Old 07-30-08, 05:15 AM   #1
Question 1 hdt rough running
Hi All,
I've just rebuilt the engine on my 80 Series 4.2 TD 12 valve. The engine has been re-bored, and now has new pistons, rings, main and big end bearings. All new seals, cam shaft bearing, recon injectors, rebuilt fuel pump, new valve stem oil seals, a new thermostat, and I replaced all the sender units while I was at it. Once primed, the engine started with good oil pressure, and idles smoothly. However, as the rpm is increased, the engine starts to shake. This is most pronounced at 2500 rpm. As far as I can see, there are no leaks on any of the injection pipes or return lines. The valve shims are all "middle of the road", and all the cylinders are compressing well with virtually identical compression. I’ve tried cracking all the injection lines one by one, and all exacerbate the problem except for number five. With this line loose, the lumpiness disappears. I swapped no 2 and no 5 injectors around but this made no difference. Strangely, both injectors had a heavy carbon build up after slightly less than 500 miles. The timing is spot on. My next step is to try and measure the fuel flow to each cylinder, and perhaps that'll point me in the right direction? Any thoughts on how to solve the problem would be greatly appreciated.
Regards,
Ian.
Imakora is offline   Reply With Quote
Old 07-30-08, 07:37 AM   #2
lshobie's Avatar
Check the injection pump, sounds like something isn't right with it.
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 07-30-08, 07:47 AM   #3
Diesel for blood
roscoFJ73's Avatar
Hi Ian and welcome to mud
I would start with cheap easy things.
Has the timing belt jumped a tooth?
Harmonic balancer not on properly or damaged?
Does the engine shake in neutral at 2500 or only on the highway?
Any smoke ,colour?
Maybe an injector or 2 isnt opening properly at higher rpms
You will have put some money into that I did a similar engine and pump rebuild a few years back and it tested my wallet
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 07-30-08, 07:51 AM   #4
lshobie's Avatar
Good points mate.
Louis
Old 07-30-08, 03:15 PM   #5
Tapage's Avatar
When you was loosing the injector lines .. how was the spray pathern .?
Other thing to check .. opening pressure values ..
New Nozzle 2062-2205 PSI
Used Nozzle 1920-2205 PSI ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Internet Advertising | Loans | Magazine Subscriptions | Gas Suppliers | Loans
