Old 08-28-08, 11:36 PM   #1
Transmission Service on HDJ81
Hi All,
I would like to change the transmission oil in my 1990 HDJ81. It has A442F transmission in it. Is it just a simple drain-and-refill job or should I worry about anything else?
FSM says, drain from the drain plug then pour through the filler neck. Is that all??
I am thinking of using Amsoil Synthetic Transmission oil. Opinions??
Cheers,
Ahmed
1990 HDJ81
aabasiry is offline   Reply With Quote
Old 08-29-08, 02:56 PM   #2
Hmmm.. seems that no one ever did any service to their transmissions before..!!
1990 HDJ81
Old 08-29-08, 08:58 PM   #3
I have a 1991, what you'll find is that draining the pan will only remove about 4-6 liters of oil at a time and our trannies have a capacity of roughly 15 liters. So if you want to go synthetic you should do it in one shot with a tranny flush/transfusion machine, it is pressurized and goes through the whole tranny including torque converter, valve body and pressure lines. Be prepared to buy 20 liters if you're going this way plus cost of service from shop. What im doing is using ac delco dexron vi (made by petro-canada) and changing fluid one pan drain at a time, usually when i change my oil. This gradually changes fluid from old to new. If you look in the 80's forum, it describes this technique.
Later
TrouserChili is offline   Reply With Quote
Old 08-30-08, 01:48 PM   #4
shromani's Avatar
X2, did the flush as posted on the 80's forum and it worked like a charm, just as they said it would. I went with the cheap walmart 5 gal pail (Will switch synthetic when I have the money, I just wanted it changed) and cycled it untill all the dark oil was gone. Don't foget to put the truck into "L" for a bit to cycle the oil that way too.
Ken
Daughters were God's revenge on you for being a man:
you lived in moral fear that they might accidentally encounter
somebody like... yourself at that age.
John Clark - Debt of Honor - Tom Clancy
'97 Rav4
'90 HDJ81 VX Limited
'67 Mustang Convertible
'90 4Runner - 7MGE project that I sold
shromani is offline   Reply With Quote
Old 08-30-08, 11:48 PM   #5
Thanks guys.. I appreciate the help..
I will look in the 80's forum for the details..
Cheers,
Ahmed
1990 HDJ81
Old 09-01-08, 06:10 PM   #6
Tapage's Avatar
I recomend keep using same mineral oil .. and keep the old oil in a pan ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Refinance | Promotional Codes | Loans | Internet Advertising | Mortgage
