#91 |
Very nice post - I will move my controller this weekend. Man, some good tips pop up on this board eh.
Thanks very much. Louis __________________ Louis Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/ Join the IVOAC here to keep JDM's coming - www.ivoac.ca Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca |
#92 |
nah, that is the fertilizer under the bush...
[quote=BillyGHusk;3322586]is that the little red berries on the holly bush? QUOTE] |
#93 | |
And your last point about volume flow. Intercooling increases the volume of air that a turbo and engine has to move. Where do you think those extra air molecules you're cramming into the cyilnders come from? __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. Last edited by Dougal; 05-16-08 at 07:59 PM. |
#94 |
...hope this works.
![]() ![]() __________________ -1971 Toyota FJ-55 44" 302 etc. -1993 Toyota Carina E 2,0 GLi -1987 Toyota HJ-61 38" 12H-T http://forum.ih8mud.com/showthread.php?t=134457 Hj-61 intercooler: http://forum.ih8mud.com/showthread.php?t=181830 |
#95 |
Excellent posts of late! I was also wondering, and found suspicious, that a temperature drop of X would produce the same temperature drop in the exhaust. I believe the effect of increased oxygen availability/air pressure on combustion efficiency and flame front speed was forgotten, and can explain why in real life the EGT temperatures drop in fact by a much wider margin than what is simply produced by the intercooler intake temperature drop.
Now let me add another question to this discussion: what about use in winter time when temperatures are extremely cold? Shouldn't the intercooler be bypassed when air is very cold, or when the engine is cold? Hasn't anyone noticed that the engine seems to work at its best around 10C, indicating a real effect by intake air temperatures? __________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 |
#96 | |
Otherwise colder is better. No need to bypass it, a piece of cardboard stopping airflow would do. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#97 | |
I've been thinking intercooling lately not only because the warm weather is finally upon us, but because I'm seriously thinking about converting to [at least part-time] WVO fueling, and was thinking that probably, a great dual purpose installation for cooling AND keeping combustion clean, would be water injection... Seems so much simpler... What do you guys think of the idea? Just wondering if it hasn't been tried already... __________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 Last edited by 83bj60; 05-17-08 at 08:47 PM. |
#98 |
Water injection is done all the time, but It would be my last choice for cooling charged air. It seems like a much more labor intensive/ potentially dangerous option, depending on how you do it I suppose.
Inter-cooling is pretty much a bolt on and forget solution. That being said... I plan on do it to mine, but more for all out power than a regular use item. G __________________ There is no such thing as a stupid question... just stupid people. |
#99 | |
For water injection .. I will choose propane injection for the same results.
__________________ HJ-60 2H-T Intercooler Tencha HDJ-80 1HD-T not stock at all ! Marilu FZJ-80 1FZ-FE ready to Play ( wife rig ! ) Quote:
#100 |
Water injection cools the charge air and steam cleans the combustion chamber, while propane adds fuel and increases burning efficiency. A bit different, wouldn't you say!
#101 |
#102 | |
At the end what you you want it's more powa .. so water / propane injection are diferent but the same target ..
How much dificult are .. in the long term maybe propane should be more expensive, but water more dangerous .? __________________ HJ-60 2H-T Intercooler Tencha HDJ-80 1HD-T not stock at all ! Marilu FZJ-80 1FZ-FE ready to Play ( wife rig ! ) Quote:
#103 |
I would use caution and alot of math before doing either.
#104 | |
If it didn't, then cigarette lighters wouldn't work. So if you're substituting diesel for propane, you can end up with a slightly lower EGT, but if you're adding (instead of substituting) propane onto your full shot of diesel then you're increasing EGT's markedly. Basically. Swapping liquid fuel for gaseous fuel = slightly lower EGT. Same amount of liquid fuel + gaseous fuel = higher EGT. |
#105 |
#106 | |
But more powa .?
More powa compared to the same setup but instead of propane, water mist injection ? __________________ HJ-60 2H-T Intercooler Tencha HDJ-80 1HD-T not stock at all ! Marilu FZJ-80 1FZ-FE ready to Play ( wife rig ! ) Quote:
#107 |
OK, got it... Slightly lower egt at same energy output... So basically a great mod if you want slightly more power while maintaing similar egts...
Economy wise, though, I'm not convincved... I just got my propane bill, and it's steep! Prices here a way higher than what you pay for the stuff out west... Same with Diesel, of course (1.49.9 last week), but I presume the difference for diesel is not that high... But what about water injection? It should cool the air charge, increasing oxygen content and clean the combustion chamber at the same time, a win-win situation, don't you think? Plus it shouldn't be so hard to make/install? What's the status of research on water injection in diesel engines? Anyone know the latest developments? __________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 |
#108 |
nobody's mentioned hydrogen injection... there's a great thread on it in the alternative fuels section
__________________ BJ62, 3b, H55F 5spd, turbo, A/C, P/S, winch, badass bumpers, defender rack. Facing the music... above 100% rust free diesel expedition cruiser may be up for grabs in 4-6 months time. Shown/delivered anywhere in North, South, Central America. www.wanderinglost.com group for mudders in latin america |
#109 | |
I'd give those a miss. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#110 |
Well any fuel added is probably not going to reduce net fuel consumption and my not really improve efficiency like intercooling will...
The reason I was asking about water injection was precisely for that cooling effect with the added bonus of combustion chamber cleaning, that could probably compensate for potentially increased coking due to WVO injection... In other words, I was looking at increasing combustion efficiency while keeping the combustion chamber clean to allow safe use of WVO... __________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 |
#111 |
I bet you do Neither ![]() __________________ ------------------ a white Landcruiser - now with Track Tactical! |
#112 |
Great intercooler thread!
#113 |
Yeah its more like I try and I still get it wrong heh.
#114 |
Hi there,
I had a Safari Intercoler installed on my HDJ80 Landruiser. They did the install while the vehicle was strapped down on their dyno. Did a run before and got 79Kw at the rear wheels. Did the install and then did a run after adjusting the fuel. Seeing as I do not have an EGT guage fitted we adjusted the output back to 97Kw at the rear wheels. Saw 120Kw on one run but the exhaust was a bit black and thick so we dialed the fuel back for the 97Kw output. Fuel economy dropped a very small amount and is very related to the right foot. The more fun you have the less fuel economy you get. Very worthwhile thing to do though. Cheers Hedley __________________ Mine 1992 HDJ-81, Triple Locked, Factory Sun Roof, Safari Intercooler, Airtech Snorkel, Milford Cargo Barrier, Ome 2" lift, Warn XP9000, Hella Rallye 2000's ARB Winch Bar. Hers 1992 HDJ-81, Triple Locked, Factory Sun Roof, Milford Cargo Barrier, ARB Winch bar, Hella Rallye 2000's, Safari Snorkel. |
#115 | |
#116 |
Yep, bone stock except for an OME suspension kit that was fitted because the std springs had given up th ghost.
