Old 06-23-08, 08:13 PM   #1
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
2L Water Sensor
Where can I get a Water Sensor from?
1986 Nuclear Reactor
1985 Toyota LN65R
LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO!
Jonathan_Ferguson is online now   Reply With Quote
Old 06-23-08, 09:12 PM   #2
Diesel for blood
roscoFJ73's Avatar
Have you tried the wreckers for the bits you need?
Does the sensor look anything like the Landcruiser water sensor?
Otherwise,your probably better off ditching the toyota equipment and fitting something from Delphi/Racor/Cav with a built in water sensor
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 06-23-08, 10:35 PM   #3
Nah, I don't even try the Wreckers these days, too many bad experiences in the past.
I've never looked, and my BJ40 didn't have a Water separator at all.
Yeah, I probable am, but I've never had much luck at diesel part shopping locally.
I wonder if there is a standard plastic thread size with a diameter of 1.5"
1985 Toyota LN65R
Old 06-23-08, 10:43 PM   #4
Diesel for blood
roscoFJ73's Avatar
Keep up the optimistic outloook
33 in BFG A/T
Volvo 740 GL
Old 06-23-08, 11:20 PM   #5
The old one's thread is 1 1/8" which is too small.
The old one's float has a diameter of 2.5cm, which is too big.
1985 Toyota LN65R
Old 06-25-08, 03:28 AM   #6
After consulting with Al Gore, the Thread should be an M36x1.5 and the Parker Racor Cattledog makes mention that their products have an option to use a Water Sensor. But does Parker Racor produce a Water Sensor in M36x1.5
1985 Toyota LN65R
Old 07-07-08, 02:24 AM   #7
I think I've made some progress. I'm going to get an M36x1.5 Bolt then Drill and Tap it 1/2 UNF so I can use a Delphi Lucas Cav water sensor. - Is there an Internet source for one of these?
1985 Toyota LN65R
Old 07-07-08, 05:26 PM   #8
rchalmers3's Avatar
Hey, a used sensor from a local auto recycler will probably get you back on the road faster and cheaper. Isn't the 2L readily available in Vic???
Rick
rchalmers3 is offline   Reply With Quote
Old 07-07-08, 10:05 PM   #9
Rick
Junk yards don't play well with the Jonathan.
The Jonathan doesn't play well with Junk yards.
1985 Toyota LN65R
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/227798-2l-water-sensor.html
Posted By For Type Date
Horn Relay Wiring This thread Trackback 07-17-08 05:54 AM
Fuel Filter This thread Trackback 06-24-08 12:22 AM
Unsecured Loans | Personal Loans | TV News | Debt Help | Fast Loans
