Old 05-15-08, 12:56 PM   #31
joshoisasleep's Avatar
What do you guys think of the idea of changing an exhaust manifold gasket clearing up a serious oil disappearing problem? Does that sound plausible? Because it seemed to happen...
Sometimes I drink and post...
Adventuring in my BJ-T62
www.wanderinglost.com
joshoisasleep is offline   Reply With Quote
Old 05-15-08, 01:13 PM   #32
BlueHZT60's Avatar
TLCA# Yep
Originally Posted by BlueHZT60 View Post
Alright, here's a fun one: I just popped the hood (60 w/hz-t), I have oil staining on the top airtube at the manifold & at the turbo. ARGH!! - did I smoke a turbo in less than 15,000 miles/ 2 years? OR do I just have a VSV valve missing, or some other easy fix? We'll see soon.
The only other oil drib is out of a couple TC bolts - 1 drop every 2 weeks. BOB
It was bad turbo seals. All fixed now, 1,000 miles on it and no oil leaks on the Hz-60 - none. And yes, I know that is a temporary situation. Bob
BlueHZT60 is offline   Reply With Quote
Old 05-15-08, 01:27 PM   #33
Can you elabourate any more on the above?
Old 05-15-08, 06:59 PM   #34
owensexport's Avatar
TLCA# 2305
HZJ77 with 1HZ - Rear main seal leak... Only after long distance
driving... Drops about 5 or 6 drops and then stops. 200,000 kms on the engine.
1991 HZJ77
1965 FJ45SWB - Project #865
1967 HQ15 Weapons Carrier - Project #721
1964 FJ45 Fire Truck (GONE!) - 1981 LD10 Blizzard (GONE!)
1967HJ45 (Sold!) - 1966 FJ45LV (Sold!) - 1965 FA80 Fire Truck (GONE!)
1965 UP10 Publica - Military: Too Many
owensexport is offline   Reply With Quote
Old 05-15-08, 11:43 PM   #35
peterdouglas's Avatar
Hmmm... maybe my BJ60's oil leak isn't so unique after all then! I thought it was possessed. Sometimes it leaks, sometimes it doesn't. 3B with 332,000 kms. Just changed rear main oil seal plus a bunch of others (but not head gasket). Sometimes leaks coolant and possibly transfer case oil too. And sometimes it doesn't.
I thought the leak gremlins were paying me a visit. For more details, check out this thread.
1984 BJ60 (stranded in Ontario) • 1986 Jetta Diesel (my DD) • propane powered 1995 Ford Errorstar
peterdouglas is offline   Reply With Quote
Old 05-17-08, 12:28 AM   #36
IH8HILLS
Granite Grinder's Avatar
TLCA# 1539
Originally Posted by Benihana View Post
I'm looking around the Lower Mainland for gaskets, especially oil pan, any sources people? . Anyone know a good mechanic for re and re of that?
BK
I used Toyota FIPG black (Form In Place Gasket). No cork required.
See this post about IP's or injectors:
http://forum.ih8mud.com/diesel-tech-...tor-pumps.html
Fred Holmes or Jim's Fuel Injection
GG
1977 - FJ40-V8-SM420-ARB's,SOA (Ducky)
1987 - HJ60-OME,Turbo'd,4.56 (Silver)
1987 - HJ60-Work in progress (Clementine)
1985 - BJ60-3B-Belton lift (FunOne)- 2008 RIP
Granite Grinder is offline   Reply With Quote
Old 05-20-08, 12:14 PM   #37
TLCA# 2305
I always say if you dont see any drips, you have a problem.
It means there is no oil in there
1991 HZJ77
Old 05-20-08, 02:32 PM   #38
bunja's Avatar
3B-300K miles daily driver, does not leak a drop. Was leaving fuel here or there from the fuel tank, JB weld fixed that quick though.
bunja is offline   Reply With Quote
Old 05-20-08, 02:38 PM   #39
um.................well................you see the piston rings on my 61 leak oil but obviusly this only provides smoke how ever the extra presure in the block pushes the little oil left out thru a hole on the back of the timing case where a piece of gasket is missing,this leaves a line of drips on any driveway.
P.S. where is the best place to get piston rings?in europe.
hj herby is offline   Reply With Quote
Old 05-20-08, 03:00 PM   #40
canucksafari's Avatar
Try Toyota or try http://www.milneroffroad.com/. If not them, then ask them for ecommendations.
Old 05-20-08, 03:01 PM   #41
Try Toyota or try Milner Offraod in the UK Openads. If not them, then ask them for ecommendations.
Old 05-21-08, 09:11 AM   #42
Update on mine... a few days ago I took my BJ60 on a 40 km drive, when parked it didn't leak a drop of anything. Yesterday I took it on a 600 km drive to Montreal and there were 4 small oil spots on the ground after parking. Not wanting to hijack this thread, I'll post some details and questions in a new thread specific to my BJ60.
Old 07-04-08, 03:13 AM   #43
1985 cruiser
I have a 85 with a 2h that has started oiling up the inlet manifold - via the line from the rocker cover i am thinking valve seals
justannoyed is offline   Reply With Quote
Old 07-04-08, 10:38 AM   #44
I am thinking blow-by from worn rings. I am pressuming the crank case vents up through the block and head to the rocker cover and out the hose into the intake manifold. If you still have good power and no problems with run on, then don't worry about it.
Old 07-04-08, 11:43 AM   #45
mac
rust and moth consumables
mac's Avatar
still not as bad as a Rover shit box...puddles everywhere you stop.
Rovers leak? Must be a Brit thing then 'cause my Norton leaks everywhere- gearbox, crankcase, carbs. It's really funny to pull up next to a guy on a modern bike and see the urgent look on his face as he says,
"Hey, your bike's leaking something!"
"Oh yeah, it came from the factory that way."
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 07-04-08, 02:34 PM   #46
marting's Avatar
Location: I live in Oslo.. the biggest village in Norway
No leaks in my bay! oil-pan is quite rusty.
HJ60..OSLO
marting is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/206691-toyota-diesel-engine-oil-leaks-dont-shy.html
Posted By For Type Date
*Clix This thread Refback 03-24-08 03:19 PM
WASALive ! Oil - IH8MUD.com Forum This thread Refback 03-09-08 09:07 PM
Coupon | Mobile Phones | Payday Loans | Electricity | Mortgage Calculator
