Old 01-18-08, 03:50 PM   #1
RufusTheDufus's Avatar
RufusTheDufus is on a distinguished road
How bad is 285 psi compression in a turbo 3B?
The UPS guy dropped off my compression tester today. I was able to take some readings. 289, 292, 307, 285. So they're at the low end of the spec. Engine has 368,000 kms on it. I have no idea how much of that was with a turbo. A half-dozen drops of 0 - 30 ELF synthetic oil into each cylinder brought the compression numbers up over 400 psi.
So how bad is this? Should I be concerned about the engine failing at some point?
RufusTheDufus is offline   Reply With Quote
Old 01-18-08, 03:59 PM   #2
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
brownbear is on a distinguished road
Did you do the compression cold or hot?
I thought the FSm said to do it hot. Then it's accurate to normal driving conditions.
-91 FJ80, wife's ride
Old 01-18-08, 06:15 PM   #3
Otterav's Avatar
Otterav is on a distinguished road
Ditto,
Ya gotta do it with the engine at operating temp, you might even have to start and run between cylinder tests. The other thing to make sure you are doing is open the throttle butterfly all the way. If you didn't do it this way your results are not accurate.
eric
Otterav is offline   Reply With Quote
Old 01-18-08, 07:46 PM   #4
I did it hot. I had some errands to do and ran it out on the road for 20 minutes. Parked it in the garage, Unplugged the EDIC, pulled the glow plugs and cranked it for each cylinder with the pedal to the floor. It couldn't have taken more than 15 minutes to do the whole thing.
I read the FSM prior to doing the compression check.
Old 01-18-08, 07:57 PM   #5
wesintl's Avatar
TLCA# 4180
wesintl is an unknown quantity at this point
285 is min spec so I would think your ok unless you have poor power and are burning alot of oil. Otherwise it's fine.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
You should be able to delete your own thread. Communists abound
wesintl is offline   Reply With Quote
Old 01-18-08, 11:59 PM   #6
Diesel for blood
roscoFJ73's Avatar
roscoFJ73 is an unknown quantity at this point
If you want it to last keep the revs down ,particuarly for long periods on the highway.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 01-19-08, 12:25 AM   #7
M John Galt is on a distinguished road
That engine has specs like a 50 to 60 year old human. Tired, still in reasonably good shape, but can't compete with a kid in their 20s.
Concerned about how long it will last? How long do YOU expect to live?
If the rest of the truck is in really good shape then overhaul the engine, if not drive it till it dies at about half a million kms.
Quando Omni Flunkus Moritati
Old 01-19-08, 04:07 AM   #8
When these engines die is it a slow death with lots of warning signs or something a little more sudden? The body is in pretty good shape. We were hoping to use it for camping trips to the southwest driving from Maine. (5,000 mile+ trips with lots of highway driving.) I guess that's not such a good idea without an overhaul.
Old 01-19-08, 04:31 AM   #9
Diesel for blood
roscoFJ73's Avatar
IMO you do not have a serious problem yet and providing you dont over stress the rings it will be fine for a few more camping trips yet
Highway trips will be fine as long as you keep the rpms down.
Its already dying a slow and graceful death as the compression figures are close to one another.
Now you know its going to die it will give you a year or 2 to line up an engine rebuilder.
The engine kits for these are cheaper than some gassers.
I guess the next signs will be increased blow by ,oil usage and harder starting in the cold.
Another way of monitoring your engines condition will be to do a comp every few months or so
33 in BFG A/T
Volvo 740 GL
Old 01-19-08, 08:46 AM   #10
I think I'll start planning on a rebuild. I'll order a kit from roodog on Ebay and find a shop to handle it. I know there's a few diesel shops around the specialize in logging equipment engines but they should be able to do the machine work on the 3B too.
Old 01-20-08, 03:35 AM   #11
Ron R's Avatar
Ron R is on a distinguished road
No objections against a rebuild
But keep in mind that this engine is just loosing it's optimum performance. That's all.
As long as you don't need that there is no real need for a rebuild.
If you want to carry out that rebuild now because you're afraid the engine will get damaged because of this degration, then don't worry.
This kind of wear is 'healthy'. No parts will break or suffer damage because of this.
As long as performance is sufficient to you and oilconsumption is within reasonable limits you can postpone the rebuild. Enjoy another 100k k's or so and then do the rebuild.
Then you will have more value for money.
Ron R
1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks.
http://www.ourwebspot.nl/English_index.html
Ron R is offline   Reply With Quote
Old 01-20-08, 08:09 AM   #12
I actually have an extra turbo 3B engine that only has 40k kms on it. (It used to be Lumpy's.) I also have an HJ45 Troopy on the way from New Zealand with a tired 2H in it. My plan was to put the rebuilt engine into the HJ but I think I'll end up tossing it in the BJ. Then I'll rebuild the BJ's motor for the HJ. (Does this make any sense?)
The HJ is more of a long term project. It doesn't need an engine for a while. The BJ is something we plan to use this summer for a cross country trip lasting 8 - 10 weeks. I don't want to have to worry about reliability issues. Since I have a spare fresh engine I might as well make use of it.
Old 01-20-08, 10:23 AM   #13
mac
rust and moth consumables
mac's Avatar
mac is on a distinguished road
That sounds perfectly sensible. I would consider putting a six back in that troopy though. Maybe a 1HZ or 1HD-T.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 01-20-08, 10:44 AM   #14
A turbo 3B should do just about as well in the Troopy as a normally aspirated 2H, no?
Old 01-20-08, 11:26 AM   #15
Ron R's Avatar
Originally Posted by mac View Post
That sounds perfectly sensible. I would consider putting a six pack in that troopy though.
A six pack ?
Ron R
Old 01-20-08, 11:27 AM   #16
mac
mac's Avatar
Yes, actually I would prefer a turbo 3B over a na 2H. Given the weight of a troopy however, I would prefer a 1HZ-T or a 1HD-T and I only suggest it because you'll be pulling the 2H anyway. When you factor in the cost of rebuilding your 3B, add to that what you can sell it for as is- you may come near to the cost of picking up a newer Toyota diesel and be much happier with the performance.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-20-08, 12:23 PM   #17
How does the fuel economy compare. turbo 3B vs. 1HZ or 1HD?
Old 01-20-08, 05:43 PM   #18
Diesel for blood
roscoFJ73's Avatar
The 3B would probably use at least 10% less but a 6cyl is much smoother and has longer legs. Its the long trips where the 6 cyls come into their own
Even without a turbo ,a 1HZ cruises beautifully at 70 mph and 2800. A good 1HZ can attack most hills without too much loss of speed although thats relative to the terrain in your area
33 in BFG A/T
Volvo 740 GL
Old 01-20-08, 06:47 PM   #19
The 1HZ has slightly less power than the 13B-T, but the economy is about the same. If you operate at sea level there isn't much difference, but over 2000ft the turbo makes a big difference.
Old 01-20-08, 06:49 PM   #20
We'll be vacationing in the four corners area and Crested Butte, CO. The turbo will certainly help.
Old 01-20-08, 07:54 PM   #21
mac
mac's Avatar
Actually, it's the other way around- the 13BT lists at 120HP and the 1HZ @ 135HP.
The 13BT is a nice engine but if you were considering a swap you may as well go for a cuurent engine and one that produces the most bang for buck. The 1HZ is a good choice in that respect- turbo it and it reportedly will sing you a wonderful tune.
As for fuel economy- I'm not a tight #'s crunching type but have had many 3B's, a 13BT and now a couple of 1HD-T's and the economy is close. It's within a few MPG's. My 80 is the heaviest and only full time 4wd of my Cruisers and I still can attain a respectable 23MPG. My Bj60 with a 3B was getting approx. 26MPG. Not a big diff to me esp. considering the power gains- 90HP compared to 160HP.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-20-08, 09:05 PM   #22
I guess I should look into how difficult is it to get one of these engines in the U.S.
Old 01-20-08, 09:31 PM   #23
Believe whatever numbers you want, I've driven both at 2500', I was speaking to real power not theoretical. BTW both trucks have about the same 100,000 km, with the same compression to spec.
... and your actual experience behind the wheel?
Old 01-21-08, 09:28 AM   #24
lumpy70's Avatar
lumpy70 is on a distinguished road
I think your compression tester is off by at least 5 lbs. Why? Because diesel will not fire below 290 lbs. If your truck runs, then good. If you are satisfied with the power and performance, also good.
I rebuilt mine when it was at those numbers, but the truck barely ran so I had little choice.
Factory spec is 420 lbs per cylinder.
Craig.
www.rmlca.ab.ca
'85 BJ74 in a LHD conversion, in pieces
'95 FZJ80 burning oil
TLCA # 13682
lumpy70 is offline   Reply With Quote
Old 01-21-08, 10:31 AM   #25
mac
mac's Avatar
Since when are published HP #'s theoretical? Do you think Toyota just pulls these #'s out of their ass based on how the truck feels ? This wasn't an attack on you personally Galt it was simply a stating of the facts.
My behind the wheel experience? Plenty of it. But it's not something I feel the need to prove to you.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-21-08, 03:12 PM   #26
I have a new Mightyvac digital compression gauge. I think my low reading might have something to do with the glow plug adapter I was using.
Old 03-06-08, 11:40 AM   #27
Radd Cruisers is an unknown quantity at this point
Was the throttle plate held open during the process?
~John
Check out our new location in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - all hardware included
Limited Quantities - Deposit or Full Payment Required to hold your order while they ship
