Old 08-10-08, 04:30 PM   #1 (permalink)
amaurer's Avatar
3B valve stem seal replacement (pics!)
I *think* I've found the source of my occasional stink and oil loss. (see http://forum.ih8mud.com/diesel-tech-...l-mystery.html)
I don't see people talking about valve seals on 3B's much, but I found that 3 of them were loose, and 2 weren't even seated on the guides anymore, they were just floating up on the valve stem!!
Sadly, I couldn't get my hands on 8 seals, SOR only had 6 and I couldn't find ANY suppliers. I replaced 5, ruined one, and reused the tightest fitting of the old ones. , I know.
Here are some pics, its an easy job...
#1 remove rocker cover and rocker ass'y.
#2 rig up a hose from your air compressor and set it to 90psi or so.
#3 i used a spare fitting from my compression tester set, if you do so, remember to drill out the schraeder valve inside it though.
1982 BJ42 "Krull" - DD
www.cruiseruser.com - Replacement gauges and custom knobs.
Have you met LonelyBot?
amaurer is offline   Reply With Quote
Old 08-10-08, 04:32 PM   #2 (permalink)
amaurer's Avatar
#4 attach the compressor hose to your fitting with a clamp, and apply valve spring compressor
#5 tap the spring compressor to break the keepers loose and remove them
#6 remove the springs
Old 08-10-08, 04:34 PM   #3 (permalink)
amaurer's Avatar
#7 remove the old seal, just pull with a twist.
#8 install the new one. I used a socket to help push it down easily... they're TIGHT! so careful hammering is needed. I ended up ruining a seal by hammering it on cockeyed, beware!
#9 Voila! rinse, repeat.
Old 08-10-08, 05:09 PM   #4 (permalink)
gerg's Avatar
TLCA# Iforgotmynmbr
Thanks man I never thought of that as a potential problem. It is also comforting to know that I am not the only one with a disaster for a garage!
g
There is no such thing as a stupid question... just stupid people.
gerg is offline   Reply With Quote
Old 08-10-08, 07:05 PM   #5 (permalink)
Another excellent tutorial.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Diesel42 is offline   Reply With Quote
Old 08-10-08, 07:26 PM   #6 (permalink)
lostmarbles's Avatar
Great work Drew. (I especially like the compressed air idea.)
Name's really Tom & I have a 1979 Australian-market BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A tire is really a tyre...........
lostmarbles is offline   Reply With Quote
Old 08-11-08, 08:48 AM   #7 (permalink)
amaurer's Avatar
g
I'm offended, thats the cleanest its ever been!!
Old 08-30-08, 10:06 AM   #8 (permalink)
BrianSanDiego's Avatar
Thanks a LOT for the writeup. I'm going to need to do this on mine soon and pics always help a lot!
9/'72 FJ40. Chevy 327 with Holley Fuel Injection, Metaltech cage, Warn 8074, Shackle Reversal, and 33's.
Some of my pics... http://www.flickr.com/photos/11281533@N04/
BrianSanDiego is offline   Reply With Quote
Old 08-30-08, 03:35 PM   #9 (permalink)
North Florida Cruiserhead
mel lowe's Avatar
TLCA# 19409
Any other sources for the seals?
I don't even want to look at mine w/o new ones in hand.
82 Fj60 - 2F, 37"s, Toybox, Daily Driver, 62 Frame, Lights, Grill and Roof
http://nfcruiserheads.org/forum
mel lowe is offline   Reply With Quote
Old 08-30-08, 03:58 PM   #10 (permalink)
crushers's Avatar
nice write up...
thanks
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
(for any of you going through a divorce, thanks Woody) http://forum.ih8mud.com/1650867-post1.html
Wayne in Ontario
www.luxuryimports.ca
Old 09-02-08, 08:05 PM   #11 (permalink)
RufusTheDufus's Avatar
What gap did you set the valves to cold? Is there a general rule of thumb on what the cold gap should be? I know that the valves supposed to be adjusted when the engine is at operating temp but there has to be some baseline that's used as an initial setting.
RufusTheDufus is offline   Reply With Quote
Old 09-02-08, 09:08 PM   #12 (permalink)
I found the answer in the FSM. (I should have checked there first.) The initial cold adjustment is the same as the hot.
Old 09-18-08, 06:04 AM   #13 (permalink)
amaurer did this fix your oil usage problem,im doing my 12ht the same way tomorrow,ive got similar probs,good compression but chewing oil,keen to know how its going after you changed the seals
cheers goldchaser
goldchaser is offline   Reply With Quote
Old 09-18-08, 08:58 AM   #14 (permalink)
amaurer's Avatar
cheers goldchaser
no.
Its not that they didn't need to be replaced, as it was clear my old ones were toast, it just sadly didn't fix it. I don't know if thats cuz i damaged some of the new seals putting them on, or, more likely, my problem is just elsewhere. sigh.
