Old 05-28-08, 03:14 PM   #1
Talking 12ht or 4bt or 6bt conversion
i have decided to change the power plant and transmission of my 1981 hj 47, it currently has a 2h with 4 speed transmission. i was thinking of a 12ht with a 5 speed, because it will bolt right in. a friend today suggested a 6bt or maybe a 4bt cummins. one reason beside the reliability of the engine is the cost. i know that there are a lot of information on the forum about the 4bt conversion, what about the 6bt. will the 4bt or the 6bt bolt right into the toyota 5 speed transmission or do i need to go to another transmission. what is the mpg. my cruiser is heavy see picture below. love my 2h but, there just don't seem to have enough horses on it. reliability is still most important for me. pls direct me to the information or i am interested to know what you think. since i have decided to change power plant i figure i should explore the possibilities and put the question before the forum.
rideglobally is offline   Reply With Quote
Old 05-28-08, 05:45 PM   #2
Diesel for blood
roscoFJ73's Avatar
I would go with the 12HT ,1HZ or 13BT. The others would be difficult for parts outside the US and explaining to people it has had an engine swap on the phone is frustrating.
The 12HT is the easiest to bolt up,but get the 5sp with it. In 5th gear at 2200 it will be in its ideal rpm range and that will be around 60mph.
Realistically ,with all the camper gear up top, achieving 17-20 mpg will be the best you can hope for
The toyota diesels are also quiet which is ideal for long trips.
Download the free image resizer from MS and choose the smallest setting to resize the pic then upload to mud
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 05-28-08, 07:07 PM   #3
Diesel Trucker
why not put a turbo on the 2H? You can also add a 5 speed to your existing 2H
lynchmob is offline   Reply With Quote
Old 05-28-08, 11:23 PM   #4
Talking
i thought about that but, the cost is very close and would rather go all the way, my 2h has many mialege and would have to rebuild it if i was to put a turbo on it. plus i need to put a ps and an air conditioning on it, i am thinking i need to a power plant that i can build around....thanks
also i will take down the photo till i figure out how to resize it..thanks again
Old 05-29-08, 04:54 PM   #5
Tapage's Avatar
I love the 2H engine .. but if you have any chance to get a 12H-T ( close to the best turbo diesel engine that I ever seen ) go for it ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 06-13-08, 11:45 AM   #6
Talking 1981 2h engines
i am told there is a difference between 2h engine made before 1985 and those made after 1985. since my 2h is 1981 i am told that the piston are sprayed with oil, therefore ideal for turbo conversion, does anyone knows about the difference, between this engines? is this true?
Old 06-13-08, 02:49 PM   #7
Tapage's Avatar
There are few diferences like head gasket, sleeve vs non sleeve block, exhaust manifold .. and few others ..
I don't think that any 2H have piston squirt cooling ..
Old 06-13-08, 05:38 PM   #8
Diesel for blood
roscoFJ73's Avatar
x2 the parts manual only shows the squirters on the 12HT AFAIK
33 in BFG A/T
Volvo 740 GL
Old 06-13-08, 06:02 PM   #9
The info on here is for an Isuzu 4BD1T, this is not the same engine as the cummins 4BT but is a similar layout (similar capacity, both 4 cyls etc).
It'd be probably four times quicker and easier to fit a toyota engine in than anything else.
Have you heard of the 1HZ-T?
Old 07-21-08, 01:47 AM   #10
have not heard of the 1hz-t, i have only heard of the 1hz, no turbo. i have heard of the 1hdt, i am looking into the 1hdt if the price is right it may be the way to go... sorry about the big picture in the beginning of the tread, i cannot figure out how to take it out.
Old 07-21-08, 10:39 AM   #11
Otterav's Avatar
E-mail irongiant, he is in the process of importing a 1HZ, he is a wealth of info on JDM engines and trans.
eric
1974 FJ/BJ 40 3/4 Mutant, 3B, Turbo, and Odie the yellow lab ridin' shotgun!
http://forum.ih8mud.com/diesel-tech-...-mutation.html
Engineering: Not doing anything with a dollar and spending 4 more on internet access instead of owning a Landcruiser!
Otterav is offline   Reply With Quote
Old 07-21-08, 02:05 PM   #12
Diesel for blood
roscoFJ73's Avatar
eric
One of the things that needs to be considered is the Japanese diesels are all 24 volt and the Australian diesels are 12v.
Rideglobally's HJ45 is 12v.
I suppose a JDM 1HD T would be simple enough to convert to 12V by obtaining a 12V starter and alternator.
Im not too sure about the glowplugs,temp and oil sensors but they are cheap to change over
33 in BFG A/T
Volvo 740 GL
Old 07-21-08, 03:26 PM   #13
The 1HZ-T is the sasquatch of toyota engines. Pictures and catalogue references exist but the board members get rapidly divided over whether it really exists or not.
Old 07-23-08, 10:58 PM   #14
Talking inter cooling a 12ht
i could not find a tread on inter cooling a 12ht. what are the gain in power? what are the other benefit ie, mpg. i weight my cruiser today it is 7500lbs, i think when i am done building, it will be between 9000 to 10,000 fully loaded. given this weight, what do you think is the best engine. do you think an inter cooled 12ht would be enough power? 12ht would be the easiest of all the possible conversion. your thoughts.......
Old 07-23-08, 11:17 PM   #15
Take a look at this thread:
http://forum.ih8mud.com/diesel-tech-...-nuumbers.html
"Enough" power is very subjective. Some people aren't happy with a 300hp sports car.
*edit*
This one too:
http://forum.ih8mud.com/diesel-tech-...r-install.html
Old 07-24-08, 04:30 AM   #16
Diesel for blood
roscoFJ73's Avatar
Im sorry but I think you will be grossly overloaded. I dont know what the american laws allow ,but here, the GVM would be 6700lb
33 in BFG A/T
Volvo 740 GL
Old 07-24-08, 01:20 PM   #17
Wayneraintree's Avatar
TLCA# 9720
hmmmmmm......
With that weight... I would say Chevy Duramax
Jeffrey
Save Tellico!
TreadLightly
BlueRibbon Coalition
United Four Wheel Drive
TLCA.org
ALCA- Fledgling Cruiser group of eastern PA
Wayneraintree is offline   Reply With Quote
Old 07-24-08, 01:31 PM   #18
Tapage's Avatar
Make me smile .. but it's true ..
I thought ( and it's bassed on my personal opinion ) that a properly tuned 12H-T with a proper fitted intercooler it's a very capable engine that allow you to move with your cruiser to any place ..
Sure if you are moving 10k pounds of stuff 33" or 35" tires with an auto tranny and 3.70 R&P .. you gonna feel that the 12H-T are not enought ..
Edit: sure with that weight you will end with other propblems as your rear axle ( FF . ? ) and your braking power.
Old 07-24-08, 01:35 PM   #19
Team Bullsac
bull's Avatar
TLCA# 12258
Speaking from experience the 2H will be a dog up hills. Then the MPGs go down. I say drive it as is and get a feel for it. Then upgrade to your liking.
bull is offline   Reply With Quote
Old 07-24-08, 03:46 PM   #20
Tapage's Avatar
2H and 12H-T are 2 totally diferent beast ..
Old 07-24-08, 04:53 PM   #21
Team Bullsac
bull's Avatar
TLCA# 12258
True, but he currently has a 2H and my reccomendation was to take the rig on a few trips fully loaded. To see exactly how much power etc he is going to need to do what he needs to do
Old 07-24-08, 05:00 PM   #22
Diesel for blood
roscoFJ73's Avatar
He has just done that and is not happy
33 in BFG A/T
Volvo 740 GL
Old 07-24-08, 10:47 PM   #23
Talking
[quote=Wayneraintree;3509032]hmmmmmm......
i am now thinking 12ht with intercool or 1hz with turbo and inter cool. i will look into the chevy duramax, but seem that there would be much modifications, has anyone done this?
Old 07-24-08, 11:26 PM   #24
code 621's Avatar
I know I'm a little off subject--but nice speed rail rack. Reminds me of my days of doing car rigs in the movies.
code 621 is offline   Reply With Quote
Old 07-24-08, 11:58 PM   #25
If you're considering a 1HZ and turbocharging it, why not a 1HD-T?
Direct injection means faster starting and better fuel economy.
Old 07-25-08, 06:31 AM   #26
TLCA# 9720
I think you are getting some great advice here.... good topic and sweet 47!
*if you click "edit" under your post, you can delete the photo as you like.
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 07-25-08, 11:45 AM   #27
