Old 07-06-08, 09:18 AM   #1
will BJ60 or hj60 fan clutch fit BJ70?
I'd like to replace the fixed (solid) fan coupler with an o.e.m. fan clutch but can't seem to source one for a bj70. But I can source them for 60's, both bj and hj. Does anyone know if it will fit? I'm thinking they will but would like to confirm this. Part # would be a big help also.
JonB ke6gfb
87 bj70, arb'ed, slidered, winched, 4x4llabs bumper.
97 40th fzj80 w/difflocks, cdl switch & pin 7 mod, Hanna sliders, 2.5" ome lift, 1" body lift, rear drawer system on 285/75-16's.
87 sas 4runner- air lockers, dual cases, beadlocked 35" mtr's, waggy & cheby springs, sliders, 8274 winch, etc...
jonb96150 is offline   Reply With Quote
Old 07-06-08, 11:10 AM   #2
David*BJ70's Avatar
TLCA# 15514
yes. 60 and 70 (3B engine) will fit.
BJ42 1982 * The Primitive Beast
BJ70 1985 * The Green Machine
1992*Corolla*All-trac* The Quiet Spirit
Si je dois aller en enfer... ce sera en Landcruiser
(Canadian french guy (Québécois)... sorry for my english ! ) http://forum.ih8mud.com/showpost.php...79&postcount=2
David*BJ70 is offline   Reply With Quote
Old 07-06-08, 09:14 PM   #3
wesintl's Avatar
TLCA# 4180
all of the 4 bolts that the fan clutch use to mount to the pulley fit. The 60 fan clutch won't allow the 70 plastic fan to mount on it. I guess you can buy the 60 plastic fan too. One of the things I haven't done yet is to find out the diameter of the 60 fan to make sure it fits the 70 shroud.
I do know that the mid 80's pickup plastic fan is the same as the 70 series. part # crosses over. so you could run a mid 80's pickup fan clutch and it would bolt up. I dunno if it engages differently from the 70 fan since it's a different # but it can't be that far off.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
You should be able to delete your own thread. Communists abound
wesintl is offline   Reply With Quote
Old 07-07-08, 02:31 PM   #4
Thanks for the replies.
I talked to Dan at 4wheelauto.com in Edmonton and he's sending out a water pump and a fan clutch (viscous coupling). He was very patient, and thinks my fan will bolt up to the new fan clutch.
My current fan mount is a viscous coupling modified to be solid by being drilled and through bolted so I don't think I can just add the fluid back to it.
Thanks again.
JonB ke6gfb
Mobile Phone | Loans | Myspace Layouts | Make Money Taking Surveys | Loans
