#61 | |
the comment was:
Roverboy: " but MASSIVELY increases the stress on everything." there is no proof that a controlled and progressive induction of propane causes any MASSIVE increase of stress. as in anything if you dump gobs of added power to an engine you will increase the load BUT a controlled injection of propane will not. think of it as a turbo affects the load on an engine. the boost does not jump instentainiously from 0 lbs to 15 lbs, it is a gradual climb in pressure (sometimes quick but still gradual). with a PROPER propane injection system the increase in stress and power is also gradual since the volumm of propane is increased as the boost increases. you can adjust the propane to be injected in what ever amounts and at what ever boost you want... so if you want a minimum injuection of propane 2 cfm at your cruising speed average boost of 6 lbs then you set the system at 4 lbs. the voost will open the valve and allow the propane to BEGIN being injected into the air charge to the engine. at 6 lbs of boost you will be at the 2 cfm, this will provide a cleaner burn, PROBABLY a whee bit better milage and smoother burn of the fuel... NOT the massive stess load Roverboy is indicating. you also can limit the max of propane you are injecting so at 15 lbs you can also set the max at 3cfm for hills or passing... once again this is a controlled injection of propane NOT a line from a bottle in the cab and a hand knob cranking the flow of propane uncontrollably into the engine. with propane a little is good, and contary to popular belief, a lot is not better. now this is MY take on propane injection for fuel economy: the addition of propane for fuel economy is a waste of time and money in my mind. it is for an increase of performance. you "might" get a mile or two to the gallon out of a properly setup system but then you are paying for the kit, the install, the tank and the fill with each tank. it will take a long time to pay off the advantage costs. <uneducated BS comments like those from Roverboy should be edited> Quote:
__________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
#62 | |
![]() Regardless of how you like to "control the injection" of propane, you're adding it to the cylinder before the diesel injects, the gas preignites causing the diesel to burn sooner. The loads this increase in timing places in the engine are nothing like turbocharging, such a statement suggests a lack of understanding. Of course I don't sell or fit these systems so I have nothing to gain from promoting them. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#63 |
yah, i am promoting the sale of propane iinjection kits by telling everyone NOT to buy for fuel economy...
grow up little man. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
Hummer | Myspace Layouts | Mortgage Calculator | Car Insurance | Flights |
