Injector pump fittings leaking
I've have a issue with my 87 HJ60 (2H engine) that happens every so often. I sometimes have a slight leak at the connection between the injector pump output fittings and the lines going to the injectors. It's just two that usually leak. It's the most rearward two pump outputs. Although the leak is very minor; just a slight dribble, it's still a leak. I've tried tightening the fitting. After tightening the leak goes away but returns out of the blue in a few weeks.
Any suggestions on why just these two injector outputs seem to leak and what I can do to fix this leak?
rust and moth consumables
There should be a clamp style bracket further up the lines that helps to keep them in place and absorb vibration. Check to see that it's tight.
__________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
#3 | |
Diesel for blood
Most diesel mechanics replace them every time Download the free 2H 12HT manual and go to pg FU36.There are torque specs to consider also __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Web Advertising | Kawasaki insurance | Internet Advertising | Car Credit | iKobo |
