Old 06-26-08, 01:36 PM   #1
24 volt system
Is it possible to use a 12 volt alternator on a 24 volt system?
buffel is offline   Reply With Quote
Old 06-26-08, 03:47 PM   #2
If you install it as an auxiliary/second alternator for a separate 12v system to run all your 12v accessories then yes.
'92 HZJ73
Locked,
Safari Turbo,
3" stainless exhaust
Spddude is offline   Reply With Quote
Old 06-26-08, 03:58 PM   #3
rchalmers3's Avatar
X2 plus the 12v alternator will not have sufficient capacity to charge a 24v battery bank.
Rick
rchalmers3 is offline   Reply With Quote
Old 06-26-08, 11:01 PM   #4
Will it burn out the 12 volt alternator if I connect it to a 24 volt system?
There are a couple of wiring issues with this vehicle which may have been converted from 12 volt to 24 volt in the past. My alternator has burned out and when I took it in for repairs two shops have told me that it is a 12 volt alternator as they can check from the windings.
They said this even though the brush holder says 24 volt. I put a 12 volt alternator and it isn't working, hence the qusetions.
Old 06-27-08, 12:31 AM   #5
Diesel for blood
roscoFJ73's Avatar
A good start would be to tell everyone what model it is and its counrty of origin
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 06-27-08, 06:59 PM   #6
Your Battery will charge the amount a volts your alternator will try. If you have 2 batterie for a 12v alternator. Your batterie will run at 6 volts each if no modification is done to you system. You can plug a 12 volt alternator.. but you will buy two new batterie in no long and you cannot start a 24volt starter with that. If you have only one batterie in your truck then you have a 12 volts system then no problème with a 12volts alternator. But if you run with the alternator that burn and you have 2 batteries... you have certainly a 24 volts alternator. Make it rebuild for 24 volts. Change the bearring and diode in the same tame... a little bit more but no probleme for 20 years after that.
Owner of a bj40 1979 with turbo B 3.0L engine
frame down and rebuild with pure american steel
Now hard enough for Quebec Winter
Wedg3 is offline   Reply With Quote
Advertising | Homeowner Loans | Dutch Bodybuilding Forums | Loans | Books
