Hi all
I have searched the web and asked around. I need some info on this in regards to a 1KZ-T conversion.
There's a lot of info on intercooling gasser's but very little on intercooling diesels.
Some just project gasser theory and practice on to diesels, some say that is a big mistake.
I have searched, on Yotatech, Toyotadiesel and the web in general and found one article that expalins the difference in diesel intercooling vs. gas-powered intercooling.
I others want to read the article it's here:
Browser Warning
A brief summary:
Turboed gas engines are only on boost for short periods. There are several rewasons for this, the fact that a diesel does not close off the air supply when you lift your foot of the throttle, diesels being pushed harder from the factory and running higher boosts in general.
This means that a gas engine (on boost occasionally) uses the intercooler as a heat-sink. The aluminium absorbs the heat on boost, and dissipates it to ambient air, as weel as intake air when not on boost.
Diesels are on boost more of the time. Therefore a diesel intercooler must be more efficient at dissipating heat to ambient air.
Conclusion from the article: " [...] However, because more boost is used much more often, intercooling a diesel turbo requires much better design than an equivalently sized petrol turbo engine." (Browser Warning)
If you want more detail, read the article, it is quite informative!
Well we are installing a 1KZ-T from a prado in an old army Volvo truck.
The 1KZ-T has no intercooler from the factory. I want to add one for a few reasons listed in order of importance:
I have found two options that might fit, but this is where I would like the experts to come in; short way, better flow or long way through, better cooling?
Overall Size 23"x11"(9.5")"x3"
Core Size 19.5"X6"X3", 2.5" Inlet & Outlet
So I thought it would be interesting to start a thread on the subject, not only for my application, but for all applications. It could be nice if w could gather the knowledge here instead of having a lot of fragmented info all over.
Browser Warning
A brief summary:
- The 1KZ-T has a reputation for cracking heads. This is usually because the engine runs too hot, adding an intercooler might help.
- Keeping engine bay temps down. the Volvo being a cab forward design, there's a possible heat build-up under the cab where the engine sits. adding an intercooler might help that.
- Getting a few more ponys...
Overall Size: 29"x8"x3.5"
2.5" Inlet & Outlet One Side
3.5" Core
3.5" Core
Core Size: 22"X8"X3.5"
