Old 07-13-08, 12:57 PM   #1
Pyro going weird
I have a ISSPRO Pyro in my 3B and it's been fine for almost 2 years now but I was driving it last week, the pyro readings were all over the scale. It would just drop down to 300, as soon I as I pressed the accelerator, it was fly all the way up to 700 but then flutter from 500 to 900 and back down to 300.
Mind you, the entire time, I'm on the highway doing light acceleration, I'm sure I'm not overfueling or anything.
is it a connection problem or has the pyro bit the dust?
Lantec is offline   Reply With Quote
Old 07-13-08, 02:11 PM   #2
BJ addict
eleblanc's Avatar
TLCA# 16338
Check the engine ground.
1983 BJ42LV
3B turbo diesel, 5 speed, power steering
24V Viair 450C, ARB locker front/rear, OME Heavy
4.56 R&P, BF Mud 255/85 (34")
Warn M12000 24Volt
http://www.ericleblanc.com/gallery/m...p?g2_itemId=20
eleblanc is offline   Reply With Quote
Old 07-13-08, 06:18 PM   #3
Check all the connections. These things run on millivolts so it takes nothing to upset them.
Old 07-13-08, 06:36 PM   #4
make sure the wire sheathing hasnt worn off and is shorting somewere on a metal part
Big Blue 84BJ60 is offline   Reply With Quote
Old 07-13-08, 10:25 PM   #5
UpsideDown's Avatar
note that the thermocouple/sensor do require replacement from time to time.
1978 FJ40 - parts vehicle - PM me
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
UpsideDown is offline   Reply With Quote
Old 07-13-08, 10:48 PM   #6
thanks, I'll check the wires underneath and see what happens
Old 07-14-08, 04:46 PM   #7
lowenbrau's Avatar
TLCA# 5513
24 volt truck? Solar converter feeding the gauge?
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 07-14-08, 05:35 PM   #8
Tapage's Avatar
did you use the head shield wire .?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-14-08, 11:16 PM   #9
nope. it has a turbo so it's attached to the manifold pre-turbo
Old 07-15-08, 01:27 AM   #10
83bj60's Avatar
don't forget these meters usually have electronic components (zener diode, reference thermistor and an amplifier/comparator circuit). It's usually not just a simple millivoltmeter.
But agreed, first check the simple things. Make some tests with a simple k type thermocouple with a propane soldering gun. If it goes all over the place again, it's the meter itself, otherwise it's the sender.
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
83bj60 is online now   Reply With Quote
Old 07-23-08, 05:10 PM   #11
Are you still having the problem? Were the conditions such that you would not have been over 900° normally? If so, then I suspect either bad connections to the amplifier box, or internal failure of the amp box.
Regards,
Michael Pliska
ISSPRO Engineering Manager
MichaelP is offline   Reply With Quote
Old 07-23-08, 05:40 PM   #12
Tapage's Avatar
Wou Michael .. nice to have a ISSPRO pro here .. !
I have a complete set off ISSPRO gauges in my Cruiser .. ( oil press / boost / pyro / trans temp ) and have a question about the oil press gauge .. but there comes in another thread.
Old 07-23-08, 07:42 PM   #13
seapotato's Avatar
TLCA# Reset to Zero....
I had an autometer pyro do this. thing just went crazy needle bouncing around all over the place. was the ground wire on the back of the pyro.
vibrated loose. was fine after.
cheers,
ryan
I disagree.
87BJ70 BJ109/55. Bluefish & Grover.
seapotato is offline   Reply With Quote
Old 07-24-08, 07:01 PM   #14
A simple thing to remember when diagnosing pyrometer problems is that the gauge is basically a really sensitive voltmeter, and the sensor (thermocouple) generates a very small voltage in proportion to the temperature difference between the "hot end" in the exhaust and the "cool end" at the gauge. Bad connections between the thermocouple, leadwire, and the gauge can lead to readings which are intermittently below the expected reading. However, you typically won't see a value ABOVE the expected reading (even intermittently) unless your gauge or amplifier box is bad.
Regards,
Michael Pliska
MPAA | Property for sale in Spain | Electricity Suppliers | Buy Shares | Loans
