Old 09-06-08, 09:55 AM   #1 (permalink)
Question 1KZ-T Turbo on a 13B-T
I have a dead 1KZ-T with pefect stock turbo on it. I don't know its specs but was wondering if it's better that CT26 that comes with a 13B-T.
Actually, the turbo on 13B-T, CT26 spits some oil in air intake. Was wondering if the swap would be good idea.
danhr is offline   Reply With Quote
Old 09-06-08, 04:15 PM   #2 (permalink)
What turbo came with the KZ is it a CT-20?
RHD Toyota's is offline   Reply With Quote
Old 09-06-08, 04:31 PM   #3 (permalink)
CT12B
Yes it'd be a good match.
Old 09-06-08, 05:26 PM   #4 (permalink)
Is there much difference between the ct12a and the ct12b? Looking at the CT12a on a Soarer I have they look quite small and can't produce much more 16psi safely.
What turbo comes on the 2lte? anyone know
Old 09-06-08, 05:52 PM   #5 (permalink)
I've never seen a CT12A, but toyota seem to use the B suffix to indicate a bigger turbo.
For example the CT20 is the small turbo found on the 2.4 litre 2LT, where the CT20B is big enough that the ricers chase after them, rumoured to flow more air than the CT26.
Old 09-06-08, 10:13 PM   #6 (permalink)
retired maths geek huh
denis's Avatar
I don't have a 13B CT26 to check but have a CT12B and it's quite a bit smaller than the 1HD or the 7MG CT26s. Physically it's slightly bigger than a CT20, anyway it works so well on a KZ it can't be bad on a 13B with only marginal additionnal displacement and lower power curve.
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil View Post
there are a lot more single women available then nice low mileage Land Cruisers.
denis is offline   Reply With Quote
Old 09-07-08, 01:40 AM   #7 (permalink)
Wouldn't CT12B (that you say comes with a 1KZ-T) be smaller than CT26? And wouldn't smaller turbo mean lower power i.e. lower PSI/CFM?
Please compare CT26 with CT12B. I have noticed that CT12B is indeed smaller than CT26.
Old 09-07-08, 01:57 AM   #8 (permalink)
Dieselevente do list a CT26 for the 13BT, but they don't have any more information on exactly which mix of CT26 parts it uses.
TOYOTA turbochargers, TOYOTA turbo, TOYOTA turbocharger, TOYOTA diesel injection
The CT12B is a later generation turbo than the CT26, as turbo design progresses more airflow is possible from a physically smaller turbo. Given the 1KZ has more power than the 13BT had, it's fair to say the CT12B turbo will have enough airflow capacity. In fact some of the 15BT's (larger than the 13BT) used the CT12B.
Old 09-07-08, 12:55 PM   #9 (permalink)
Is there anything like CT26B?
Seems CT26 has been used in newer 1HDs. I was once told by mechanic that he can provide me with two turbos of 1KZ-T for in exchange of my CT26. I was surprised back then. He never told me the reason but now I know.
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
