#151 | |
You were the one who brought up the Brayton cycle. I researched it and proved your VOODOO engineering is truly in your head. eric __________________ 1974 FJ/BJ 40 3/4 Mutant, 3B, Turbo, and Odie the yellow lab ridin' shotgun! http://forum.ih8mud.com/diesel-tech-...-mutation.html Engineering: Not doing anything with a dollar and spending 4 more on internet access instead of owning a Landcruiser! |
#152 |
I disagree Otterav. If you look at a gas turbine (Compressor, combustion chamber, turbine), a turbocharged engine runs off of the same cycle. Granted that the engine (combustion chamber) is more complicated than in a turbine, the turbo's turbine does draw from the exhaust gases to run the compressor that in turn feeds the engine air.
Check this out. A turbocharger that looks strikingly similar to a jet engine. I don't think there is any vodoo, just a different application of the principal. TechNudge DIY Jet Engine And on a side note... does anyone know what the combustion chamber volume is for a 3B? G __________________ There is no such thing as a stupid question... just stupid people. |
#153 | |
The joule cycle is not the brayton cycle, but to a layman the similarities may cause confusion. The ericsson cycle model is based on isothermal compression (no charge heating), the Brayton on adiabatic (air heats as it compresses). I'd expect everyone here to know that turbo compressors cause air to heat and hence understand why the Brayton cycle is the applicable one. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#154 |
OK OK OK... I want a jet powered canoe!
Untitled Document So does 42cc sound about right for a 3B combustion chamber volume? Thanks G __________________ There is no such thing as a stupid question... just stupid people. |
#155 | |
Bore = 102mm Stroke = 105mm So Displaced volume = 858cc Comp ratio = 20:1 So clearance volume = 857/21 = 40.8cc. Total volume = 899cc __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#156 |
Ahh thanks. I wasnt sure if I divided by 20, or 21.
#157 | |
Whatever eric What part of this basic theory don't you understand? Ideal Brayton cycle: * isentropic process - Ambient air is drawn into the compressor, where it is pressurized. * isobaric process - The compressed air then runs through a combustion chamber, where fuel is burned, heating that air—a constant-pressure process, since the chamber is open to flow in and out. * isentropic process - The heated, pressurized air then gives up its energy, expanding through a turbine (or series of turbines). Some of the work extracted by the turbine is used to drive the compressor. * isobaric process - Heat Rejection (in the atmosphere). Actual Brayton cycle: * adiabatic process - Compression. * isobaric process - Heat Addition. * adiabatic process - Expansion. * isobaric process - Heat Rejection. __________________ 1974 FJ/BJ 40 3/4 Mutant, 3B, Turbo, and Odie the yellow lab ridin' shotgun! http://forum.ih8mud.com/diesel-tech-...-mutation.html Engineering: Not doing anything with a dollar and spending 4 more on internet access instead of owning a Landcruiser! |
#158 |
Holy crap I think im deaf now!
I say victory goes to the guy who can use a word with the most syllables in a sentance correctly. So if there is heat loss across a turbochargers turbine, I assume that some of this heat is soaked into the turbo itself, and some is transfered into mechanical energy, and the rest dumped out the exhaust. Would it make sense in a compound turbo set up to have the larger turbo first with the smaller turbo second in the exhaust stream? That is assuming there is less potential energy (heat) available for the second turbo to work off? Ohh and by the way, I just love all you guys. Big hugs for everyone ![]() G __________________ There is no such thing as a stupid question... just stupid people. |
#159 | |
![]() You'd better tell us what problem you have with that description of isobaric? See turbo operating conditions often result in backpressure and boost being equal pressure. When they don't you simply change the pressure at that part of the cycle. It's not that difficult. Time to update my sig too. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#160 |
Wow I can't wait til I can get around to reading the last 2 or 3 pages of this thread later tonight. I had no idea it had exploded so much... my own thread!
Just to clarify, I haven't been arguing either side, know nothing about turbos, and am stupid enough to drive a newly installed one cross country loaded to the gills in high heat with no egt or boost gauge. I look forward to voicing my opinion! |
#161 |
#162 | |
![]() On a serius note: Josh, time you get your pyro installed and let us know what happen there .. |
#163 | ||
An aircraft EGT gauge is on its way to me that will have a dual reading, EGT on one side and intake air temp on the other. Only thing is they have clamp style probes... I asked him for screw in but I guess he's decided I'd be better off with clamp style. What's the disadvantage here? Quote:
What are we all doing messing about with landcruisers?! With global warming these things are what will be ruling the streets in a few years time! Last edited by joshoisasleep; 05-15-08 at 01:53 PM. |
#164 |
Mod in Hibernation
Thread closed for evaluation. Seems like too much bad blood in here.
__________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
Internet Advertising | Online Advertising | Free Advertising | Loans | Credit Card Debt Consolidation |
