Water pump problem
Does anybody know if the diesel motors, (the 2b specifically), water pumps have a weep hole in the bottom that lets you know when the pump is going bad? I got a leak and it looks like it's coming from the bottom of the pump.
__________________ 1980 BJ41 33' BFG OME Dakar Lift "Happy to be here, Proud to serve" (Some crusty old BMC) |
Mine just went a few weeks ago...and it started rattling real bad. It was all over in about 15 min & I had to tow it back to my garage. Time to order one 'cause it coming.
I think my B engine has a weep hole, and if so, your 2B would likely have one too. But I can't remember for sure.
But why does it matter whether you have a "weep hole" or not? If there is no weep hole, and the seal within the pump fails, the coolant will simply spew out through the waterpump bearing instead of coming out the weep hole. The way I see it ----- Either way - You've still got to renew your water pump. I presume the precise source of your coolant leak is hidden by your fan pulley at the moment. Can I suggest you loosen your fan belt (via the alternator-pivot adjustment) and then see if you can wobble the fan pulley. If you can wobble it - This will confirm that your waterpump is "carput". ![]() PS. The seal can still fail without you finding that the waterpump bearings are "shot" - but this isn't very common from my experience. __________________ Name's really Tom & I have a 1979 BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981 A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A trunk is really a boot........... |
My 2H WP have this hole .. and in my experience it's the first advice that ket me know my WP it's diying ..
Thanks for the replies. I just got home from a 200 mile tow. I was up in San Francisco home is in San Luis Obispo. Thanks to an awesome member, water pump is on order. Is there anything I should look at while I have the pump out besides hoses, belts, Etc.. The pump for my 2b is not cheap, anyone ever rebuild a water pump, it would be nice to have a spare on the shelf.
#6 | |
And be very careful of the pump gasket. I damaged one by trying to fit the pump with the gasket attached to it. Better to stick the gasket to the block instead. (I just stuck it there using some copper grease on the non-sealing part of it.) It is a special/expensive gasket from memory. You'll probably need to swap the "BSPTxhose fitting" from your old puump to your new one. (Hope it is not too badly rusted. If it is you'll need to replace it.) And looking at my records - I see the pump I fitted to my B engine back in 2000 did indeed have "coolant weep holes". (It actually had two - one top and one bottom.) I have rebuilt water pumps before but not those from a cruiser. But I kept my original ex-factory pump for this very same purpose though. I think the best procedure would be to remove the old bearing and old seal and them take them to a parts shop for matching replacements. My guess is that they would be generic (common to other pumps in other vehicles) and wouldn't be hard to obtain.
Keep your old hoses if in good condition as spares, because you know they fit. New thermostat, and you might as well flush the cooling system, before you refill it with new antifreeze.
__________________ Rob S. 1981 CDN BJ42 All Stock (except for that Orange paint job!), custom roof rack, 1986 Warn M12000 24v winch, need restoration soon.... Beautiful British Columbia, Canada ![]() 2007 Yaris, daily commuter Brodie 1-ball; simple, like my Cruiser |
Mobile Phone | Secured Loans | Loans | Remortgages | Credit Card Debt Consolidation |
