Old 07-05-08, 06:40 PM   #1
amaurer's Avatar
Red face Valve cover cracked
My valve cover cracked while I was torquing it down. I set the wrench to 9ftlbs, but I didn't do a very good job of torquing a bit at a time in sequence, i guess. Whats the best way to torque the cover?
Also, anyone have a spare cover? My crack extends between the middle two bolts on the top of the cover, through the ribs in that area. I snugged it up as best I could without making it worse, but I suspect it needs replacing.
"... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908
1982 BJ42 "Krull"
amaurer is offline   Reply With Quote
Old 07-05-08, 07:22 PM   #2
Joe Egolf's Avatar
rocker cover
It is alumunum isn't it?? Maybe it can be magna fluxed or even JB welded??
1981 BJ42
Joe Egolf is offline   Reply With Quote
Old 07-05-08, 07:36 PM   #3
amaurer's Avatar
I'm not so worried about it leaking from the cracks (which I could use JB weld to stop if it does), but if I torque the center bolts to spec I can hear the crack widening... I don't know if I have sufficient pressure on the gasket now.
1982 BJ42 "Krull"
Old 07-05-08, 07:46 PM   #4
Joe Egolf's Avatar
Hmmm
A Hah The catch 22,Maybe you could have welding shop magna flux or heli arc and beef up the inside of the cover/crack, even add a strip of aluminum inside? I forget which or what they use on alumunum?
1981 BJ42
Old 07-05-08, 09:54 PM   #5
Joe Egolf's Avatar
rocker cover
Saw one used in Canada in classifieds here from
cruiser_guy
1981 BJ42
Mortgage Calculator | Credit Counseling | Personal Car Finance | Remortgages | Mortgages
