Old 06-16-09, 03:17 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
87 HJ60's Avatar
EGT probe location (???)
I'm going to install my pyro in my HJ60 this weekend. I have a question about where the probe for the EGT gauge should be located.
I heard that I should install it directly on the exhaust manifold by drilling and tapping a hole.
I also heard that it should be located just after the turbo and on the exhaust downpipe but somewhat close to the turbo.
Any thoughts ??
1987 HJ60
2002 VW Jetta TDI
1995 MustangGT
1970 Mustang MACH1
eddyc01@beachestoronto.com
87 HJ60 is offline   Reply With Quote
Old 06-16-09, 03:25 PM   #2 (permalink)
Former regular
Gold Boy's Avatar
TLCA# 19478
works good for me, that's where mine is located [13bt].
BJ74 & TUFT & U-AFPT
for Okanagan-Similkameen Toyota land cruiser meetings, click here.
Gold Boy is offline   Reply With Quote
Old 06-16-09, 04:00 PM   #3 (permalink)
I had a dual Pyro on my 60, so I had both, in the manifold and in the down pipe 6" below the turbo, there was a good temp difference between the two as well as some what of a lag in the reading of the post turbo probe. That being the case, if I only had the one I would most definetely go for the manifold probe. After all its the exaust temp leaving the head and entering the turbo you are concerned about, If the turbo acts as a heat sink and cools the exaust some, that is of little consern.
92 HDJ 81, intercooled, winched, tripple locked, Kaymar bumper. ( sold HJ 60 1986 5 speed, 1986 HJ 60 Automatic )
bvissers is offline   Reply With Quote
Old 06-16-09, 05:14 PM   #4 (permalink)
amaurer's Avatar
Go pre-turbo. If you go post turbo you'll be using those numbers to try and guess what the pre-turbo numbers are, so why not just measure what you really want to know.
1982 BJ42 "Krull" - DD
www.cruiseruser.com - Replacement gauges and custom knobs.
Have you met LonelyBot?
amaurer is offline   Reply With Quote
Old 06-16-09, 08:26 PM   #5 (permalink)
You need to keep in mind that the numbers are relative, your looking for major increases in temp, you will not be counting each degree. I have said it before and I will say it again, ever major truck engine manufacturer puts the EGT probe post turbo, not in the manifold.
83 BJ60, Needs TLC but gets 25mpg!
84 FJ60, ARB Bull Bar, Powertax Rear, 4:11s, 33x9.5 BFGS, daily driver.
83 FJ60, Incredibly stock, ugly factory brown, daughters rig, engine blown, maybe 3B?
70 FJ40, big pile of rust, future project, needs everything!
valdezhilander is offline   Reply With Quote
Old 06-16-09, 08:32 PM   #6 (permalink)
amaurer's Avatar
... because the manufacturer has fully tested the engine in the engineering stages WITH a pre-turbo probe and knows how to correlate pre and post turbo readings.
On these old engines, where everyone's combo of mods, engine age, turbo type, etc, are unique, we have no such data.
Put it in front of the turbo.
Old 06-16-09, 08:59 PM   #7 (permalink)
What do you base that on? There are plenty of folks on this site that have the probe after the turbo and I am not aware of there being a trend for burn downs? I base what I say off of my personal experience as a diesel mechanic, and I tend to trust the people that design engines that put down 600+ hp and charge upwards of $40,000 for an engine. Here is one more reason, your cast iron mainfold was designed to have certain holes in certain places and expand a certain way, when you start drilling holes in any cast material in a spot not intended to have a hole you weaking that casting and creat a perfect spot for a crack to start. Here's my final comment, you can put that probe where ever you want, but I am going go with where the engineers that actually know what their talking about put it.
There it is...
Old 06-16-09, 09:59 PM   #8 (permalink)
EGT probe
If your using a 13bt exhaust manifold, theres a factory threaded hole just underneath the turbo adapter. You can drill this out and retap with a 1/4"NPT which fits most any EGT probe. I agree with Armuer on the pre-turbo. Why not get the quickest most accurate readings possible. This location is pe turbo as it just enters the turbo. Simple install. Good luck.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Diesel42 is offline   Reply With Quote
Old 06-16-09, 10:05 PM   #9 (permalink)
Sorry, misspelled Amaurer and i meant 1/8"NPT for the probe. Been a long day machining in the shop.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Old 06-16-09, 10:26 PM   #10 (permalink)
Garry's Avatar
Definately pre-turbo
1984 HJ60 Big Red Wagon!
Garry is offline   Reply With Quote
Old 06-16-09, 10:30 PM   #11 (permalink)
Mine is in the top of the manifold, been there for a few years in a hole I drilled, no problems, no leaks or cracks, this is after a fair bit of searching on this site, and the recommendations of the pyro manufacturer I bought. However valdezhilander makes some good points, thus neither is wrong, just make sure you specify where it is when asking questions about heat, and if your readings are good.
onefsatchevy is offline   Reply With Quote
Old 06-17-09, 07:06 AM   #12 (permalink)
sandcruiser's Avatar
I installed mine pre-turbo (hd-t) by drilling/tapping the manifold.
if I were to do it again, I would probably do it the same way.
Post-turbo will not be as accurate, but if the install is easier/safer/faster/cheaper then I would consider that route. Unless you are planning to aggressively tune the motor/fuel delivery/boost, the exact reading of the pyro is not going to make a big difference to you.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
sandcruiser is offline   Reply With Quote
Old 06-17-09, 05:29 PM   #13 (permalink)
Turbo Diesel Lover
Tapage's Avatar
another vote for pre turbo .. ( in both of my Cruisers )
HJ-60 2H-T Intercooled Tencha
Old 06-17-09, 05:40 PM   #14 (permalink)
as sandcruiser said, unless you are going for performance and believe it is critical to know if you are 1201 F pre turbo either position (pre, or post) does not matter. You should use the EGT as a general guide for operation of the engine and limit stress during the high end and allow sufficient cool down when shutting the engine down.
I see more issues with pre turbo vs a post install as far as failure of the probe and destruction of the $$$ turbo. Do put it close the the hot side outlet to get a solid reading.
I'm post, and avoid sustained 1000F operations (I've touched 1000, but less than 10 seconds) try to keep around 900F or less) and cool down I wait until 400 normally to shut the engine down.
The first 100K before I got the engine the owner never once used an EGT...I want to get another 200K without thinking...
rick_d is offline   Reply With Quote
Old 06-18-09, 09:35 AM   #15 (permalink)
Turbo Diesel Lover
Tapage's Avatar
funny and maybe a little paranoic .. but I never shutoff my engine before 350°F ( now running a turbo timer ) and I'm pre turbo ..
Old 06-18-09, 11:06 AM   #16 (permalink)
finderscuba's Avatar
My 1HD-T is always below 350 when idling. It rises with acceleration, and will sustain a higher reading while cruising, but it falls below 350 almost as soon as I stop. According to this, I don't even need my turbo timer. But I idle for at least one minute before every shutdown.
"Rocinante" - '90 JDM HDJ81, 1HD-T, 5 speed, 3" OME lift, 35s, bullbar, IPF Super Rally's, heated seats, Toyota hood ornament (RIP), air suspension, PlantDrive candidate spring 2009
"Simone" - '02 Golf TDI, 5 speed, euro projectors, *'s car*
finderscuba is offline   Reply With Quote
Old 06-18-09, 11:20 AM   #17 (permalink)
amaurer's Avatar
After a long highway run I find that my 3B will soak up enough heat that idle will be over 350. It only takes a minute or so to bring it down below 350 though.
Given enough time, it'll idle just above 200.
Old 06-18-09, 11:51 AM   #18 (permalink)
Turbo Diesel Lover
Tapage's Avatar
well if I drive gentle mine cools faster .. but if I'm with the AC and usually driving around the City at MD haven't lime to let it idlle ..
it's a matter of weather and outside temp ..
Old 06-18-09, 01:09 PM   #19 (permalink)
interesting notes about EGTs. Mine us usually at around 400 when I get home, and takes over a minute to get down near 350. I wonder if I should back the fuel off a little?
More importantly, I suspect my injectors aren't very clean/well tuned.
Old 06-18-09, 02:29 PM   #20 (permalink)
Turbo Diesel Lover
Tapage's Avatar
mine cools much more easy and fast now with the manual tranny (without the auto tranny job on the rad )
Old 06-18-09, 07:34 PM   #21 (permalink)
There it is...
Here is a link to the quote "experts who design the 600+hp"
as far as cracking the exhaust manifold I would like to see a post with pics of someone who has cracked a exhaust manifold thru a hole drilled and tapped for an EGT. If Banks is not big enough of a designer than who would you believe?
Banks Power | Why EGT is Important
Whether the pyrometer thermocouple is mounted before or after the turbine is usually a matter of finding a suitable mounting location, or of convenience. It should be noted that when the EGT is measured after the turbine, the turbine outlet temperature at full throttle or under a heavy load typically would be 200º to 300º F. lower than the EGT measured in the exhaust manifold. The temperature drop after the turbo indicates the amount of heat energy in the total exhaust gas flow that was used to drive the turbocharger. The temperature drop through the turbine is also related to the total flow and speed of the flow through the turbo. At part throttle, under light load, such as cruise conditions, the turbine outlet EGT may be as much as 500º F. lower than the turbine inlet temperature, but the total exhaust flow is much less than at full throttle. At high turbine speeds (under heavy load) the exhaust gases simply don't have time to give up as much heat energy as they speed through the turbine. This variance is why installation of the thermocouple in the exhaust manifold is considered more accurate. The EGTs discussed in the remainder of this article will all be turbine inlet temperatures.
Not my words but I installed my EGT preturbo by drilling a hole and tapping it, knowing what the temp after turbo is a guessing game in my opinon.
BJ70, new frame galvanized, 13BT, warn birfield replacement kit, rear disc conversion, AC installed, Old Man Emu lift kit, anti reverse shackles,
Jim
jake2far is offline   Reply With Quote
Old 06-19-09, 08:08 AM   #22 (permalink)
87 HJ60's Avatar
OK so it seems that pre-turbo is the way to go. As far as drilling and tapping a hole in the exhaust mainfold, should I remove the ehaust manifold from the engine to do this?
My concern is the little bits of metal from the drilling and tapping? If I don't then won't all the metal bits be blown through the turbo and possibly damaging it?
Or is there a way to minimize/prevent this while leaving the mainifold on the engine. Getting the exhaust mainifold is a pain in the buttocks.....
Also is there a particular spot on the mainifold I should install the probe?
1987 HJ60
2002 VW Jetta TDI
1995 MustangGT
1970 Mustang MACH1
Old 06-19-09, 01:15 PM   #23 (permalink)
when I installed mine on the hd-t, I did it without pulling the turbo and without pulling the manifold. It was .... nerve wracking.
But the way I did it was to put a magnet next to the hole- to pull chips/shavings away from the bit, and to do the work while the motor was on so that there was positive pressure on the exhaust system to blow chips/shavings out.
the downside is that you'll probably have to drill, then wait for things to cool off, then tap. The other downside is that I had a lot of trouble getting the tap handle to move freely in there- very cramped.
All things considered, if I did it again, I would seriously consider pulling the turbo (at least) or pulling the whole manifold (better) to do the work.
Old 06-19-09, 07:31 PM   #24 (permalink)
Take the turbo off, use a vacuum cleaner, when drilling vacuum the chips from the outside to the point of penetration, switch the vacuum to the inside, continue with the vacuum inside until you are finished. Coat your tap with grease to aid in cutting as well to trap the chips, wipe everything with a clean rag. Install the EGT probe, hook up the turbo and you are finished.
Jim
Old 06-19-09, 10:46 PM   #25 (permalink)
Have you seen a pre-turbo probe lunch a turbo or is it just the potential that worries you?
The problem with post turbo is the measurements are a guessing game. Sure it'll work as an idiot light (oh look, it jumped 300 degrees, something is wrong), but as a tuning and diagnostic tool it loses all of it's accuracy.
As for a drilled hole starting a crack. Well drilled and tapped holes aren't a good stress riser. Drilled holes are often used to stop cracks growing.
Old 06-19-09, 11:54 PM   #26 (permalink)
All right I have to jump in here again. First of all the temps are all relative. You will have slightly different temps at different spots in your exhaust manifold and for that matter in your entire motor. Since there is no specification for what temp your supposed to have, and where, your'e looking for relative increases and decreases. I prefer after turbo because I don't risk an EGT probe going into the turbo, and yes it does happen, especially in high performance cars and I perfer to not drill out the manifold. To me it is much easier to put a small welded boss on the outlet pipe of the turbo. Which is how all heavy duty diesels are set up. Now there are far more Caterpillars, Detroits and Cummins engines in North America than there ever was or ever will be Toyotas, engines that routinely go to 500,000 miles before in inframe and then go another 500,000 before a crank/cam R/R. I am just saying that I think if it were so much better and more important to have the probe pre-turbo then why don't the big trucks run them that way?
Old 06-20-09, 12:06 AM   #27 (permalink)
"big trucks" run a completely different state of tune. When you've got an engine you want close to a million km from, you run a leaner mix which gives a cooler exhaust.
The probe on those is primarily a driving aid, lets the driving know how hard the engine is working.
The typical person here putting one in is looking for feedback during engine tuning (often after fitting or changing a turbo) and is getting more than stock power levels from their engines. The other benefits include shutdown temperature.
I have a probe in my exhaust manifold and run EGT's up to 750C (higher accidentally sometimes). For me it allows getting the most performance with the least danger. Something a post-turbo probe can never offer.
There is a specific temperature you shouldn't exceed and that's what we use those probes for. Relative sure is interesting, but not as interesting as exactly how hot it gets under full load.
I haven't seen or heard of a probe failing and taking out a turbo. I'd like to hear from someone who has.
Old 06-20-09, 12:07 AM   #28 (permalink)
amaurer's Avatar
But thats not true! There is a specification given by the melting point of the metals used in the cylinders/pistons. Thats where the 1250 max limit stems from.
Because if your manufacturer has gone through the trouble of correlating pre- and post- turbo temperatures over the engine's operating range, then there is no need to take additional preturbo measurements. But since everyone's custom turbo setup is different on this forum, and no one has ever run pre AND post turbo pyros to create such a map for every engine/turbo/exhaust combination, we don't have the luxury of being able to divine the pre turbo temperature from a post turbo measurement.
... which is what I've already said.
Old 06-21-09, 11:09 AM   #29 (permalink)
rchalmers3's Avatar
Location: Playas de Nosara, Nicoya Peninsula, Costa Rica
Pre post pre post pre post
Notice the "Exxes" in those horses eyes. Them horses are dead.
Rick
rchalmers3 is online now   Reply With Quote
Old 07-03-09, 07:29 AM   #30 (permalink)
I'm with Sandcruiser and the nerve wracking comment
I actually drilled one hole and missed the gas flow chamber Hmm, I recall there was a bit of black smoke coming out this spare hole so I tapped it and put a bolt in it. Not my best moment.....
Second hole went right into the right spot and the probe screwed in very nicely. I put lots of grease onto the drill and the tap and am reasonably confident only a minor amount of debris went down the hole and onto the turbo. I've driven 6 months since installing with no adverse affects.
I run up to 600°C - 1100°F before chickening out but am intrigued by Dougal's comment of their being a temperature not to exceed. What is it?? I'd be highly anxious if I saw 750°C on the gauge. That'd freak me!
This is on a 12H-T.
Tim
1989 HJ-61 12H-T, 5 speed, Jap NATO spec, 24v and Redarc Charge Equaliser, Goodyear 694LT 265/75 16 on 16x8 steel rims. Start up on diesel, cruises on 10% ULP and 90% WVO since 2005. 15psi boost, 3" exhaust and no intercooler.
Tim-HJ61 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/289448-egt-probe-location.html
Posted By For Type Date
12H-T power boost - Page 3 - Perth4x4.net Forums This thread Refback 11-06-09 07:31 AM
Diesel Tech and 24 volts Systems on IH8MUD.com Forum - The Truth is in the Rocks | BoardReader This thread Refback 07-10-09 04:43 AM
