12ht into bj40 STOPPPPEEDDDD
ok to start it off to all the guys who said that the 12ht will bolt straight into my bj40 with pre 84 60 series engine mounts are wrong.. i pulled my b series diesel engine out to put the 12ht in and soon found out that the mounts are out by 25cm atleast, even when the motor is right up against the firewall. now i have to remove the old engine mounts and do it all custom even the gearbox crossmember as some of you told me that would bolt straight up too.. anyway has anyone actually done this conversion before?? i know of one guy on here with a red bj40 with a 12ht but thats all i have seen and he hasnt replied to my pm's so i dont know where to get the info from??
thanks mitch |
#2 | |
Diesel for blood
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Mitch,
You'll need to use the FJ40 mounts on the chassis and the pre 11-84 mounts on the engine. That configuration WILL bolt up. I changed from a BJ series chassis to the 12HT and thats what it took. PM me your e-mail adress and i'll mail you some pictures of how my mounts on both chassis and engine are located. And yes, the HJ47/2H mounts will work too, but those don't have the mounting for the PS pump. Mark __________________ 1982 BJ 45 Troopcarrier 12H-t, H55-f, 60 series PS, cable lockers, HZJ73 rear axle w/disks, parabolics, 255/85/16 |
ouch...
hummm, if it is on the internet then it must be true...leason learned. of course the engine mounts will need to be changed the tranny will not work (different imput shaft) the tranny mounts are different (on the older B enignes the rear engine mount was off the bell housing) the driveshafts will need to be modified the rad is different the shifter "might" be in the same location although i doubt it the e/brake will need to be modified shall i continue? sorry, i missed your original post... maybe it was while i was on a self-ban for a few months... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#5 | |
__________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
you know it...
a 1HZT into a FJ40 and a 1HZTI into a HJ60... thanks for reminding me of my... ummm... fun times? <self imposed exile...i like that terminology> __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
good shot .. we forget it sometimes ..
Diesel for blood
What did the 40 go like?
you know the saying
get in buckle up hold on!! it takes on a whole new meaning. the bloody things feels like a very well running gasser!! from Calgary to Ontario pulling 3000 lbs we returned a constant 27.5 mpg Canadian. ability to quickly accelerate and pass if needed and QUIET... as far as i am concerned it is the BEST swap for a 40 series or a 60 series. no sensitive throttle issues, parts availability for the next 20 years, quiet, powerful and wicked on fuel AND the ability to make you smile!! i am installing a fiberglass body on the truck which means i will be removing the engine again so i can do a detailed post of the swap at that time. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#10 | |
and i got a 5 speed box with the 12ht so i dont need to change the input shaft. and i know about the driveshafts and its only common sense that the handbrake will need to be changed... |
#11 | |
.I plan to swap my 3bII with a 1HZ in my BJ70RT at some point, I just can't get enough of the 1HZ. I drive the BJ42 less and less (especially with the BJ70RT, it is no comparison) but If I don't sell it soon, maybe someday I will do a 1HZ in that as well, I bet it would be sweet. Now if I can just get a hold of some 1HZ's...In the US ![]() Post some picks Wayne ![]() Cheers, Michael |
#12 |
I'd be interested to see the post where folks say a 12ht would bolt right up to a BJ40. I expect we are going to find a reading comprehension problem.
One way or the other, building custom motor mounts is two banana. Quityerbitchin and post some picks of the swap.
#13 |
Diesel for blood
Anyone know if a BJ42 5sp crossmember would work on his 5sp?
#14 |
the H55F will use the same crossmember as the 83-84 BJ42 but he does not have the pieces on the frame so he will need to buy the "L" mounts and either weld or drill and bolt them to the frame...
#15 |
I can pretty much concur with Crushers/Wayne's notes:
I did this conversion into my 1982 FJ40. Used troopie mounts. I had to graft the P/S tab from the '60 mount. 60s and 40 H mounts use different engine mount rubber (locating pins are in different places). I fabbed some mounts for the '60 radiator and used custom rad hoses....Yes, I also had new driveshafts, modified the crossmember, modified the steering shaft, new tranny floor cover. I was spared the B versus F&H input shaft difference since I used a new H55. The list continues...but is was amazingly time consuming and fun... BTW: The engine is too tight so you can't REALLY use the mechanical fan & fan clutch if you want A/C.....I discovered this the HARD way over 100 miles into the desert (but that's another story and lot's of $$$ later). Hope that helped. __________________ N6LG - Extra Class Amateur Radio Operator 1982 FJ40 (HJ41), 12HT turbo diesel, H55, ARB locker, e-locker, Marks Gears, APRS 1997 LX450, 1HT-FT/H151 diesel conversion in process... 1972 FJ40 Fun Beater Rig, Bone Stock! |
#16 |
Zip cut and a welder
__________________ -24 volt 1980 BJ40. -Five 24 Volt Hobbs heavy duty equipment lights. -32x11.5 GWrench AT's. |
#17 |
Check my rebuild.
The 2H & 12h-t will bolt straight in as long as you get the engine brackets off a HJ47 or HJ45 that had a 2H in it and the rubber engine mounts to suit. The engine brackets on a 2H or 12H-t out of a 60 series or 75 series won't bolt straight in. If you want to use those brackets then you have to move the chassis mounts, also the engine mounts (rubber) have the locating pin offset. You also need the bracket plate for under the gearbox but that depends of what year chassis you have and whether it was a diesel or petrol FJ to start with. That should be ok if it was a BJ40 but it might need moving. PS. Your current front & rear tailshafts maybe the wrong lengths as well. __________________ Rebuild 1974 FJ40 2F into a 1984 HJ43 2H Diesel. http://forum.ih8mud.com/40-55-series-tech/173333-rebuild-my-fj40-1974-rhd-down-under.html Last edited by watrob; 09-03-08 at 07:37 PM. |
Vacation Spots | Sports 2007 | Credit Check | Share Prices | Mortgage Calculator |
