Old 07-03-09, 04:42 PM   #31 (permalink)
Originally Posted by Tim-HJ61 View Post
I run up to 600°C - 1100°F before chickening out but am intrigued by Dougal's comment of their being a temperature not to exceed. What is it?? I'd be highly anxious if I saw 750°C on the gauge. That'd freak me!
This is on a 12H-T.
Tim
750C is the absolute upper limit for sane people. Put whatever safety factor on that you like.
750C is 1382F.
Old 07-03-09, 05:10 PM   #32 (permalink)
Turbo Diesel Lover
Tapage's Avatar
750C is 1382F.
how much time you will keep this temp in any IDI engine .. ?
I'm under the idea ( maybe from here ) all over 1250°F will kill my engine ..
HJ-60 2H-T Intercooled Tencha
Old 07-03-09, 05:19 PM   #33 (permalink)
I'm useless as a mechanic, so as long as I have to take it to a garage to install the pyrometer and I'm spending too much in my 80 and the budget is really tight now, let me ask you some questions:
1-Can any regular mechanic do a safe and clean pre-turbo pyrometerer installation or should a take it to a specialist?. I found a mechanic that's been told to be very good, he setup competition vehicles and he knows 80's, but he charges three times as much than the regular mechanic.
2-You said that the post turbo installation is cheaper. How many hours of labour do you think it takes to do a pre turbo and a post turbo installation?
Thank you.
Cañonero is offline   Reply With Quote
Old 07-03-09, 06:54 PM   #34 (permalink)
I don't own any IDI engines, for that reason and others.
Old 07-04-09, 04:14 AM   #35 (permalink)
i put probe post turbo and measured egt's in stock 12ht and then added exhaust and boost and fuel to get correlation of stock egt's to modified egt's to get a good safe tune in engine
plumma is offline   Reply With Quote
Old 07-04-09, 07:51 AM   #36 (permalink)
sandcruiser's Avatar
post-turbo shouldn't take any time at all.... even if you are a crap mechanic, all you have to do is drill a single hole in the exhaust pipe, then use the clamp included w/ the pyrometer to clamp the thing in. 15 minutes?
then some electrical wires. maybe give an hour to do it "nicely".
It is easier than installing an alarm or stereo.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Geolander MT's 33x12.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
sandcruiser is offline   Reply With Quote
Old 07-04-09, 11:47 AM   #37 (permalink)
Originally Posted by sandcruiser View Post
post-turbo shouldn't take any time at all.... even if you are a **** mechanic, all you have to do is drill a single hole in the exhaust pipe, then use the clamp included w/ the pyrometer to clamp the thing in. 15 minutes?
Thank you, sandcruiser.
And what about pre-turbo?, how much time would it take to a regular mechanic to do it nicely and safely?
Old 07-04-09, 04:00 PM   #38 (permalink)
As soon as you increase boost or fuel, your correlation to the original EGT's are lost.
Old 07-05-09, 05:12 PM   #39 (permalink)
pre turbo, it'll take more time, but I don't have a good estimate of what it "should" take.
it took me all day, but a part of that was learning how to use a tap
Old 07-05-09, 05:59 PM   #40 (permalink)
Thank you Sandcruiser.
I hope it doesn't take that long to my mechanic
Anyway, as you are in Costa Rica, you may be able to tell me, what's the exact translation to spanish of Tap, in this context?
Old 07-06-09, 07:59 AM   #41 (permalink)
not really sure about "Tap"... finding a tap set here was difficult. "un macho para hacer roscas" seemed to get the message across, but that may vary from CR to Spain. "broca para cortar roscas" also seems to get some understanding on the faces of the hardware store guys.
"cortar roscas" would be the closest verb for "to tap". As far as I can tell.
Old 07-06-09, 12:16 PM   #42 (permalink)
Turbo Diesel Lover
Tapage's Avatar
in my field experience, it looks mi DI engine can raise much more easy the EGT compared to my IDI engine .. both boosting the same and both with plenty of diesel available at the IP ..
also .. the IDI looks will raise the water engine temp before you have real high EGT problem ..
Old 07-06-09, 02:48 PM   #43 (permalink)
Yes, the IDI engines lose more heat into the cooling system through the head and precups. Because the Di combustion chambers have less surface area the heat stays in the gas better.
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/289448-egt-probe-location.html
Posted By For Type Date
12H-T power boost - Page 3 - Perth4x4.net Forums This thread Refback 11-06-09 07:31 AM
Diesel Tech and 24 volts Systems on IH8MUD.com Forum - The Truth is in the Rocks | BoardReader This thread Refback 07-10-09 04:43 AM
