LinkBack (1) | Thread Tools | Display Modes |
#31 | |
Diesel for blood
From memory ,the transfer case with the vac shifter has some extra wiring to activate 4WD if you shift into low range manually. On the manual shift t/case it you have to shift into 4WD before you can shift into low range. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL Last edited by roscoFJ73; 08-03-08 at 05:56 PM. |
#32 |
i bought the vsv switch for the transfer case and the interior switch anything else needed.?
#33 | |
Drinking the Kool-aid
![]() The reservoir (not OEM) says Power Steering fluid, but that's not right. Search for the board's rec's. ![]() BTW - the PS lines run between the frame and the radiator. It's a PITA to bolt down when the radiator's in place... __________________ '88 FJ62 - 12HT conversion, OME Lift, ARB front bumper, Roof Rack '04 Prius - stock '66 Pearson Commander - a hole in the water to throw money into. __________________________________________________ ________________________________________ And we are here as on a darkling plain Swept with confused alarms of struggle and flight, Where ignorant armies clash by night. |
#34 |
Creeker, do you have a gas engine or a diesel?
#35 |
![]() I have a 12HT dropped into an FJ62. I didn't do the work myself, but have had to do some wrenching on it so I'm slowly learning whats what. I have a couple of diesel issues I'm trying to resolve:
#36 |
i converted my fj40 with a 3b, used the gas wiring harness and my oil pressure reads low to. i know that the oil pressure is lower in the deisel than the gas and think that the gauge from the gas wiring reads incorectly because my motor is fine.
#37 |
Creeker are you running an electric fan? if so what kind did you use?
#38 |
I thought this might be the problem. I need to check the pressure per the manual, and change out the guage if needed. My concern is that even if the gauge isn't calibrated, the pressure starts high then drops after the engine warms up. I don't know if that's normal.
#39 |
Yes. I'll check tonight if I get a chance and take some pics.
#40 | |
The 12H-T as same as the 1HD-T engine need ( by Max Ellery manual ) at least 4.3 PSI at idle .. ( 650 rpm ) and 36 PSI or more @ 3000 rpm .. all measurement sure @ normal operative temp. |
#41 | |
So should I check the oil seals in the turbo? I don't suppose there's an easy way to do that... __________________ '88 FJ62 - 12HT conversion, OME Lift, ARB front bumper, Roof Rack '04 Prius - stock '66 Pearson Commander - a hole in the water to throw money into. __________________________________________________ ________________________________________ And we are here as on a darkling plain Swept with confused alarms of struggle and flight, Where ignorant armies clash by night. |
#42 | |
I don't think the turbo oil seals are related with the low oil press .. that it's more internal, BEB's oil pump, oil seal front cover etc .. |
#43 | |
#44 |
can i reuse my stock gas fuel lines or do they need to be bigger?
#45 | |
You can see in my sign both threads .. |
#46 | |
Diesel for blood
Snap On make a nice but they are a $140 or so. If your prepared to spend money ,you might as well get a full time oil mechanical pressure gauge fitted __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#47 |
just got my parts together and have one question. would a compressor of an 89 62 bolt to the 12ht?
#48 |
its too bad the air box is on the other side, seems stupid to have two crossover pipes going across the engine head, anyone think it might get heat soaked.
#49 |
you can route the lines anywhere you want i was just wondering if the compressor will bolt up
#50 |
ok guys started my conversion it is in the 60 section. looking forward to hear from anyone who has done this or has a 12ht. thanks
#51 |
A couple notes:
There is a A/C idle boost solenoid that is 24V and must be replaced. I haven't done it yet. If you don't then the engine either lugs at idle or you have to increase the idle too high to compensate for the A/C use. I am using used 12V vacuum switches from salvaged 2F smog equipment for my cut-off and it works perfectly and it was FREE! I could have also used industrial Parker switch valves as they are industrial quality, but expensive. __________________ N6LG - Extra Class Amateur Radio Operator 1982 FJ40 (HJ41), 12HT turbo diesel, H55, ARB locker, e-locker, Marks Gears, APRS 1997 LX450, 1HT-FT/H151 diesel conversion in process... 1972 FJ40 Fun Beater Rig, Bone Stock! |
#52 | |
12h-T & the 2H get low oil pressure if you use to modern oils. Use a old fashion mineral oil 20w x50w with low detergent as the diesel fuel is low sulpher now anyway. These motors cannot handle oils that become to thin. When you first start up the motor the oil pressure is high and as it becomes hot you notice the oil pressure drops of to nearly nothing. Use oil that is suited for pre 1990 diesel motors. The handbook even mentions low oil presssure results from using the wrong oil. __________________ Rebuild 1974 FJ40 2F into a 1984 HJ43 2H Diesel. http://forum.ih8mud.com/40-55-series-tech/173333-rebuild-my-fj40-1974-rhd-down-under.html |
#53 |
Panoramic good info thanks
Wartrob ill look at the manual as far for the oil good tip though |
#54 |
does anyone know where i can pickup a manual for the 12ht? i have the toyota repair manual, but need one for wiring diagram and vacumm line diagram. i found a diagram for vacumm here on mud but it just gives you part #s.
#55 |
12HT wiring and vacuum diagrams
I have been looking for the wiring & vacuum diagrams for 2 years now. If you come across something PLEASE let me know!
I would think that there is an engine supplement for the HJ61 or 75-series or a coaster bus? Perhaps Roscoe knows? Fwiw: there are some incomplete diagrams for the Alternator (24/12 & internal/external regulator) and I have pieced together what I feel is the full wiring for my 12V-internal reg. but I have not had a chance to scan the greasy picture pasted to my garage wall yet... __________________ N6LG - Extra Class Amateur Radio Operator 1982 FJ40 (HJ41), 12HT turbo diesel, H55, ARB locker, e-locker, Marks Gears, APRS 1997 LX450, 1HT-FT/H151 diesel conversion in process... 1972 FJ40 Fun Beater Rig, Bone Stock! |
#56 |
here is something that might help you
http://forum.ih8mud.com/attachment.p...1&d=1219440512 this is all that i could find hope you get more out of it than i do |
#57 | |
Rob,
can you be more specific with the oil type? Perhaps an example of a type from Mobil-1 (they sell down there too, right?)? Fwiw: For lack of knowledge, I have been using Delo-400 as that is commonly available at the truck stops here when I have been traveling. - Eric Quote:
#58 |
I use 15W-40 Castrol CRB down here .. swtich to 20W-50 in the summer .. but here we pretty hot usually.
