Just got off the highway after a 45 minute drive at 100km/h. When I came to a a stop I heard something like construction hammering outside. Turned out it was my engine. Just a tick at idle and when revved a little it was a banging. I was ready to call a tow truck and figured the 3b was toast. Came out 15 minutes later. Started up and it ran fine. Drove it all the way home at highway speed without a peep. It does have a noticeable tick (kind of metallic sounding). This ticking started after I put new nozzles in the injectors. I did have the cracking pressures adjusted. But I mileage did improve from 25 to 31 mpg. On another occasion, the truck did lots of bucking when I had driven over a crunky ice covered road. In this case, I had just hammered three speed bumps. I wonder if there is not dirt somewhere near the fuel pump that is getting stirred up when I hit bumps at speed. Then again, maybe it's something more sinister. I adjust the valves every year, but have not yet done it this year. The truck is my only driver. Thanks for any advice.
84 BJ60 265 km |
mmmm I didn't like this kind of sound ..
How it's your oil press .? My best bet shoul be inspect the engine form under ( oil pan ) and see what you get .. |
Tapage, it does drip a little but has done so for a long time. The oil pressure has not changed. It is a little under half when warm.
#4 | ||||||
"Ticking" is normally associated with a tappet that has too much clearance (which is a minor problem and easily corrected). Quote:
"Metallic-sounding". Who did that work? Did you do it yourself? (Because exactly what was done then could be the key to finding out what has gone wrong now.) Quote:
![]() PS. I'm probably not much of help here --- I know. Perhaps you should identify which cylinder is "ticking", remove that injector, inspect it, and peer down the hole? __________________ Name's really Tom & I have a 1979 BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981 The only people that aren't insane are the ones I don't yet really know. |
ah, no biggie, you probably drop a chunk of prechamber and are slowly killing your piston.
__________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
I had a 3B with a metallic rap at 1 x's rpm and found the problem after I pulled the oil pan. In my case it was a piston missing part of its skirt. The noise was the other side of the piston skirt slapping the cylinder wall. My only solution was a rebuild as I didn't want to pay for the rebuild with a fragged engine.
Keep us posted on what you find. Jeff __________________ 1981 BJ42/Factory smurf blue/PTO Ramsey 03 Volkswagon wagon TDI Only gassers left in my household are my Stihl chainsaws... |
of course, metal objects do not heal themselves so...
bad knocking is ...well...bad. __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
rust and moth consumables
Did you do your own injectors? Where did the nozzles come from? If it were mine I'd be thinking about investigating injector nailing. An injector can make a hell of a lot of noise that can sound a lot like a rod is going to come through the block.
A really bad metallic knock caused by a rod or main or some other serious mechanical failure does not typically come and go. __________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
why not start by draining your oil, checking for...
can you be sure in was the engine and not the tranny? good luck, eric __________________ life before kids... '81 bj 42 daily driver '81 bj42 project '77 fj40 hopefully running soon |
#10 |
Diesel for blood
Its not the fan hitting the shroud by any chance is it??
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#11 |
Well, isn't Cushers the positive thinker in this thread?
![]() I am hoping Rosco is right. It is very strange that you had a very loud thumping and it went away to a slight tick. Look at the fan tip and shroud for wear. If so, then check for a broken motor mount. Never had a precup drop but from what I have read it generally can start out like a slight rock in a tin can rattle as the loose or cracked precup rattles in its place in the head. When it drops, then you get the bang (and sometimes worse). I have never heard of anyone starting back up and driving away with a slight tick after a pre-cup drops. __________________ John G. 姉 ![]() Join the Import Vehicle Owners Association of Canada: Fight for what is right |
#12 |
anything i can do to lighten the mood...
when a precup drops it usually means a dead piston, busted rings, scored cylinder sleeve or wall, cracked head and busted valves... nothing really serious. __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
#13 |
From the description, I thought pre-cup too.
__________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
#14 |
Rotflmao!!
#15 | |
BJ addict
IH8MUD™ Forums - View Single Post - Dont' loose a precup, 3B carnage __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#16 | |
I never thought of that. Well done...... Yes. This would certainly connect the "driving over a speed hump" with "engine noise". And broken engine mounts are hard to spot without jacking the motor up. (Hopefully "broken engine mounts" is all it is.) Any news of what you've found Duckling? |
#17 | |
Diesel for blood
#18 |
You guys are hilarious. I'm glad I wasn't home to read all these posts. I don't know. I just took another trip of an hour and a half. Ran fine. I agree with Canucksafari that it seems pretty unlikely that major engine damage would come and go. I mean, the truck pulled perfectly between incidents. Then about an hour after which the problem started again. Tried bleeding the injector pump and injectors, while running, in case it was air. Started it again after ten minutes and the noise was gone. This morning, the muffler broke off. I have pipe running outside the passenger frame rail, with a v. small muffler (doesn't muffle much) and goes out behind the rear passenger door. I think it may have been banging against the frame at the end of every odd trip just to freak me out. Yeah, I feel stupid.
Mac, I just pulled them apart put the new nozzles in myself without setting the cracking pressures. Maybe they're off. My mileage went from 25 back up to 31 mpg, though (Canadian gallons) and it definitely pulls better. |
#19 |
Rosco, on the east coast, our constant melting, freezing and freezing rain can sometimes make roads that are literally slabs of uneven ice of varying thicknesses. Wet, bumpy and well…chunky. Doesn't happen very often.
#20 |
LOL!!
you might feel stupid but who cares, it was a cheap fix... that is the important thing. __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
#21 |
Glad to hear it's worked out for ya.
I had an exhaust system that would occasionally bang against my frame on a BJ60. It was the result of a decaying left side engine mount. __________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
#22 |
I actually had this happen to me, exhaust on these engines rattling loose or against something can make some very bad noises....
__________________ 1986 BJ70, 24v with a 3B |
#23 | |
Diesel for blood
#24 |
any time you have what you think could be and engine noise (especially bottom end) remove the oil filter and cut the top off it with a hacksaw. Then pull out the element and cut it down the middle from top to bottom, then then you can take the element and spread it out and inspect it look for metalic peices use a magnet to see if they are aluminum or steel. Messy job but usually tells you a lot of info with out having to take the engine apart.
Glad to hear it was only an exhaust problem |
