Old 07-28-08, 12:50 AM   #1
Fj 60 fuel tank vs BJ60 fuel tank
what need s to be modified on ex FJ60 fuel tank/ fuel line and or all related fuel delivery emissions BS that came with stock 2F (California) to run a 3B diesel.
any photos one which line is the inlet line fuel since my 3B does not have a return line.
FJn00b is offline   Reply With Quote
Old 07-28-08, 01:24 AM   #2
crushers's Avatar
use the same tank, block off the lines you do nto need.
your fuel line is the same one the gass fuel pump was hooked to
Wayne in Ontario
Old 07-28-08, 08:13 AM   #3
AGreekBoy's Avatar
TLCA# 18699
crushers, does the diesel tank not need all the vent lines that the gas one has? just asking because i am doing a swap into my 60 as well
AGreekBoy is offline   Reply With Quote
Old 07-28-08, 12:16 PM   #4
mel lowe's Avatar
my 81 bj6o came with
"all the vent lines" and no fuel return line
"if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64
mel lowe is offline   Reply With Quote
Old 07-28-08, 12:16 PM   #5
crushers's Avatar
there is no return line on a 3B, the 13BT does as well as all rotory pumps (Toyota)
you will need a vent so eitehr a venting gas cap or a vent line.
someone correct me if i am wrong...
Wayne in Ontario
Old 07-28-08, 04:35 PM   #6
Do you need to add an electric fuel pump or the 3B prim fuel pump on the injectore pump can suck fuel from the tank. Also does anyone have a picture of which line on the FJ is the fuel inlet and which one is the return ?
I think mine is mixed and can not tell which is what.
Old 07-28-08, 05:18 PM   #7
crushers's Avatar
no elec needed but it does make the priming easier...
Wayne in Ontario
Old 07-28-08, 06:39 PM   #8
Diesel for blood
roscoFJ73's Avatar
The gassers,by law,had to vent though the charcoal canisters and then had another line running from the canister into the front RH rail to allow any other vapours to dissipitate.
However all the fuel caps on the 70 and 60 cruisers I have seen have a one way vent in the fuel cap to allow for expansion.
On my 1HZ ,I blocked off the vent and just have 2 lines . One for fuel supply and one for fuel return as the 1HZ returns its fuel to the tank,unlike the 3B
You could use the old vent line as a back up by adding a valve like the diff breather and elevating it to the height of the air filter.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 07-29-08, 02:31 AM   #9
IH8HILLS
Granite Grinder's Avatar
TLCA# 1539
Is it normal to hear air escape/ get sucked in (not sure which) I believe it's sucking, when you open the fuel fill cap? Pretty much a stock HJ60 (CDN spec).
GG
1977 - FJ40-V8-SM420-ARB's,SOA (Ducky)
1987 - HJ60-OME,Turbo'd,4.56 (Silver)
1987 - HJ60-Work in progress (Clementine)
1985 - BJ60-3B-Belton lift (FunOne)- 2008 RIP
Granite Grinder is offline   Reply With Quote
Old 07-29-08, 04:35 AM   #10
Diesel for blood
roscoFJ73's Avatar
GG
Neither of my diesels do it. I used to have a petrol toyota truck and it would build up a lot of pressure in the heat. I was never sure if it was normal or not
33 in BFG A/T
Volvo 740 GL
Old 07-29-08, 05:19 AM   #11
crushers's Avatar
i have had the gassers and the odd diesel do this on a hot day...
Wayne in Ontario
Old 07-29-08, 08:05 PM   #12
mel lowe's Avatar
the oem 3b pump is up to the task....
no second pump required
Old 07-29-08, 08:13 PM   #13
amaurer's Avatar
my 3B sucks a little air whenever i open the cap.
"... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908
1982 BJ42 "Krull"
amaurer is online now   Reply With Quote
Old 07-30-08, 12:12 AM   #14
Diesel for blood
roscoFJ73's Avatar
I should have mentioned Im using one of these aftermarket lockable type caps . It has a one valve that allows air in to avoid vacuum problems.
Im not sure how it avoids pressure build up. Maybe the cap isnt tight enough or that white valve on the fuel lines allows it to let expanded gas out
No problems in 5 years and plenty use them here
33 in BFG A/T
Volvo 740 GL
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/233081-fj-60-fuel-tank-vs-bj60-fuel-tank.html
Posted By For Type Date
FJ - forum post summary | BoardReader This thread Refback 07-29-08 04:51 PM
Loans | Credit Cards | Credit Counseling | Online Loans | Final Fantasy Ringtones
