Old 06-19-08, 09:25 PM   #1
12H-T question...
Anyone know if this engine uses cylinder sleeves?
Is a 12H-T rebuild particularly expensive? I would imagine that if the cylinders don't require boring (if it has sleeves) then perhaps not as much.
Thanks!
Time flies like an arrow. Fruit flies like a banana.
- Groucho Marx
hotrats is offline   Reply With Quote
Old 06-20-08, 12:52 AM   #2
mac
rust and moth consumables
mac's Avatar
12HT's aren't sleeved AFAIK but even if they were as the 3b is, there is still machining costs to factor in which can add up easily to 1000 or more. Add to that your parts cost and it will be a costly rebuild. On the positive side, you'll have a kickass engine that you can pass on to your kids.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 06-20-08, 12:52 AM   #3
Diesel for blood
roscoFJ73's Avatar
Thanks!
An engine rebuilder I have used a few times said the cost is not much different for sleeved/non sleeved.
The 12HT AFAIK is not sleeved
The 12HT kit is not substantially more than a 2H last time I looked.
EDIT $1275AUD
IMO you need to machine the bores if your using a rebuild kit to get the crosshatching pattern back on the cyl.
The items that could push the cost up are a turbo rebuild or pump rebuild if they need doing.
The machining should include the manifold and flywheel for the best job.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 06-20-08, 10:30 AM   #4
Tapage's Avatar
It's not factory sleeved, but you can put a sleeve and back to the factory bore if it's needed .. actually if where my engine ( you can donate if you want ) I just go with the Rosco route .. no sleeve and bore it if where necesary with over pistons ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 06-20-08, 01:22 PM   #5
prado t's Avatar
TLCA# 17424
There is a club member that got the kit from 4- Wheel Auto for his 12H-T (ATEB) did the rebuild but got the machining done somewhere? for the sleeve installation.
2.5 OME Heavy coils, ARB rear locker PRADO STOLEN
89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
prado t is offline   Reply With Quote
Old 06-21-08, 11:00 AM   #6
rchalmers3's Avatar
Are you saying the 12H-T is sleeved or are you saying the club member you mentioned decided to sleeve his motor?
Rick
rchalmers3 is offline   Reply With Quote
Loans | Cheapest mobile phones | Secured Loans | Mobile Phones | Mortgages
