Old 05-31-08, 10:19 AM   #1
Tachmoeter
I have accesss to a fj60 tachometer. Any way to make this work in my 2B engine?
Thanks!
K
1981 JDM BJ44 RHD - Going under the knife soon!
BreckenridgeCruiser is offline   Reply With Quote
Old 06-02-08, 02:29 AM   #2
AGreekBoy's Avatar
TLCA# 18699
i am not positve but i dont think this tack will work unless you have a sensor in you bellhousing that i will plug into. i just put an autometer on my 3b part number 2888. look it up it reads off the alternator.easy install.
AGreekBoy is offline   Reply With Quote
Old 06-02-08, 10:43 AM   #3
70sguy's Avatar
Won't work. The FJ tach takes a signal from the distributor or alt or something. The pre 90 Toyota diesels take a signal from a hall effect sensor that reads the teeth on the flywheel.
See if you even have a sensor in the bellhousing... being JDM it just might.
If not you will have to drill and tap.
The Autometer might be the simplest route as you won't get a 60 tach into your 40 cluster anyway.
93 1HD-T swapped FZJ80
VW A4 Jetta TDI
My other diesel is a Locomotive
www.gscruiserparts.com
70sguy is offline   Reply With Quote
Old 06-02-08, 11:48 AM   #4
This is the kind of Bellhousing required for a diesel tach....this one is for a 3B, and i am not sure if it will fit the 2B
This one is available
This is the tach sensor that goes with this housing also available
Shipping will be substancial
Best Regards
Gord
exmodlad is offline   Reply With Quote
Old 06-02-08, 09:53 PM   #5
TLCA# 15991
Ok,
let's take this one step further. Has anyone ever ADAPTED the hal-effect sensor to another tachometer?
I would like to do so because of space limitations on my dashboard...
N6LG - Extra Class Amateur Radio Operator
1982 FJ40 (HJ41), 12HT turbo diesel, H55, ARB locker, e-locker, Marks Gears, APRS
1997 LX450, 1HT-FT/H151 diesel conversion in process...
1972 FJ40 Fun Beater Rig, Bone Stock!
panoramic is offline   Reply With Quote
Old 06-02-08, 10:41 PM   #6
Diesel Trucker
Originally Posted by panoramic View Post
Ok,
Ive seen pics of diesel 45/47 series in AU that have a tach mounted to the right of the main cluster in the dash. Maybe you can find one of those? It would use the hall sensor mentioned.
You could also try the tiny tach that others have used. The small led readout would be good for your space limitation and it would be easy to get.
lynchmob is offline   Reply With Quote
Old 06-05-08, 06:44 PM   #7
TLCA# 15991
The problem with the TinyTach is calibration. You still need some sort of reference for true RPM's.
BTW: I thought TinyTach is LCD (ie:not LED).
Old 06-05-08, 07:03 PM   #8
Diesel Trucker
You got me on the LCD screen...
I dont really follow on your statement re: calibration though. The tach runs off the pulse of the injection pump which happens only every 360 degrees for each cylinder. What needs to be calibrated?
Old 06-08-08, 02:11 PM   #9
IH8WORK
freebie's Avatar
Ditto on the calibration?? I just installed mine, there's no calibration!
As for the autometer tachs, part number 2888 where are you finding that Greekboy, I have searched there site with no luck and when I've checked with the auto stores they can only find 12 volt models, unless you can find a mechanical tach you will need a 12 volt supply for any of these tachs if they are connected to the alt or to a bellhousing sensor. The only simple and cheap solution for the 24 volt Landcruiser models I can find is the Tinytach.
Cheers
freebie is offline   Reply With Quote
Old 06-08-08, 02:44 PM   #10
amaurer's Avatar
Why would you need to calibrate it? Its sensing fuel flowing through the injector line; that only happens once per two revolutions on every four stroke diesel.
"... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908
1982 BJ42 "Krull"
Last edited by amaurer; 06-08-08 at 03:26 PM. Reason: duh diesels are four strokes
amaurer is offline   Reply With Quote
Old 06-08-08, 02:51 PM   #11
Here's a Autometer from Summit racing Auto Meter
You can pull 12v from your converter to illuminate the light. Works off of the alternater, no calibration.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Diesel42 is offline   Reply With Quote
Old 06-08-08, 03:23 PM   #12
amaurer's Avatar
Nope, that type DOES need calibration (try the instruction manual http://www.autometer.com/productPDF/608.pdf). Its sensing alternator pulses, but various types of alternators have different numbers of poles, so you'll get varying numbers of pulses.
The tint tach, again, needs no calibration.
1982 BJ42 "Krull"
Old 06-08-08, 04:59 PM   #13
Your right, i forgot. I stand corrected.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Old 06-08-08, 11:33 PM   #14
IH8WORK
freebie's Avatar
Hi Diesel, thanks for the link, how much for that tach??
Old 06-16-08, 06:24 AM   #15
Drinking the Kool-aid
Creeker's Avatar
So has anyone here installed the Autometer tach? If so, how did you do the calibration? The instructions suggest using "test equipment found at many stations or dealers"...
'88 FJ62 - 12HT conversion, OME Lift, ARB front bumper, Roof Rack
'04 Prius - stock
'66 Pearson Commander - a hole in the water to throw money into.
__________________________________________________ ________________________________________
"Dang me, dang me, oughtta take a rope and hang me..." Roger Miller
Creeker is offline   Reply With Quote
Old 06-16-08, 08:31 AM   #16
amaurer's Avatar
If you're brave and work quickly you could use the rev limiter as your rpm reference.
You could also calculate your final drive ratio and calibrate in motion via the speedometer.
Or take the rear driveshaft out and use the speedometer as above, but while stationary.
More outlandish ideas:
Use a laptop with a microphone and spectral analyzer, there should be a good bit of power at 2*engine frequency (rps).
1982 BJ42 "Krull"
Old 06-16-08, 04:01 PM   #17
Tapage's Avatar
Holy smart dude ..
Lucky my both diesel cruiser have factory Tach .. far beyong my capabilities spectral analyzer !
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Myspace Comments | Credit Cards | Cell Phones | Personal Injury Attorney Los Angeles | Bleach 183 . Bleach 184
