Old 05-16-08, 08:33 AM   #91
lshobie's Avatar
lshobie is on a distinguished road
Very nice post - I will move my controller this weekend. Man, some good tips pop up on this board eh.
Thanks very much.
Louis
Louis
Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/
Join the IVOAC here to keep JDM's coming - www.ivoac.ca
Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca
lshobie is online now   Reply With Quote
Old 05-16-08, 12:17 PM   #92
crushers's Avatar
crushers is an unknown quantity at this point
nah, that is the fertilizer under the bush...
[quote=BillyGHusk;3322586]is that the little red berries on the holly bush?
QUOTE]
Old 05-16-08, 04:34 PM   #93
Dougal is on a distinguished road
Originally Posted by nicks90 View Post
2) EGT can be reduced by lowering the boost pressure in the inlet due to restrictive intercooler.
correct. Most diesel turbos have a wastegate to control the amount of boost they deliver. this is usually situated right after the compressor.
Adding restrictions to the inlet after this point will rob the intake manifold of pressure - because the wastegate doesnt care where the final restriction is, it just knows its hitting 15psi and opens!
This loss of boost at the cylinder can be offset by the greater density/lower temps - therefore producing simillar overall power and hence why some people notice no power increase or decrease when running an i/c
solution!!! - the wastegate is usually operated by bleeding pressure from the compressor side via a small tube. relocate this tube onto a tapped hole on the intake manifold, This will ensure the boost pressure at the cylinder will be 15psi irrespective of what restrictions are between the compressor and inlet manifold. As long as the restrictions are sooooo massive as to exceed the possible boost deliverable by the turbo (very very unlikely) then it works very well.
this is standard practice on tdi defenders when fitted with full width intercoolers. Boost would normally drop by 1psi - simply relocate the pipe and you regain the boost.
Downside of an i/c - increased turbo lag
1) you are pressurising an increased volume of air between the compressor and the cylinder. Takes longer
2) if the i/c is causing significant restrictions to air flow - add some extra lag to the above.
all this arse about mapping turbos has already been done - by TOYOTA! They mapped the appropriate turbo characteristics to the appropriate engine. Adding an intercooler into the mix makes no difference to the volumetric capabilities of the engine (you aint changing head design or valve sizes or displacement) and the volumetric capabilities of the turbo supplying it.
On point 2. That increases boost, doesn't decrease it. The extra air reduces egt's.
And your last point about volume flow.
Intercooling increases the volume of air that a turbo and engine has to move.
Where do you think those extra air molecules you're cramming into the cyilnders come from?
Old 05-16-08, 07:47 PM   #94
Talos's Avatar
Talos is on a distinguished road
...hope this works.
-1971 Toyota FJ-55 44" 302 etc.
-1993 Toyota Carina E 2,0 GLi
-1987 Toyota HJ-61 38" 12H-T http://forum.ih8mud.com/showthread.php?t=134457
Hj-61 intercooler: http://forum.ih8mud.com/showthread.php?t=181830
Talos is offline   Reply With Quote
Old 05-17-08, 08:57 AM   #95
83bj60's Avatar
83bj60 is on a distinguished road
Excellent posts of late! I was also wondering, and found suspicious, that a temperature drop of X would produce the same temperature drop in the exhaust. I believe the effect of increased oxygen availability/air pressure on combustion efficiency and flame front speed was forgotten, and can explain why in real life the EGT temperatures drop in fact by a much wider margin than what is simply produced by the intercooler intake temperature drop.
Now let me add another question to this discussion: what about use in winter time when temperatures are extremely cold? Shouldn't the intercooler be bypassed when air is very cold, or when the engine is cold? Hasn't anyone noticed that the engine seems to work at its best around 10C, indicating a real effect by intake air temperatures?
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
83bj60 is offline   Reply With Quote
Old 05-17-08, 05:24 PM   #96
If your engine struggles to keep operating temp then it could be worthwhile.
Otherwise colder is better.
No need to bypass it, a piece of cardboard stopping airflow would do.
Old 05-17-08, 08:39 PM   #97
83bj60's Avatar
Originally Posted by Dougal
No need to bypass [the intercooler], a piece of cardboard stopping airflow would do
D'oh! Why didn't I think of it myself... Now you're talking practical!!!... Hmmm.. How about a thermostatically controlled rad louver to control the cooling then , hehe...
I've been thinking intercooling lately not only because the warm weather is finally upon us, but because I'm seriously thinking about converting to [at least part-time] WVO fueling, and was thinking that probably, a great dual purpose installation for cooling AND keeping combustion clean, would be water injection... Seems so much simpler...
What do you guys think of the idea? Just wondering if it hasn't been tried already...
Old 05-17-08, 11:40 PM   #98
gerg's Avatar
gerg is on a distinguished road
Water injection is done all the time, but It would be my last choice for cooling charged air. It seems like a much more labor intensive/ potentially dangerous option, depending on how you do it I suppose.
Inter-cooling is pretty much a bolt on and forget solution.
That being said... I plan on do it to mine, but more for all out power than a regular use item.
G
There is no such thing as a stupid question... just stupid people.
gerg is offline   Reply With Quote
Old 05-19-08, 03:36 PM   #99
Tapage's Avatar
Tapage is on a distinguished road
For water injection .. I will choose propane injection for the same results.
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 05-19-08, 07:01 PM   #100
83bj60's Avatar
Water injection cools the charge air and steam cleans the combustion chamber, while propane adds fuel and increases burning efficiency. A bit different, wouldn't you say!
Old 05-20-08, 07:44 AM   #101
crushers's Avatar
actually, propane also cools the charge...
but yes different...
Old 05-20-08, 02:43 PM   #102
Tapage's Avatar
At the end what you you want it's more powa .. so water / propane injection are diferent but the same target ..
How much dificult are .. in the long term maybe propane should be more expensive, but water more dangerous .?
Old 05-20-08, 10:08 PM   #103
gerg's Avatar
I would use caution and alot of math before doing either.
G
Old 05-20-08, 11:53 PM   #104
Propane only cools when it's expanding from liquid to gas, when it's burnt it releases far more heat.
If it didn't, then cigarette lighters wouldn't work.
So if you're substituting diesel for propane, you can end up with a slightly lower EGT, but if you're adding (instead of substituting) propane onto your full shot of diesel then you're increasing EGT's markedly.
Basically.
Swapping liquid fuel for gaseous fuel = slightly lower EGT.
Same amount of liquid fuel + gaseous fuel = higher EGT.
Old 05-21-08, 10:25 AM   #105
crushers's Avatar
exactly.
end of discussion.
Originally Posted by Dougal View Post
Propane cools when it's expanding from liquid to gas,.
Old 05-21-08, 10:56 AM   #106
Tapage's Avatar
But more powa .?
More powa compared to the same setup but instead of propane, water mist injection ?
Old 05-21-08, 10:56 AM   #107
83bj60's Avatar
OK, got it... Slightly lower egt at same energy output... So basically a great mod if you want slightly more power while maintaing similar egts...
Economy wise, though, I'm not convincved... I just got my propane bill, and it's steep! Prices here a way higher than what you pay for the stuff out west... Same with Diesel, of course (1.49.9 last week), but I presume the difference for diesel is not that high...
But what about water injection? It should cool the air charge, increasing oxygen content and clean the combustion chamber at the same time, a win-win situation, don't you think? Plus it shouldn't be so hard to make/install? What's the status of research on water injection in diesel engines? Anyone know the latest developments?
Old 05-21-08, 11:46 AM   #108
joshoisasleep's Avatar
joshoisasleep is on a distinguished road
nobody's mentioned hydrogen injection... there's a great thread on it in the alternative fuels section
BJ62, 3b, H55F 5spd, turbo, A/C, P/S, winch, badass bumpers, defender rack.
Facing the music... above 100% rust free diesel expedition cruiser may be up for grabs in 4-6 months time. Shown/delivered anywhere in North, South, Central America.
www.wanderinglost.com
group for mudders in latin america
joshoisasleep is offline   Reply With Quote
Old 05-21-08, 02:20 PM   #109
There's a lot of BS around about that too. People claiming 100% improvement in mileage from a device that produces about 1 bubble of hydrogen in every room full of air your engine breathes.
I'd give those a miss.
Old 05-21-08, 09:13 PM   #110
83bj60's Avatar
Well any fuel added is probably not going to reduce net fuel consumption and my not really improve efficiency like intercooling will...
The reason I was asking about water injection was precisely for that cooling effect with the added bonus of combustion chamber cleaning, that could probably compensate for potentially increased coking due to WVO injection...
In other words, I was looking at increasing combustion efficiency while keeping the combustion chamber clean to allow safe use of WVO...
Old 05-23-08, 03:19 AM   #111
matt 105's Avatar
matt 105 is on a distinguished road
G
I bet you do Neither
a white Landcruiser - now with Track Tactical!
matt 105 is offline   Reply With Quote
Old 05-23-08, 03:20 AM   #112
matt 105's Avatar
Great intercooler thread!
Old 05-23-08, 07:26 PM   #113
gerg's Avatar
Yeah its more like I try and I still get it wrong heh.
Old 06-08-08, 01:30 AM   #114
Sarmajor's Avatar
Sarmajor is on a distinguished road
Cool Safari Intercooler
Hi there,
I had a Safari Intercoler installed on my HDJ80 Landruiser. They did the install while the vehicle was strapped down on their dyno. Did a run before and got 79Kw at the rear wheels. Did the install and then did a run after adjusting the fuel. Seeing as I do not have an EGT guage fitted we adjusted the output back to 97Kw at the rear wheels. Saw 120Kw on one run but the exhaust was a bit black and thick so we dialed the fuel back for the 97Kw output.
Fuel economy dropped a very small amount and is very related to the right foot. The more fun you have the less fuel economy you get.
Very worthwhile thing to do though.
Cheers
Hedley
Mine 1992 HDJ-81, Triple Locked, Factory Sun Roof, Safari Intercooler, Airtech Snorkel, Milford Cargo Barrier, Ome 2" lift, Warn XP9000, Hella Rallye 2000's ARB Winch Bar.
Hers 1992 HDJ-81, Triple Locked, Factory Sun Roof, Milford Cargo Barrier, ARB Winch bar, Hella Rallye 2000's, Safari Snorkel.
Sarmajor is offline   Reply With Quote
Old 06-08-08, 01:40 AM   #115
Originally Posted by Sarmajor View Post
Hi there,
Cheers
Hedley
Sounds good, was it bone-stock beforehand?
Old 06-08-08, 12:48 PM   #116
Sarmajor's Avatar
Cool Intercooler
Yep, bone stock except for an OME suspension kit that was fitted because the std springs had given up th ghost.
Cheers
Hedley
