LinkBack (2) | Thread Tools | Display Modes |
2L Water Sensor
__________________ 1986 Nuclear Reactor 1985 Toyota LN65R LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO! |
Diesel for blood
Have you tried the wreckers for the bits you need? Does the sensor look anything like the Landcruiser water sensor? Otherwise,your probably better off ditching the toyota equipment and fitting something from Delphi/Racor/Cav with a built in water sensor __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#3 | ||
Nah, I don't even try the Wreckers these days, too many bad experiences in the past.
I wonder if there is a standard plastic thread size with a diameter of 1.5"
#4 | |
Diesel for blood
The old one's thread is 1 1/8" which is too small.
The old one's float has a diameter of 2.5cm, which is too big.
__________________ 1986 Nuclear Reactor 1985 Toyota LN65R LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO! Last edited by Jonathan_Ferguson; 06-24-08 at 12:37 AM. |
After consulting with Al Gore, the Thread should be an M36x1.5 and the Parker Racor Cattledog makes mention that their products have an option to use a Water Sensor. But does Parker Racor produce a Water Sensor in M36x1.5
I think I've made some progress. I'm going to get an M36x1.5 Bolt then Drill and Tap it 1/2 UNF so I can use a Delphi Lucas Cav water sensor. - Is there an Internet source for one of these?
#8 | |
Rick |
#9 | |
The Jonathan doesn't play well with Junk yards. __________________ 1986 Nuclear Reactor 1985 Toyota LN65R LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO! |
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/227798-2l-water-sensor.html
| Horn Relay Wiring | This thread | Trackback | 07-17-08 06:54 AM | |
| Fuel Filter | This thread | Trackback | 06-24-08 01:22 AM | |
Advertising | Loans | Bad Credit Mortgages | Problem Mortgage | Loans |
