#31 | |
#32 | |
Diesel for blood
The downside is parts are not so readily available as only a handfull of countries got them and they were only in production for about 5 years. I dont think you would need a intercooler and it would block off access to the engine. With what you have regarding the height and weight,a good steady 50-60 mph is the best you can hope for on a very good road. If you going to countries with not much infrastructure 30-40mph might be the best you can hope for. The 1HZ would need new frame bracket welded on for the engine mounts. A gearbox with 21 splines.. You would need a new tacho.An aftermarket set up would be better I think your oil pressure and temp gauge are a plug in. The exhaust would need some thought as it exits the 1HZ in an awkward spot on a 45. The PS pump and vac pump are all self contained on the 1HZ Send a PM to Radd Cruisers. Im sure he put a 1HZ into a 45 __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Loans | Loan | Secured Loans | Debt Help | Mobile Phone |
