07-06-09, 08:58 AM
#31 (permalink)
Just what you'd expect
USD. TOYOTA LANDCRUISER 2H STARTER MOTOR - eBay Other Engines, Components, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 16-Jul-09 08:34:24 AEST)
and then there's this (apparently identical, different price):
TOYOTA LANDCRUISER 2H STARTER MOTOR - eBay Other Engines, Components, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 21-Jul-09 07:07:09 AEST)
07-07-09, 02:37 AM
#32 (permalink)
I am shocked. I found plenty more NEW starters for sale (in oz)- BUT those ebay starters are the cheapest I can find on the net ATM.
Tofudebeest - you have a PM.
60 Series Tribute / Snorkel / Just wrong
 Henry
1986 HJ 60 Sahara - Upgrading...
1986 HJ 61 Sahara - Parts
1999 YZ 400
2001 KX 500
2007 Hayabusa / 178bhp
07-07-09, 04:23 PM
#33 (permalink)
I was having the same problem in my HJ47, just a click. replacing the contacts did not help. After running around for an hour with a meter I found the voltage after the starter relay was 2 volts less then at the battery, when the key was in the start position. I replaced the relay and not a problem since.
1952 M135 (Wifes)
1963 FJ40 w/3BII Conversion (In Progress)
1977 FJ40 Weber and HEI (Wifes but rolled by me at 07 FG)
1980 HJ47 Stock
2002 100 Stock
07-09-09, 09:59 AM
#34 (permalink)
Well, I did it.
I went to AAMAC.
He eyeballed the starter and said (and mind you that the tag is long gone): "Well, it is Japanese, industrial of some sort, looks familiar. Is this from some kind of heavy machinery?" I said, "If you have seen this unit before, is was probably from a Hino forklift, but this is factory equipped on diesel Landcruisers, which is where this one lives." He replied "Oh, shit, that's cool."
He then said: "So what's it doing"?, and I pulled the gear out and let it snap back and said "It is making that noise, and won't engage. Hammer whacks used to do the trick, but stopped working, now I have to rock the truck back and forth in gear, and sometimes that works. I replaced the contact and plunger about 5000 miles ago, have pulled this bitch at least 20 times to inspect, clean, freshen up the contacts, etc. but the situation is deteriorating quickly."
He said: "And now you are here. Solenoid, buddy, solenoid."
So, not only did he fix that, but he installed two of the four replacement brushes I provided (the positive ones, the neutrals were relatively unworn, as you can see in the photos), and because he felt is was too noisy, he replaced ALL of the bearings, he reset/realigned the contacts, and then POLISHED THE EXTERIOR, because he was unhappy with what my months of beating on this thing with a hammer had done to the case.
I came to pick it up and he apologized for misquoting me on the job. He had quoted me $90.
I was actually prepared for a much bigger bill.
He charged me $62 + tax. $66.19 out the door!!! I jokingly told him that he's a shitty businessman, and that I really appreciate his more than reasonable rates, honesty, skill, etc..
So, I am giving him a non-functioning 2F starter as a tip (broken wire in the coil). He was more than pleased with that gesture. I also told him I'd send him as much business as I can.
I installed it last night and it is almost silent by comparison, STRONG, and should provide me with hassle-free starts for many years.
07-09-09, 04:28 PM
#35 (permalink)
Great news tofudebeest.
My guess is that the "Pull-in coil" in the old solenoid was toast.
That shop sounds like the ulitmate. (Wish it was here in NZ!)
07-09-09, 05:28 PM
#36 (permalink)
Well....
Not so fast.
I fueled up today (B100). It was my 5th start since this rebuild...no start. Took about 5-7 tries.
I am going to cry, injure someone and break something, not necessarily in that order.
So...All I can figure is bad wiring, because I made 100% sure my grounding spots were clean and as tight as a frog's ass. So, let's troubleshoot...
Starter torn apart and fully rebuilt. Hammer whacks on the case get it to work, or when it doesn't, putting it in gear and rocking the truck back and forth does...
Not a relay (or is it?)...not the ignition switch (or is it?)...what else could it be?????
Or I guess this starter rebuilder could have missed something...
07-09-09, 07:06 PM
#37 (permalink)
Shameless self-bump. I am desperate...
07-09-09, 09:59 PM
#38 (permalink)
Well I can't defend self-bumping. (And who can?) Surely it must be on a parr (in shamefulness) with all those other self-......... things.
And my intitial thoughts were to refer you to Dr Death (over the ditch from here - in Australia's Northern Territory). He may be Australian, but I'm told he's very good with advice on "assisted-suicides". (I'm saving for my "trip to end a lifetime".) But then again ..... you mightn't be old enough. This guy has dedicated his life to helping us older folk. (And I'm extremely grateful cos it's not often we get priveledged with special treatment!)
Then I got to thinking of an alternative option. ............But unfortunately diesel is less-flammable than petrol. So by a cruel twist of fate - It will be harder to set the "object of your distress" on fire.
But then again ...... Perhaps we're getting ahead of ourselves here. (Maybe save the afore-mentioned generous advice for later?)
I'm pretty sure someone in this thread suggested that your "start relay" could be the culprit (saying that it had been the case for them when they'd experienced identical symptoms). So why not bypass your ignition key and start relay with a wire directly to your starter solenoid. Then if it" does crank" or "doesn't crank" every time you apply juice there - you'd at least have narrowed down (or eliminated) "possible problem areas".
But if you do this ...... Be careful how you apply the power, make sure your cruiser g/box is in neutral beforehand, etc etc. (Or else you may accomplish the 1st goal ahead of time.)
07-10-09, 11:58 AM
#39 (permalink)
Starter relay was checked.. Did I forget to mention that? Hammer whacks on the starter would not work if it were the relay.
I found "the best mechanic in Gainesville", and we chatted for 15 minutes. I am seeing him on Monday. He suspects a few spots on the flywheel have been worn/deformed, etc. which is where it stops 1/3 of the time to every time, depending on the vehicle, which may be preventing the business end of the starter from meshing, not allowing the contacts and plunger to touch, and hence not energize. If that's the problem, a little dremmel action on the troubled teeth on the flywheel should fix this problem. The starter's gear teeth are nicely knife-edged, but if the flywheel teeth are funky, the starter gear may just be smacking into the teeth on the flywheel and stopping, like a whisky dick on a cold night. Slightly moving the flywheel by rocking the truck in gear or alternatively by whacking the starter might be enough to result in the penetration needed.
Classic...shes needs to be man-handled and roughed up a bit to get turned on...
If this pans out as predicted, it means that Sheila lives after all.
If that's not it, he will bypass the ignition etc. as you suspect, to eliminate some theoretical (likely measurable) voltage loss as the current goes through the components before it gets to the starter.
I am actually gonna drop this starter this weekend and inspect that flywheel closely (with pictures). I may save myself a few hours of $85/hr. labor charges.
07-11-09, 07:48 PM
#41 (permalink)
The bumping in gear or whacking with the hammer probably just moves one gear or the other enough so they slide and engage. A voltage drop from the relay or a weak pull coil both could cause not enough pressure on the gear teeth to allow them to slide past each other and engage. If the pull is marginal, any burs on the gear teeth would make the problem worse. I would suspect that cleaning up the teeth will help for a while and mask the other problem. Ditto on the idea of bypassing the relay to test the engagement first.
PS: Is it Rodgers Truck in Gainesville? I have a few relatives in FL and that is someone they have mentioned.
1952 M135 (Wifes)
1980 HJ47 Stock
2002 100 Stock
07-11-09, 08:41 PM
#42 (permalink)
Dave Mays.
07-14-09, 02:36 PM
#43 (permalink)
Problem solved.
Voltage at the starter: 7. Put a new relay and kick it back up prior to reaching the starter: 12-14.
Stater is fine, wiring is fine, original relay is fine (I think?), but something (too many connections?) was causing a voltage drop between the battery and the starter. Now that it gets ample juice, ZING!
09-24-09, 02:05 PM
#44 (permalink)
Drinking the Kool-aid
Originally Posted by Tofudebeest
Problem solved.
Tofu - can you give me a ref # and/or source for that relay? Was it an upgrade (like door locks and power windows) or just a replacement of the original?
UPDATE: Interesting fix on another site Starter relay - Toyota Forums :: Toyota Nation may not be applicable.
'88 FJ62 - 12HT conversion, OME Lift, ARB front bumper, Roof Rack
'04 Prius - stock
'66 Pearson Commander - a hole in the water to throw money into.
__________________________________________________ ________________________________________
And we are here as on a darkling plain
Swept with confused alarms of struggle and flight,
Where ignorant armies clash by night.
Reason: Found something
09-25-09, 07:30 PM
#45 (permalink)
From post 6 your troubles sound exactly like the one I have. The issue for me is a shoddy ground wire for the starter, doesn't always get enough contact/slow to start. Maybe your ground is good, but it's definitely something to check
09-28-09, 11:04 AM
#46 (permalink)
No, an upgrade..
Ford FOAB-14B192-AA
