air. I did a turbo on a 3B the exhaust was not done originally, Sheldon told me to install a larger exhaust, I did and the difference in performance, fuel economy and exhaust temp measured pre turbo was greater with the larger exhaust compared to smaller exhaust. Made the mods preform as I expected without the exhaust mod the turbo did not preform as I wanted.
I made a piston that replaced the fuel stop that moved to the boost level so my fuel increased as boost increased if you turn up the fuel after turbo install you will over fuel the motor until full boost.
Jim
jake2far is offline   Reply With Quote
Old 07-25-09, 04:24 PM   #7 (permalink)
Thanks for the replies guys.
So would a guy install an EGT between the manifold and turbo? I'm in Kelowna, so not too far from you actually.
The exhaust is no problem at all. I have a shorty comin out under the door sill and I'll probably run it without a muffler after the turbo.
it would be super awesome if a guy could run the thing without having to make any mods to the fuel system but I definitely don't want to damage the engine.
Old 07-25-09, 04:54 PM   #8 (permalink)
cody c's Avatar
TLCA# #19921
definately put a pyro on it pre turbo.
you dont need to adjust the fuel when you turbo it. i havent, a little less fuel in a turbo-d diesel just means lower temps. opposite of gas motors. later if you want to get more power out of it, you can adjust a screw on the IP which will add more fuel and up EGT's. you can bring add fuel/power till the temps are close to too hot.
Realistically you dont have to worry about the fuel part of it when you are doing a turbo, only for tuning which can be done any time later down the road.
83BJ60,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's
92FJ80 Cummins 6BT, Airbagged, part time 4wd conversion, rancho air adjustable shocks, custom bumper+8274, 35"Toyo M/T's, Mall Ready!
cody c is offline   Reply With Quote
Old 07-25-09, 07:00 PM   #9 (permalink)
crushers's Avatar
14 is safe...
i know a guy that was running 20.
8 is underkill
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
(for any of you going through a divorce, thanks Woody) http://forum.ih8mud.com/1650867-post1.html
Wayne in Ontario
www.luxuryimports.ca
crushers is online now   Reply With Quote
Old 07-25-09, 07:08 PM   #10 (permalink)
crushers's Avatar
your pyro will dictate the fuel settings...
Wayne in Ontario
Old 07-26-09, 02:59 AM   #11 (permalink)
Cool. This is exciting stuff. I need more money in the bank!
Old 07-26-09, 03:48 AM   #12 (permalink)
See the thread at this forum and also the thread in this forum on :12H-T 3" exhaust installation in HJ61: for ideas on how to increase fuel and flow, no matter what engine.
Tim
1989 HJ-61 12H-T, 5 speed, Jap NATO spec, 24v and Redarc Charge Equaliser, Goodyear 694LT 265/75 16 on 16x8 steel rims. Start up on diesel, cruises on 10% ULP and 90% WVO since 2005. 15psi boost, 3" exhaust and no intercooler.
Tim-HJ61 is offline   Reply With Quote
