Old 05-19-08, 06:36 PM   #1
cruiser_guy's Avatar
TLCA# 16387
Heads up on 3B internal voltage regulator
I was out driving the BJ60 today and noticed that the voltage was higher than it normally is. The shop manual repair is "replace voltage regulator" so I got out my spare regulator. As I was installing it I noticed that the white wire had a small amount of exposed copper right where it passes the blue wire terminal. I decided to see if I could simply re-wrap the wire with some electrical tape and fix the problem so I did. Voila!! Regulated voltage again! The spare regulator went back in the spares box.
Moral of the story, check wiring for shorts, bare wire just in case.
www.wirrell.com
Old 05-19-08, 07:38 PM   #2
David*BJ70's Avatar
TLCA# 15514
Nice call !
This one go in my book just after : check the fuse first
BJ42 1982 * The Primitive Beast - wvo
BJ70 1985 * The Green Machine - wvo some say The Mighty Pickle ! come on !
1992*Corolla*All-trac* The Quiet Spirit
Si je dois aller en enfer... ce sera en Landcruiser
(Canadian french guy (Québécois)... sorry for my english ! )
David*BJ70 is offline   Reply With Quote
Go ACC | Credit Report | Loans | Credit Cards | Loans
