Adding mechanical oil pressure guage to 1HZ
My "poverty pack" 80 has spartan instrumentation, including a dummy indicator light for oil pressure. I'd like to install a mechanical oil pressure guage, and bought an affordable kit from the autoparts store which comes with 1/4 and 1/8" NPT adapters. Could someone please tell me what type of thread is on the stock sender screwed into the block, so that I can get a suitable T adapter to allow both the dummy light and the mechanical guage to function?
Thanks! __________________ Current rig(s): 1992 HZJ80 LHD 215Kms SOLD: 1982 BJ60 3B H42 230Kms and counting Still planning an expedition... |
its a standard 1/8thnpt 27 or whatever that is. You can buy a brass "T" and use the new one and the old one as well. Thats what I have on mine.
__________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
Thanks Louis. Sounds like a simple installation indeed. I certainly would feel more comfortable driving with an indication of the oil pressure! with that and the "tinytach" and the "engine watchdog" temperature sensor, I'll have more dials to look at while driving, anyway!
cheers.
If you bought a guage and it has the plastic hose - buy the copper hose instead - and make sure it is tight - ask me why
Yep, can second that advice. The 1HZ in standard trim is quite bullet proof, sometime the simple accessories we add like a plastic oil line can change that. It is why manufacturers moved to electric senders as even copper lines can break if they vibrate too much. Make sure you coil the copper line, better still is an electric sender unit and gauge, IMHO
Jon West Aus 105 with 1HDT and other bits |
Hmmm, you guys have a point there. I recall installing a similar pressure guage YEARS ago on a Camaro I used to own. I used the one with the plastic tubing and didnt' have a problem, but I could now envision that line melting/rupturing with ensuing oil leak, possibly inside the cab. I think the advice to go with an electric sender and guage is a good one, so I'll buy one of those and install it! THanks!
I just threaded the copper tube through a rubber windshield washer line.
i do not recommend running a mech feed into the cab period...
but if you do then make sure there is nothing around it the reacts negative to oil being leaked on it... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
I thought the point of installing a mech. gauge was the higher level of accuracy. Is there a way to install one but then have the information sent via some sort of electrical sender?(I realize that last sentence doesn't make a ton of sense)
I guess the jist of my question is how do you use a mech gauge without running it into the cab? Tim __________________ 85 FJ60 powered by a 3B(dreaming and planning for turbo) Daily driver |
#10 |
see that is the problem, you want the accuracy of the mech gauge without the possibility of leakage...
Louis is right, the copper line is much better than the plastic and a rubber grommet for where it passes through the firewall. on the Mits J54,J53 they use this method from the factory with lots of metal retainers to keep the copper line from moving at all inside the cab area. i have found the aftermarket elec gauges to work as good as the mech hence the change to my gauge applications. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#11 | |
#12 | |
Ok....I get it....yes, I am a little slow sometimes.
Well as I am leaving for a 2700 mile cross country move Thursday morning I will have to keep my mech. one for now....crossing my fingers. Thanks for the info. Tim Quote:
#13 |
just finished a move like that from west to east...PITA, never again.
best of luck and heres to a safe drive __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
Mortgage Loans | Loan | Loans | Go ACC | Internet Advertising |
