Old 07-21-08, 09:12 PM   #1
Battery
Hi
BJ73 with 24 Volt system would not start in the weekend. I towed it to start and was ok for the rest of the Weekeend.
I took it to the Battery place on Monday and they replaced 1 battery saying it was stuffed. I had installed 2 new 13 plate batterys 15 months ago.
My question is should I go and buy a matching battery or just live with what I have?
I do us the truck in a 4X4 club and we have a alpine trip this weekend and I will be camping in the snow.
cantabkiwi is offline   Reply With Quote
Old 07-21-08, 09:47 PM   #2
Search 24v. tons of info.
But:
1) You need to replace both... after you check for any 12v taps off of the low side battery. Any 12V taps will burn one battery and undercharge the second. Bad news.
2) You need to buy both because a clean system (no taps) will still do the above if the batteries are different. Best methodology is to replace both with the same brand and type of battery. Stick to the same manufactureing month if you can. Yes they can be that finicky.
Good luck.
Kraig
1981 JDM BJ44 RHD - Going under the knife soon!
BreckenridgeCruiser is offline   Reply With Quote
Old 07-21-08, 10:19 PM   #3
Japan4X4's Avatar
Also rotating the batteries every now and then does not hurt.
Importer and distributor
Japan4X4 is offline   Reply With Quote
Old 07-22-08, 03:24 AM   #4
Ron R's Avatar
But:
Good luck.
Kraig
Yes I second that fully, but want to add a remark.
When you get the new (second one) battery, get the other new one out of the rig as well.
Connect them in parallel !!!!!!! (pluspost to pluspost - minuspost to minuspost) AND immediately charge them with a good 12V battery-charger. If it's an automatic charger, wait until the charging process stops. If it's not an automatic charger, wait untill the current has dropped to say 1 Amp or so.
Only by doing so, you will have two batteries that are in the same charging condition and will have the most out of them.
As said by others: search the forum. Tons of info.
And DO NOT connect 12V equipment to ONE of the batteries even if the needed power is minute.
Or has this been said before ? Really don't do that!!!!
Ron R
1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks.
http://www.ourwebspot.nl/English_index.html
Ron R is offline   Reply With Quote
Old 07-22-08, 05:02 AM   #5
crushers's Avatar
what drain do you have pulling off that battery?
Wayne in Ontario
Old 07-22-08, 06:43 PM   #6
Hi
Thanks for the Advice. I have spend $200 on the second battery. I only take 24 volts off both batterys. I do have a couple of 24 to 12 volt converts.
When connecting up the new battery I did hear the Glow plug relay click and there was a small spark. Is this normal?
Old 07-22-08, 08:30 PM   #7
Diesel for blood
roscoFJ73's Avatar
Originally Posted by cantabkiwi View Post
Hi
Where was the spark? Regardless ,sparks are bad news unless you have spark plugs
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
roscoFJ73 is online now   Reply With Quote
Mortgage | Credit Cards | Health Insurance | Personal Finance | Credit Card
