Old 07-18-08, 12:36 AM   #1
Rear wiper control
The rear wiper runs continuously in both the continuous and intermittent positions of the rocker switch. The wiper will not park to the down position when switched off.
What component is likely malfunctioning?
thx,
MJ
John Galt is online now   Reply With Quote
Old 07-18-08, 06:26 AM   #2
Squash's Avatar
Could be something to ground in the rear door. Road salt and water do funny things...if corrosion is the culprit you may as well service the motor at this time by opening it up to clean and grease.
You could open up the back and verify that your wiper motor wiring is good then start tracing back towards the switch. Best to unplug the connections and test with power.
Let me know by PM if you find a defective switch as I could send you one.
Mike
93 FZJ80 De-flared, de-bumpered and Aussied DD.
HZJ79L 5speed diesel LSD for work, traded for a Brand new HZJ79L...
Squash is offline   Reply With Quote
Old 07-18-08, 02:47 PM   #3
Eric Winkworth's Avatar
there is an intermitant part of the switch? I didn't know that....
1986 BJ70, 24v with a 3B
Eric Winkworth is offline   Reply With Quote
Old 07-22-08, 03:20 PM   #4
Frode S's Avatar
x2. mine has these positions from "top to bottom" on the rocker: spring loaded washer-on (continuus)-off-spring loaded on.
Frode S, member of the Monkey Hand Club and The Friends of The PX10, frequenter of the Scumm Bar.
Frode S is offline   Reply With Quote
Myspace Proxy | Find a Better Job | Loans | Gas Suppliers | Loans
