Old 04-29-08, 04:19 PM   #31
NStimac's Avatar
NStimac
Dougal what about the hot @$$ turbo your passing all this air through. How hot do you think it is 400-200 F. Never minding the fact that a turbo isn't 100% efficient (like your math implies). Ideal gas laws are ideal. What's happening under the hood isn't. 10psi + you will see a gain from an ic. Below that you might see a drop in EGTs but performance wise you might not be gaining anything.
86 BJ70 Turbo/Intercooled 33x9.50 BFG MT's OME ARB Bumper -
96 FZJ80 Locked Subtank OME '851/860 305 MT's Murdered Out
Tornado Alley Cruisers
NStimac is offline   Reply With Quote
Old 04-29-08, 04:32 PM   #32
Dougal is on a distinguished road
Originally Posted by NStimac View Post
Dougal what about the hot @$$ turbo your passing all this air through. How hot do you think it is 400-200 F. Never minding the fact that a turbo isn't 100% efficient (like your math implies). Idea gas laws are ideal. What's happening under the hood isn't. 10psi + you will see a gain from an ic. Below that you might see a drop in EGTs but preformance wise you might not be gaining anything.
The turbo compressor doesn't pick up any significant heat from the exhaust. Mainly because the bearing core is cooled by engine oil and is quite a long path for heat to conduct along.
My maths is based on a 70% efficient turbo compressor, I have temperature measurements to back them up and since your average turbo compressor map plots from 65% to 74% it's a good figure to use.
At 15psi with the T25 I measure 115C
Calculated at 70% effiicency I get 113C
Using an IHI turbo with a damaged compressor wheel (dust erosion) 15psi resulted in over 140 deg C, the equivalent of 55% efficiency.
Dougal is online now   Reply With Quote
Old 04-29-08, 05:03 PM   #33
MICKruiser is on a distinguished road
humm, trolling?? since when is asking a question about a statement trolling.
you said "A turbo working far outside it's best efficiency point"
and
i stated: "you are saying a company that designs turbos for particular applications is doing an improper job...correct?"
but if you can not answer the question then that is fine.
Hmmmm, good question about the conflicting ic info.
Confusing! I am thinking turbo and intercooler for my 1HZ so this is a pretty important point.
Some people saying 100 - 200 degree less EGT's and someone else saying it's a no go. . .
What's up?
Michael
BJ60 - sold
HZJ77
MICKruiser is offline   Reply With Quote
Old 04-29-08, 05:21 PM   #34
The Dude's Avatar
TLCA# 8113
The Dude is on a distinguished road
I think that it's just that, the efficiency of the turbo. I wouldn't doubt that we are running our turbos at less then premium efficiencies.
If you went to a shop and ask for a turbo for X truck not running an IC and asked the same shop for a turbo for X truck (the same truck) with an IC they would most likely give you too different turbos???
So I think the answer to Waynes question is yes, for the intercooled truck they gave you the wrong turbo. (or maybe just not the "best") and with those of us that see the 100-200* drops are running higher boosts then what is considered efficient for our turbos.
Clear as mud?
I belive the max boost I can get out of my turbo is 16psi and I am running it at 14. I would like to change that to a turbo that can hit 20-22 and run it at 15.
But what do I know.
Brad T
88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs...
78 BJ 40/42/60
The Dude is offline   Reply With Quote
Old 04-29-08, 05:38 PM   #35
lshobie's Avatar
lshobie is on a distinguished road
I think you have to work with what you have and use the closest fit that you can get. I'll take a video of the intercooler doing it's job and lowering the EGT's.
You can deal with theoreticals and actuals, the theoreticals being the perfect model and the actuals being the results of what you are using. You can keep spending money and adding more bells and whistles but eventually your gains get smaller and smaller percentage wise - and at what cost? If you have a 1HZ and you turbo it it is awsome depending on what turbo you are running, add an intercooler and you'll see more benefit, add a boost compensator and see better fuel economy and better performance, remove the air to air intercooler and replace it with a glycol/air intercooler and see better performance, chop off the stock exhaust and add a mandrel bent 3 or 4 inch pipe and see more gains, port and polish the intake and exhaust manifolds and the head and see even more gains. Get the idea?
Turbo your rig, when you can afford an intercooler add one, if you don't believe an intercooler works then do more research until you find out that it does if installed properly.
Dougal, If i use a heat detector on a turbo compressor are you saying that I will only get somewhere over 100 degrees? Not trolling - just asking a question.
Louis
Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/
Join the IVOAC here to keep JDM's coming - www.ivoac.ca
Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca
lshobie is offline   Reply With Quote
Old 04-29-08, 05:39 PM   #36
matt 105's Avatar
matt 105 is on a distinguished road
Originally Posted by MICKruiser View Post
What's up?
Well, theres some first hand experience here from people who have done it, and theres some "info" here from someone who read about it on the internet.
Contact Air Power Systems (Safari) or DTS (MTQ) turbo systems who sell turbo kits and intecooled turbo kits (for the same engine). They have web sites, too.
I used to fit these, and some Dyno time, Air fuel ratio and max EGT was part of the instalation, for warrentee.
Matt
a white Landcruiser - now with Track Tactical!
matt 105 is offline   Reply With Quote
Old 04-29-08, 05:47 PM   #37
What boost level?
With 10psi boost you'd have something wrong to be reading over 100C in the airstream. The housing itself with probably be a little cooler than the air coming out.
With 15psi boost you'll be over 100C, up to 150C in unfavourable conditions.
The "something wrong" could be a hot air intake, damaged compressor wheel or turbo working outside the map the makers intended.
All these things result in more heat in the airstream.
I appear to be the only one here with any real measurements.
Old 04-29-08, 05:48 PM   #38
matt 105's Avatar
Not quite sure what you mean by this?
Old 04-29-08, 05:50 PM   #39
matt 105's Avatar
Will this thread make another 3 pages and then get deleeted?
Old 04-29-08, 05:56 PM   #40
What is your turbo?
If it's a garrett then a smaller A/R exhaust housing may be available. If it's a toyota then you get what you're given.
More fuel and higher EGT's will net you more boost, but this often isn't a good idea.
Old 04-29-08, 06:03 PM   #41
If history is anything to go by............
Old 04-29-08, 06:13 PM   #42
lshobie's Avatar
Ya Dougal that makes sense - the incoming air temps - been a long day here.
Regards,
Louis
Louis
Old 04-29-08, 07:33 PM   #43
cruiser_guy's Avatar
TLCA# 16387
cruiser_guy is on a distinguished road
No reason to right now! We're having lively discussion, even disagreements (what a surprise !!) but no personal vindictive attacks. I have no problems here at all
'82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 33's, PERFECT frame!
'76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, factory A/C, factory PTO winch!
www.wirrell.com
Old 04-29-08, 08:16 PM   #44
The Dude's Avatar
TLCA# 8113
Originally Posted by Dougal View Post
What is your turbo?
Yup, stock Toyota on the 12H-T
Brad T
78 BJ 40/42/60
Old 04-29-08, 08:50 PM   #45
joshoisasleep's Avatar
joshoisasleep is on a distinguished road
What boost level?
Bear with me I'm not sure if I've read this right. So then a good test to see whether your turbo is running outside its best efficiency would be to measure the surface temp of the pipe running from the turbo cold side to the intake manifold? Or the housing of the cold side of the turbo itself?
BJ62, 3b, H55F 5spd, turbo, A/C, P/S, winch, badass bumpers, defender rack.
Facing the music... above 100% rust free diesel expedition cruiser may be up for grabs in 4-6 months time. Shown/delivered anywhere in North, South, Central America.
www.wanderinglost.com
group for mudders in latin america
joshoisasleep is offline   Reply With Quote
Old 04-29-08, 09:03 PM   #46
Yes. But to get a reasonably accurate reading off the pipe, you'll need to insulate it from the cooler outside air. Off the turbo housing won't give you a good reading.
Drilling a port into the pipe so you can thread a temp sensor inside is the best way, that's what I did.
Old 04-30-08, 04:08 AM   #47
lshobie's Avatar
So - somethin glike this would be good to measure temps before and after an intercooler as well?
Digital Thermocouple Thermometer K-Type Temp High C F - eBay (item 140228574551 end time May-01-08 09:20:26 PDT)
Louis
Old 04-30-08, 12:14 PM   #48
Tapage's Avatar
Tapage is on a distinguished road
There is a device that can read the rpm on the turbo axle shaft .?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 04-30-08, 12:48 PM   #49
Talos's Avatar
Talos is on a distinguished road
regarding EGT drops due to intercooling, let me quote Hugh MacInnes in his book "turbochargers"
as a rule of thumb one-degree decrease in intake manifold temperature will give a one-degree drop in exhaust temperature.
Page 88.
-1971 Toyota FJ-55 44" 302 etc.
-1993 Toyota Carina E 2,0 GLi
-1987 Toyota HJ-61 38" 12H-T http://forum.ih8mud.com/showthread.php?t=134457
Hj-61 intercooler: http://forum.ih8mud.com/showthread.php?t=181830
Talos is offline   Reply With Quote
Old 04-30-08, 02:30 PM   #50
Yes, the one I have is quite similar.
I rewired my pyro probe with the same mini K type connectors (those yellow two prong ones) so I have plug and play between that and my mobile K type probes.
Tapage, there is a method somewhere on the net to use a hall-effect sensor or similar to read turbo rpm.
It'd be interesting, but it's a lot of work.
Talos, that is my point exactly. To get 200F drop in EGT's you need intake temps that can lose 200F. To get charge temps that hot at 10psi suggests something is wrong.
Old 04-30-08, 03:35 PM   #51
lshobie's Avatar
Ah, ok, that is very interesting, and when taken literally I see what you mean, perhaps in my explanation I don't "explain" it properly. In fact it's pretty hard to explain what is heppening with the egt's unless you see it. I'll have to video it next week, but I need to set it up so you can see my rpm as well I suspect.
Where I notice the difference is when accelerating to high speed and I can see by the EGT's where the intercooler starts doing its business. At about 80-90 kms/hr with my foot to the mat the egt's stop rising (or atleast slow down very significantly) and then eventually they start to rise again when approaching the speed of sound (ok - not that fast).
Still not sure if I explain it very well. Where I see the difference and say that I am seeing a 200 degree difference is in that area of acceleration where the egt's stop rising - and where it would have been to 1200 without the intercooler. And it was a very poor way to explain it.
I can see why this is done by calculations on paper to get exacts results as there are many variables when trying to do it on the asphalt.
I'm going to buy those probes and see what mine is doing.
Louis
Old 04-30-08, 04:37 PM   #52
What is the boost level doing in that situation?
Old 04-30-08, 04:41 PM   #53
lshobie's Avatar
If I have my foot to the floor the boost is pinned at 12 pounds.
Louis
Old 04-30-08, 04:49 PM   #54
The Dude's Avatar
TLCA# 8113
That is very similar to my situation as well except I am running 14psi boost.
Brad T
78 BJ 40/42/60
Old 04-30-08, 05:01 PM   #55
