will an 83 bj60 5 speed tranny bolt on an 86 fj60?
please let me know....
Diesel for blood
No ,you need the right input shaft spline count and length __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Cryptic answer... but that's okay.
You will need an H55 from an H, 2H of xF engine to match your FJ60. The "B" H55 uses a much longer fine splined input shaft that is not compatible and changing it out is a fair bit of work to do. __________________ 1978 FJ40 - parts vehicle - PM me 1987 HJ61 VX 5spd - loaded - daily driver 1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa |
what about the stock 4 speed on my fj60? will that mate to a 3b engine without any problems?
If you can not make it work do you want to sell the 5 speed trans?
#7 | |
The F series and H series engines use the same input shaft. __________________ Mike Nyiri '84 BJ 60 - Japanese double military wrap lift springs - Belton AI shackles - 33x12.5 BFG ATs |
Well I am looking for one. Let me know a price?
rust and moth consumables
Your posts tell two different stories. Are putting a 3B in your truck or an H55?
__________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
#10 |
im gonna install a 3b on my 86 fj60 and keep the fj60 4 speed in there.
im gonna store the 83bj60 5 speed ![]()
#11 |
3B with a F/H tranny won't work. You will need to switch out the bellhousing, input shaft, input shaft bearing retainer & throwout bearing retainer from a BJ tranny.
__________________ "Try not to become a man of success, but rather try to become a man of value." -- Albert Einstein 66FJ45/1HD stake bed, 68HJ45, 72FJ40/13B-T - H41 tranny/pto - marks 23% OverDrive |
#12 | |
Fj tranny will not work on the 3b engine w/o modifications listed above. __________________ "if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64 |
#13 |
I have a 3B 4 spd if thats the way you want to go...
Best Regards Gord |
#14 |
You're gona store the 5 speed that came with your 3B and try and make a 4 speed work? Why wouldn't you just put the 5 speed in with the 3B and be done with it. It's a way better combo.
#15 | |
Diesel for blood
#16 |
![]() ok mudders i need your confirmation here.i am about to pick up a 83 3b and 5 speed from a parted out 83 bj60. all i will take from this parts rig is the 3b engine and the attached 5 speed will these two parts work for my 86 fj60 im crossing my fingers......... ![]() ![]() ![]() :hi llbilly:![]() PLEASE LET ME KNOW ASAP. |
#17 | |
im gonna put these two on my fj60 will this work or not? |
#18 |
the short answer is yes.
A 3b with a mated 5 speed can be swapped into an FJ60. It is not a direct bolt in swap. The motor mounts need to be moved. Provisions for the glow system need wired in. I am sure I am forgetting some other obvious yet somewhat minor modifications that need done. GL Tim __________________ 85 FJ60 powered by a 3B(dreaming and planning for turbo) Daily driver |
#19 |
See Mel Lowe's build thread. While he threw a 3B in a 62, it went with the mated H41(or H42). IF the H55F is mated to the 3B, you're golden, but it is a long, hard conversion to be sure. Read Mel's build carefully. Mine (search "evisceration tofudebeest") should help too.
Buy the donor rig, not just the powertrain, even if you have to drag, ship, or tow it home. You will need so many parts not connected to the powertrain that you are not thinking of, you'll end up spending 20X as much to get the parts separately than having them right there in a donor rig. TRUST ME! |
#20 | |
Based on your replies to this thread you are gonna have 2 really cool yard ornaments. Lemme know when you wanna sell the ornaments! I will buy them for cheap! eric ![]() ![]() ![]() :hillbill y:![]()
#21 |
Is the 3B a 24Volt system?
You can convert everything to 12Volt (alternator, glow etc), but there is more swapping (and shopping) to be done. None of the F-engine stuff carries over except some 12Volt vacuum switches. In other words: There will be lot's of electrical issues to deal with!... __________________ N6LG - Extra Class Amateur Radio Operator 1982 FJ40 (HJ41), 12HT turbo diesel, H55, ARB locker, e-locker, Marks Gears, APRS 1997 LX450, 1HT-FT/H151 diesel conversion in process... 1972 FJ40 Fun Beater Rig, Bone Stock! |
#22 | |
The BJ60 will have things like driveshafts, shifter covers, electrical that you will want to have for your FJ. With a Turbo it would be a great engine to have for both longevity and mileage. __________________ 1978 FJ40 - parts vehicle - PM me 1987 HJ61 VX 5spd - loaded - daily driver 1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa |
Online Advertising | Free Advertising | Internet Advertising | Home Insurence | Loans |
