LinkBack (1) | Thread Tools | Display Modes |
...put you in an FJ today
pinhole fuel leak
I'm new to the diesel thing so this is probably a dumb question.
I have a pinhole leak on one of the fuel lines near the motor. What can I use to patch it up? JB Weld? Replace? duct tape?? __________________ 1983 VJ47 Crew Cab "The Great Pumpkin" 1992 M-101 Finally I can get what I've always wanted....a used Toyota. |
rust and moth consumables
Which line? Being the engine compartment, I would be inclined to replace it. A pin hole indicates corrosion and probably there's more where that came from. It takes a lot to combust raw diesel but ones it lights it'll burn until there's no more fuel.
__________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
#4 | |
You can use all three, but in this order: Duct tape, JB Weld and replace. Or you can skip the first 2 and hit up exmodlad for a replacement line. Rick |
who/where is exmodlad?
__________________ ar 1979 BJ40, 12V |
I am sure lots ask that question, and i sometimes wonder myself........ albert..
![]() ![]() ![]() I have few diesel and LC parts for sale from time to time..only trying to help out... Best Regards Gord Last edited by exmodlad; 06-16-08 at 01:09 PM. |
jb weld will work for like a day or so. On my old audi 4000s diesel I had one too, nothing worked but to replace the line.
__________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute |
"You should be able to delete your own thread. Communists abound"
I wonder about this also..i wonder what makes you special that you can, as some do, delete your own threads... Hmmmmmmmmmm |
Replace your line, if you plan on running Bio Diesel or Veggie I would replace the lines with VITON but if you plan on running B5-B20 you could get by with rubber but use a fuel conditioner keeps everything like your injector pump , injectors and fuel lines in top condition.
__________________ 2.5 OME Heavy coils, ARB rear locker PRADO STOLEN ![]() 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
#10 |
if you want to go fast and easy.....cut the line...use a fuel line on top ...butting them up to each other....and 2 clamp it....its an old PO trick
![]() you too can be the PO everybody talks aboutsomething like pictured but with better clamps
__________________ 1974 FJ40 OEM Soft Top (1) Child boy version (1) Child girl version (1) New boy Child, done as of 11/6/08 ![]() 197 Wife TLC FST Canvas & Maint: http://forum.ih8mud.com/40-55-series...soft-tops.html Last edited by JohnnyC; 06-16-08 at 03:06 PM. |
#11 |
brazing a pinhole from abrasion rather than rust is a perfectly accepted way to make a repair.
__________________ 75 BDJ55- biopig |
#12 |
Thanks for the responses.
It's a metal line that is leaking about 6 inches before the fuel enters the motor. It's an "L" motor that is in my Toyota Blizzard. Do I need to buy a replacement line or are there universal replacement parts? I'm sure I can bend the line to make it fit but I'm worried that the metal pieces on each end are irreplaceable. As I said I'm not much of a mechanic so I don't wanna screw up something that can't be fixed __________________ 1983 VJ47 Crew Cab "The Great Pumpkin" 1992 M-101 Finally I can get what I've always wanted....a used Toyota. |
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/226648-pinhole-fuel-leak.html
| JB Weld - internet discussions | BoardReader | This thread | Refback | 06-20-08 08:04 AM | |
Ringtones | Online Loans | Credit Card Debt Consolidation | Loans | Loans |
