LinkBack (4) Thread Tools Display Modes
Old 05-12-08, 06:48 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Crawl gear fr my 5spd Bj42!
Evening,
I am looking for a crawl gear for my '84 bj42, 3B, 5speed.
What is my T/C called?
And who makes crawl gears for them?
Want lower gears, but don't want to loose my current low range for when the snow is good.
Already running 4.88's and 38".
Klaufi is offline   Reply With Quote
Old 05-12-08, 07:12 PM   #2 (permalink)
dslcruzr's Avatar
I believe Marlin is making toyboxes for 5speeds, and is probably the nicest option. Your transmission is a h55 (f?) and i you should have the later "split case" transfer case. I'm looking into going lower as well, and have a very similar set-up as you. I'm just getting around to putting in 4.88's. Let's see some pics of your rig!
1984 BJ60, Poo brown, SOA, c&t, Track bar, Homemade front and rear bumpers, Warn 8274, 4x4labs hysteer, York OBA, 1/4" Aluminum Oil Pan, New frame, 38" Michelin XL's, 4.88's, Aussie locker (rear), Rear storage, Rock lights, CB, Volvo T3 turbo, 2.5" mandrel bent exhaust with NO muffler, lots of pinstiping and custom rust...
dslcruzr is offline   Reply With Quote
Old 05-12-08, 07:53 PM   #3 (permalink)
thank you, I thought that the toyboxes wouldn't fit. Have you decided wich gearing to ewuip the toybox with?
I hear you can pick different gearings their site is down atm so i can't read about them atm .
*EDIT* Wroe so muchabout my car i decided to start a build thread instead!
http://forum.ih8mud.com/40-55-series...nch-o-pix.html
Old 05-12-08, 08:18 PM   #4 (permalink)
Awesome pics and awesome rig. Where were those photos taken at? It seems there is a place called Marks gears that sells a full compliment of gear sets for your(our) transfer cases. Very expensive though, seems like 1800 or 2000.00USD if i remember right. Give or take a couple hundred still way spendy. I would also like to do this mod. Welcome to the forum.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Diesel42 is offline   Reply With Quote
Old 05-12-08, 08:19 PM   #5 (permalink)
Hi,
l have installed 2 Toyboxes on Bj42s,one with 4 speed H42 and one with H55F 5 speed.l moved the engine forward 4" and therear axle back 3",the toybox has 4.7 low.
Marks' gear in australia have 1.08 hi/3.08 low gears that will fit in your split transfercase.
Simon
Winnipeg
simonliew is offline   Reply With Quote
Old 05-12-08, 08:25 PM   #6 (permalink)
Diesel42:
Thanks, Pics are taken in Iceland, More pics in my build thread
And Simon:
Why did you move the engine?
Why notchange the lenghtf the driveshafts?
Lke i said, i want an additional gear, i don't wantto change the original transfer case, the origial low gear is sometimes good in snow, and for very heavy snow i need lower gears, but don't want onlylower gears ecause then i will be travelling a hell of a lot slower when the snow isn't that heavy
Old 05-12-08, 10:19 PM   #7 (permalink)
freebie's Avatar
Hi
Very nice rig!
I just put an H55f in my Bj42 and the rear driveshaft ends about 19" long flange to flange. If you take off the u-joints and the slider the tube is 3-4 inches long. Not much room left for any thing else unless you want to go full on front wheel drive?
Cheers and enjoy mud!
freebie is offline   Reply With Quote
Old 05-13-08, 05:39 AM   #8 (permalink)
Hi Klaufi,
my project is a rockkrawler,the toybox is about 7" if l remember right,with springover axle suspension,l ended with a very short driveshaft(about13") if l don't move the engine and rear axle.
Where ca nl buy those rear femderflares,l have 80 series axles and 40"x17" MTRs.
Simon
Old 05-13-08, 05:46 AM   #9 (permalink)
crushers's Avatar
hint, if you want a lower low range but not 'rock crawling" low then get a t/case from an auto HJ60 and swap in the gears. the final crawl is the same as if you changed out the rear gears to 4.88... i have done this swap on many of my bush rigs and love the result.
the the t/case aftermarket gears seem to howl a LOT.
i have seen the crawler box installed into a couple trucks and it really gives them some serious crawl ratios but a 40/42 will need some major mods to fit (i.e. what Simon did) definately not a bolt up and run...
"life is too short, go wheeling"
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
Wayne in Ontario
www.luxuryimports.ca
Old 05-13-08, 09:55 AM   #10 (permalink)
4x4panama.com/foro
Tapage's Avatar
are 2.48:1 vs 2.28:1 in the gassers and 1.96:1 in diesels ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 05-13-08, 06:38 PM   #11 (permalink)
Simonliew:
Thoose fender lares are built here in Iceland, they are plastic, If my memory doesn't fail me a comapny that builds plastic boats makes them. Originally made for the Cj-7 Jeep.
All others talking about drive shaft length:
I don't think i have to worry about the drive shaft lengths since i'm talking about extending the car, the extension will be made just behind the T/c, so i have plenty of room for shaft's. The front shaft will ecome a little longer and the rear shaft will also need to be extended.
P.s. Simon, look at this 80 series's flares on 44" Lots of thoose here in Iceland
Old 05-13-08, 08:21 PM   #12 (permalink)
brisveganbj42's Avatar
I'm interested in this mod..
from the info I have found the low range ratio in my bj42 is 1.959:1.
What is the low range ratio in the HJ60 transfer (is it an A440 g/b?).
'84 BJ42 with all the fruit - fun to drive 7 days a week!
Got a BJ42? Join the crew @ PHAT42!
my 'shed'
3rdrock4x4 club
QLD 4WD Spares and Repairs
brisveganbj42 is offline   Reply With Quote
Old 05-14-08, 05:36 AM   #13 (permalink)
crushers's Avatar
the BJ42 5 spd comes with the 1.9 low
the BJ42 4 spd comes with the 2.3 low
the HJ60 auto comes with the 2.48 low
4.9 (H55F 1st) X 1.9 (low range) X 4.11 (diff gear) = 38.26 crawl BJ42 5 spd NA spec
4.3 (H42 1st) X 2.3 (low range) X 4.11 (diff gear) = 40.64 crawl BJ42 4 spd NA spec
4.9 (H42 1st) X 2.3 (low range gears from '4spd' t/case) X 4.11 diff gear) = 46.31 NA spec
4.9 (H55F 1st) X 1.9 (low range) X 4.88 (diff gear) = 45.43 crawl (for comparision)
4.9 (H55F 1st) X 1.9 (low range) X 5.29 (diff gear) = 49.24 crawl (for comparision)
4.9 (H55F 1st) X 2.48 (low range) X 4.11 (diff gear) = 49.94 crawl
the advantage of the low t/case gear is your day to day driveablity stays the same, fuel milage does not change but when you go into low range your crawl has been increased by 30%...quite adaquate for most wheeling.
i was incorrect in my earlier post, the t/case swap is equivilant to changing the diff gears to 5.29...sorry
i also added another of my favorite swaps for the earlier 83-85 5 spd t/case, the gears from a 81-82 4 spd t/case will slip right in giving you a healthy 46/1 crawl. a 13% crawl increase...doesn't sound like much but you can feel the increase in torque off road.
Wayne in Ontario
Old 05-14-08, 01:07 PM   #14 (permalink)
tmarx's Avatar
...i also added another of my favorite swaps for the earlier 83-85 5 spd t/case, the gears from a 81-82 4 spd t/case will slip right in giving you a healthy 46/1 crawl. a 13% crawl increase...doesn't sound like much but you can feel the increase in torque off road.
Thanx for the valuable info and the fact that you have actually done it before .....
Theo
105 1HZT I/C
BJ 42 LX 11/83 - 3b H55F P/S 3 wipers and slidin windas
tmarx is online now   Reply With Quote
Old 05-14-08, 03:34 PM   #15 (permalink)
4x4panama.com/foro
Tapage's Avatar
My Tencha come factory with H55F and 1.96:1 low gear set .. but autos ( A343 ? ) come with 2.48:1 as Wayne coment ..
Old 05-14-08, 04:48 PM   #16 (permalink)
crushers's Avatar
glad to share...
i guess us back yard mechs are good for something after all...
Wayne in Ontario
Old 05-14-08, 08:32 PM   #17 (permalink)
Yep, thanks for the valuable info on the gears.. now all i've got to do is track some down!.
my 'shed'
3rdrock4x4 club
Old 05-14-08, 11:34 PM   #18 (permalink)
Thanks Crushers. This is great info as i have always wanted to do some better gears but couldn't bring myself to the 1800.00-2000.00 Marks gear price tag. When the time comes to rebuild my t-case(83 BJ42 w/H55, I will follow your advice with the readily available gears. Awesome post.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Old 05-15-08, 12:33 AM   #19 (permalink)
Just for everyones info..i am parting out (2) split T cases that were behind 3B 4 Spd transmissions
Best Regards
Gord
exmodlad is offline   Reply With Quote
Old 05-15-08, 03:25 AM   #20 (permalink)
Hulsty's Avatar
is it only HJ60s that have a 2.488 low range? or do all 60 series autos with a A440F have that low range ? Does a 73 series share the same ratios as a BJ42 ?
cheers This would definately help my 3F turn the 35''s easier!
The Red Barron - FJ73
Hulsty is offline   Reply With Quote
Old 05-15-08, 04:04 AM   #21 (permalink)
crushers's Avatar
i am only posting up what i know...
the book says 2.3 for the 70 series autos vs the 1.9 for the manual tranny...
Wayne in Ontario
Old 05-15-08, 07:26 AM   #22 (permalink)
4x4panama.com/foro
Tapage's Avatar
I'm not sure about 2.48:1 low gearset in 70 auto trannys .. ( coz we not seen 'em here ) but 100% positive in 60 and 62 with auto trannys .. ( at least here )
Edit: Note: in this trail of the Cruiser knowledge learn that Toyota made much diferent configuration depending on the Country of target Region ..
Old 05-19-09, 02:10 AM   #23 (permalink)
Hulsty's Avatar
Does anyone have any further info on what transmissions came with the 2.488 low range gearset? I'm starting the hunt now, from what I can find only 90+ A440F boxes had the 2.488 low range.
Apart from whats written above I cannot find aynwhere what ratios were in 1990 and earlier landcruiser auto transmissions.
Old 05-19-09, 08:22 AM   #24 (permalink)
4x4panama.com/foro
Tapage's Avatar
As far as I know .. all A440 ( thought from 87 or 88 ) came with 2.48:1 low range .. as same as H150 and H151 but those share other t-case family .. HFXX t-cases
Old 05-19-09, 02:39 PM   #25 (permalink)
Ducks's Avatar
TLCA# 17334
If someone does want a toybox post to this thread in the 40s section -
http://forum.ih8mud.com/40-55-series...ts-toybox.html
or this thread in the 60s section -
http://forum.ih8mud.com/60-series-wa...ts-toybox.html
Chad... K7DUX......1984 FJ60 ....The Iron Mule: 12H-T -> FJ60 ......Web Album
................"Non impediti ratione cogitationis" - Conloquium Currus ..
Ducks is offline   Reply With Quote
Old 05-19-09, 07:23 PM   #26 (permalink)
Hulsty's Avatar
I've found a 88 A440F transer from a 60 series 12HT, which is even harder to find ratio data on! Might have to strip it down and count the gear teeth to compare to my H55F transfer
Old 05-20-09, 05:29 AM   #27 (permalink)
cruiser_guy's Avatar
TLCA# 16387
Wayne or other's out there, do you know if the FJ62 has the same transfer gear ratios as the HJ60 auto and are they interchangeable?
www.wirrell.com
Old 05-20-09, 08:08 AM   #28 (permalink)
crushers's Avatar
not sure, my findings ( a LONG time ago) showed they came only behind the HJ60...
and i am not sure where i read it.
all i know is if you install the t/case gears from a HJ60 your crawl improves noticiably...
Wayne in Ontario
Old 05-21-09, 01:57 AM   #29 (permalink)
Hulsty's Avatar
Well I checked out my spare gearbox and transfer, from a FJ60, 2F 4.11 diffs november 83 build, and it has a 1.9 ratio low range. Next up I will check the one in my car then the 12HT A440 transmission i've been offered.
Old 05-21-09, 05:46 AM   #30 (permalink)
Hulsty's Avatar
Checked the 88 model A440 from a 12HT and it has 2.2956 low range gearing. Need to see if I can find a newer model gearbox, 1990+ to check more ratios
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/221083-crawl-gear-fr-my-5spd-bj42.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - cheap transfer gears for 5spd split case from an auto HJ60? This thread Refback 05-15-08 04:07 PM
Outer Limits 4x4 Board :: View topic - cheap transfer gears for 5spd split case from an auto HJ60? This thread Refback 05-14-08 02:49 AM
Outer Limits 4x4 Board :: View topic - cheap transfer gears for 5spd split case from an auto HJ60? This thread Refback 05-14-08 02:39 AM
Outer Limits 4x4 Board :: View topic - cheap transfer gears for 5spd split case from an auto HJ60? This thread Refback 05-14-08 12:12 AM
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
