Old 05-11-08, 09:23 AM   #1
2H Turbo Glide install??
Installing a turbo glide system. 2 questions??
1 Oil supply is taken from the oil supply line from the injection pump. Use the banjo bolts supplied in kit.???
2 Return oil feed. There is an oil drain on the left side of the block below the side cover plates. The plug is removed and the new banjo bolt and fitting are installed??
This is the new style kit..
Is this correct am I reading right??
86HJ is offline   Reply With Quote
Old 05-11-08, 05:31 PM   #2
All good thanks
Old 05-12-08, 10:49 PM   #3
Tapage's Avatar
I'm not sure .. can't remember well, but can you post a pic of your kit and instalation instructions .?
Other option it's get the oil feed from the oil press sender and the return with the return of the vacc pump ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 05-15-08, 10:39 AM   #4
rchalmers3's Avatar
Pics please, the natives are beating their drums.....
Rick
rchalmers3 is offline   Reply With Quote
Old 05-17-08, 10:40 PM   #5
Installed the kit today... WOW.. it's a totally different truck. Two thumbs up. The truck is an automatic so the accel.. is very smooth with a nice pull. Should I adjust the fuel or just leave it alone. I am getting no smoke but a nice turbo sound. Install guide say's to adjust 2/3 turn ??
Old 05-19-08, 02:44 PM   #6
Tapage's Avatar
The last turbo glide install instructions that I read ( was years ago ) said in a part IIRC that 1/4 turn over factory settings ..
The question is .. it's your pump on factory settings right now . ?
Old 05-19-08, 04:53 PM   #7
Yes it is Where about on the pump is the adjustment.
thanks
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/220794-2h-turbo-glide-install.html
Posted By For Type Date
WASALive ! Turbo This thread Refback 05-11-08 11:16 AM
Debt Help | Compare | Mortgage Calculator | McDonalds | Credit Cards
