Old 07-22-08, 03:11 PM   #1
lshobie's Avatar
1HZ engine noise, harmonic balancer, delamination
Hi guys,
I was a little worried that my engine was packing it in, I had a hollow knocking sound for the last couple of days and when I started it this morning it was making a nasty bearing/grinding sound. So, I spent most of the day taking the oil pan off, valve cover off, timing cover off, looking around, trying to see and hear where the problem was coming from - turns out it was the pully behind the harmonic balancer that the alt and AC belts are driven by.
The pully is not just a solid piece of steel, there is a steel part that the crank bolt goes through - then a rubber band, then the stell grooved part that the belts ride on. I guess the rubber section is used as a damper for loads. As it turns out the outer steel section delaminated from the rubber and was just slipping around on there.
229 bucks from ENS and I should be on the road tomorrow.
I'll post pics tomorrow when I get it off so you can see how it is put together.
Louis
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 07-22-08, 05:31 PM   #2
Tapage's Avatar
It cost me around 300 USD here in Panamá year or more ago .. Easy replace ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-22-08, 05:49 PM   #3
lshobie's Avatar
How did you get the crank bolt off??? It is on there really tight!
Louis
Old 07-22-08, 06:53 PM   #4
rstl99's Avatar
WHen I once replaced a timing belt on a Land Rover 2.5 N/A engine (which required removing the crank bolt), the general advice was to use the 3/4 handle and socket on the crank bolt, rest the handle against the frame, and flip the starter to loosen the bolt. Or use the old approach of removing the starter and jamming a large screwdriver into the flywheel gears. After trying the latter rather unsuccessfully (I found the former a bit risky), I went with a lower tech approach: take the pan out, jam a piece of 2x4 between a crank journal and the side of the cast block, and get a long piece of pipe on the end of the 3/4 extension to crack loose the bolt. Used the same approach to torque the bolt back on (no torque wrench, getting the sucker as tight as I felt necessary).
Thanks for letting us know about this issue with the 1HZ.
Current rig(s):
1992 HZJ80 LHD 215Kms
SOLD: 1982 BJ60 3B H42 230Kms and counting
Still planning an expedition...
rstl99 is offline   Reply With Quote
Old 07-22-08, 07:25 PM   #5
Diesel for blood
roscoFJ73's Avatar
I made up a spanner that fits the balancer and used the bolts that connect the pulley and balancer,otherwise ,use the starter motor.
I used the spanner because the engine was out.
You can also use the weight of the vehicle by fitting a spanner to the nut and lowering the vehicle.
I found the injection pump shaft nut ,far far harder
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
roscoFJ73 is online now   Reply With Quote
Old 07-22-08, 08:14 PM   #6
lshobie's Avatar
I had tried the starter method earlier today and broke 2 breaker bars, I'll build the spanner tool tomorrow.
Thanks guys!
Louis
Old 07-22-08, 08:26 PM   #7
Diesel for blood
roscoFJ73's Avatar
Thanks guys!
Make the spanner a bit stiffer than mine as mine is a bit flexi
33 in BFG A/T
Volvo 740 GL
Old 07-22-08, 09:04 PM   #8
lshobie's Avatar
OK will do - thanks.
Louis
Old 07-22-08, 09:10 PM   #9
mac
rust and moth consumables
mac's Avatar
I have one of those sitting on my shelf- from Rosco! Decent price from Ens tho'. Getting the proper torque on it when replacing it is really the challenge- unless you have a torque wrench that does something like 750ft/lbs. I used a 4'bar and calculated the force req'd to achieve the proper spec. I then used a weigh scale to get the torque right.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 07-22-08, 09:14 PM   #10
Diesel for blood
roscoFJ73's Avatar
Thanks guys!
Im just thinking this is not going to work for you. If your engine is still in the vehicle it sbould be easy to stop the engine rotating by putting it ih high gear with the handbrake on.
I built my spanner because the engine was out and it was spinning.
Im thinking you will need one of those impact shifters that you hit with a 10lb hammer
33 in BFG A/T
Volvo 740 GL
Old 07-23-08, 04:00 AM   #11
matt 105's Avatar
I had tried the starter method earlier today and broke 2 breaker bars, .......
Sure your going the right direction?
Ive never had a problem (getting the ballancer of a cruiser)and always use the starter method.
On some other engines, I haver used an old bearing shell in the flywheel teeth.
Matt
a white Landcruiser - now with Track Tactical!
matt 105 is offline   Reply With Quote
Old 07-23-08, 05:09 AM   #12
crushers's Avatar
Louis, go buy a 3/4" set from Princess Lotto... you will never regret the purchase.
most of the sockets are used for installing seals, the breaker bar is STRONG and the proper sized nut is there for removing the crank nut...
$80
Wayne in Ontario
Old 07-23-08, 09:51 AM   #13
lshobie's Avatar
Thanks Wayne, picked up the breaker bar set - put the socket on and rested the bar on a 2x4 on the ground - turned it over and it came right off very easily. That is one big toyota bolt!
The pulley came off easily with a puller, the part should be in today so the install will be easy. Not sure how I will torque it to 750 pounds or whatever it is - will probably just make a spanner tool and pull maybe a tenth of my manly power - don't want to snap that little bolt
Thanks guys!
Louis
Old 07-23-08, 10:44 AM   #14
Tapage's Avatar
I need to remove the rad and the hole front grill to remove mine .. use some locktight to secure it ..
loctite 243. threadlocker. Super nut lock. Pt. # 21321 - eBay Plumbing, Building Materials, Hardware, Construction, Business, Industrial. (end time 24-Jul-08 13:36:53 AEST)
Old 07-23-08, 01:18 PM   #15
crushers's Avatar
jamb the bar under the frame, put the tranny in first and roll the truck the direction you want the bolt to go...
or do as i do, get a 5 foot snipe and secure tightly...
Wayne in Ontario
Old 07-23-08, 01:26 PM   #16
lshobie's Avatar
Awsome, will do that today or tomorrow.
Thanks guys.
Louis
Old 07-23-08, 02:10 PM   #17
mac
mac's Avatar
What is your impact gun rated for? If it's a good gun it will be rated for a high torque setting. A little loctite and a good hammering with the impact(assuming it's not a 1000ft/lb gun) and you should be good to go.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 07-23-08, 06:33 PM   #18
lshobie's Avatar
All done, didnt need an impact gun - did it all without taking the rad out. Used a big homemade spanner and a 4 foot breaker bar, thread locker - it is very tight now.
Thanks guys.
Louis
Old 07-24-08, 12:29 AM   #19
mac
mac's Avatar
Good on ya. Actually by not using an impact you created a lot more room for yourself. With a 4' bar you need something like 110lbs of force to get to the spec.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/232225-1hz-engine-noise-harmonic-balancer-delamination.html
Posted By For Type Date
(4 Viewing) on IH8MUD.com Forum - The Truth is in the Rocks - Powered by vBulletin | BoardReader This thread Refback 07-24-08 01:50 AM
Charity | Watch One Piece | Mortgage | Cell Phones | The eBay Song
