Old 07-29-08, 06:37 AM   #1
HJ60 Turbo cuts out
hi there guy just seeing if any one ells has had this porb with there hj60
anyway my prob is that if I'm going up a hill in 2ed gear and on boost at 2600-2700RPM and go to hit the clutch it cuts out but will start fine right after it as if nothing happened
nat
1981 FJ60 SPOA 35's radial claws locker to come one day
http://www.4wdaction.com.au/shed/index.php?id=4357&im=1
bigluxs is offline   Reply With Quote
Old 07-29-08, 04:44 PM   #2
Tapage's Avatar
nat
It cuts .. mmm I'm not clear on that .. fuel cut . ? EDIC related . ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-29-08, 05:35 PM   #3
Diesel for blood
roscoFJ73's Avatar
nat
Needs more explaining,especaily the bit about the clutch.
Why would you use the clutch charging up a hill ,in 2nd, at 2700 rpm?
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 07-29-08, 06:01 PM   #4
Tapage's Avatar
In a re-think .. if we are talking about a 2H .. maybe your butterfly it's cuting your boost and this pressure it's back to your turbo, almost stop it from continue spining so your rpm are droping big time ?
I remember have some turbo spike big time and this issue drive me to installa a BOV that allow the turbo spin better between shifts ..
Old 07-29-08, 06:02 PM   #5
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
better explanation needed for sure. Do you mean your engine shuts off completely then you have to re-start it?
-91 FJ80, wife's ride
Old 07-29-08, 08:33 PM   #6
oops...sorry guys my bad...when it is on boost (driving) and if your reving it more then normal and put your foot on the clutch to change gears from second to third the engine shuts off completely........
Old 07-30-08, 04:18 AM   #7
Diesel for blood
roscoFJ73's Avatar
Is there something touching the edic or some bad wiring in that area? Its weird it only happens shifting 2nd to 3rd.
33 in BFG A/T
Volvo 740 GL
Old 07-30-08, 04:56 AM   #8
it only happens after been on top end boost in any gear if you drive in normally reving it to 2000-2500 RPM the engine will not stop just anything over 2600RPM
Old 07-30-08, 08:43 AM   #9
Tapage's Avatar
Interesting .. it happens if you rev it up to this range in N .. ? jusnt to see if something ( like a hose ) it's sucking or so .. The EDIC as Rosco said should be another option .. easy to know disconecting it and taking a test run.
Old 07-30-08, 09:33 AM   #10
BJ addict
eleblanc's Avatar
TLCA# 16338
Could it be low oil pressure and the oil pressure switch shut it down?
1983 BJ42LV
3B turbo diesel, 5 speed, power steering
24V Viair 450C, ARB locker front/rear, OME Heavy
4.56 R&P, BF Mud 255/85 (34")
Warn M12000 24Volt
http://www.ericleblanc.com/gallery/m...p?g2_itemId=20
eleblanc is offline   Reply With Quote
Old 07-30-08, 12:38 PM   #11
Tapage's Avatar
Could be .. in all cases a simple test without the EDIC conected solve the clue ..
Old 07-30-08, 06:18 PM   #12
maybe this is the EDIC doing this
YouTube - cold start with a shit injector pump
Old 07-30-08, 07:11 PM   #13
Diesel for blood
roscoFJ73's Avatar
That didnt sound like a bad pump or an EDIC to me. If it was a bad pump or an EDIC not working right the problem would likely be there all day.
More like a bad glow plug and/or some air in the line.
Or worse ,low compression on one cyl.
Your other problem at boost could be the low oil cut off as someone suggested
33 in BFG A/T
Volvo 740 GL
Old 07-31-08, 02:51 PM   #14
Tapage's Avatar
Not .. EDIC are definately not that fast .. I bet
1. Air in the line,
2. Diying plunger at IP ..
Debt Consolidation | Mortgage Calculator | Enertia electric motorcycle | Refinance | Secured Loans
