Old 01-10-08, 08:56 AM   #1
Quiet there's a J**P
JONNYFJ's Avatar
TLCA# 18337
Which deisel is better
Ok guys need your opinon on this one. I am going to do the deisel conversion in my 40 sould I go with the Cummins 4BT or the Toyota 1KZT-E. Any input will help Thanks. JONNYFJ
69 FJ40 383 Stroker SM420 3Speed Toyota T-Case SOA ARBs 35 MTRs and more
84 Mini Truck 22RE Stock Tranny Duel T-Cases Flat Bed 35s
JONNYFJ is offline   Reply With Quote
Old 01-10-08, 09:08 AM   #2
a little off of the subject but...
How 'bout one of these.
http://forum.ih8mud.com/diesel-tech-...bd1t-swap.html
I want to put one of these in my 40 some day.
FJ40-40
'74 FJ40
Midlands Cruisers
FJ40-40 is offline   Reply With Quote
Old 01-10-08, 09:18 AM   #3
JONNYFJ's Avatar
TLCA# 18337
Not enough power in the isuzu deisels and they are not intercooled, of course either is the 4BT in a 40
Old 01-10-08, 09:42 AM   #4
Japan4X4's Avatar
13B-T.
Importer and distributor
Japan4X4 is offline   Reply With Quote
Old 01-10-08, 09:52 AM   #5
JONNYFJ's Avatar
TLCA# 18337
What kind of power does the 13B-t have and specs
Old 01-10-08, 10:08 AM   #6
Japan4X4's Avatar
Toyota B engine - Wikipedia, the free encyclopedia
Old 01-10-08, 10:14 AM   #7
JONNYFJ's Avatar
TLCA# 18337
Will this fit in a 40 intercooled???
Old 01-10-08, 10:53 AM   #8
Diesel for blood
roscoFJ73's Avatar
It will fit better than a cummins. The B engines were the 1st diesels that landcruiser's got and the 13BT is a turbo version.
There are also the H 6 cyl engines
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 01-10-08, 11:00 AM   #9
JONNYFJ's Avatar
TLCA# 18337
Does anyone know where I could pick up a 13B-T at and the cost?
Old 01-10-08, 11:22 AM   #10
canucksafari's Avatar
PM Japan4x4.
(edit) ... or Greg or Sheldon at G&S Cruiser Parts
Old 01-10-08, 12:14 PM   #11
boots4's Avatar
What is your requirement for "better"? Reliability, parts availability, engine availability, power, noise level, adaptability? What are you doing with your rig (planned usage)? If you are SOA already then a cummins will probably fit fine. There is a local who is going to put a 4bt in his FJ40 in the next month or two and his rig is mostly a trail rig.
I think the torque figures on a diesel are more important than the hp numbers.
13bt: 118hp 210lb.tq
1KZT-E: 129hp 253lb.tq (numbers converted)
4bt: 105hp 268lb.tq
4bta: 120hp 305lb.tq
4bta are intercooled where the 4bt is not, but you can intercool it just like any diesel. I'm pretty sure you can get more power out of a 4bt than a 13bt. From quick research it looks like the cummins will out power the 1KZT-E and wiring up a 4bt would be easier than the 1KZ too. But the 4bt is not for everyone. Some don't like the noise or the vibs. Both can be controlled but it seems the toyota diesels are quiter and don't shake as much.
I've put a 4bta in an FJ60. I chose a cummins because they are damn good engines, make some good power, availibility here in the states for engines and parts, easy to mod, and because I was infected with the diesel bug.
85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 01-10-08, 12:40 PM   #12
JONNYFJ's Avatar
TLCA# 18337
I am SOA but you see there is not enough room to run a intercooler on a 4BT in a FJ40, Cummins are great but they so freakin loud. My rigs is mainly used for Overlanding so I am most interested in MPG and a comfortable on road ride, but when the time comes I need enough power to go over anything in the way. JONNFJ
Old 01-10-08, 12:42 PM   #13
mac
rust and moth consumables
mac's Avatar
One vote for 13bt. Sweet engine and reliable. Ciaran Wilson @ Cruiserland has one. Search his name here and you'll find his #.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 01-10-08, 12:47 PM   #14
mac
mac's Avatar
http://forum.ih8mud.com/diesel-tech-...ouver-%24.html
His contact info is in this post.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-10-08, 02:03 PM   #15
boots4's Avatar
Really? The 4bt is shorter than the I-6 that was originally in it. It seems like there would be extra space to have and intercooler fit once a I-4 is put in. Were you planning not to move the drivetrain; I could see how that could be a problem. Were you planning on running a mech fan or electric? I think anyone going from a gasser to a diesel needs to plan sound deadening into a swap since these older diesels are louder than gassers. There are some good products out on the market now-days. I've noticed that my 4bta is a little quieter than a regular 4bt. It has a slight lower compression ratio so that might help. There is a dodge durango on 4btswaps.com that reports a comfortable in-cab volumn level with his 4bt transplant so the volumn can be controlled but yes it will never be as quite a today's new diesel engines.
Old 01-10-08, 03:29 PM   #16
sandcruiser's Avatar
there are a lot of kzt motors here in Costa Rica, they are much MUCH quieter than the 4bt, based on my experience.
and they get very good efficiency and have lots of get up and go... but it feels more like a gasser (peak torque feels like higher rpm) than a 4bt.
so take all that into account
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns. WTB: Tan DS mirror & housing
'88 HJ60, "Louie" For Sale in Costa Rica.
sandcruiser is offline   Reply With Quote
Old 01-11-08, 12:28 PM   #17
Tofudebeest's Avatar
Except for a passing reference by Rosco, why is there so far, no discussion of the 2H or 12H-T? While neither are intercooled, the latter has piston-skirt cooling. Canadian support for the former (and it can be turboed fairly easily), though it has a stiffer block and no sleeves. You can get both engines from Aus easily. $OR sells "front clips", but for WAY too much (~$9,000) but what else is new?
Tofudebeest is offline   Reply With Quote
Old 01-11-08, 02:01 PM   #18
it's a wooly worm
Gold Boy's Avatar
Originally Posted by Japan4X4 View Post
13B-T.
even with no muffler the 13bt runs fairly quiet.
off road torque is excellent! imo
BJ74 & TUFT & U-AFPT
Gold Boy is offline   Reply With Quote
Old 01-11-08, 08:23 PM   #19
The 4BD1T has boatloads more than the 1KZ-TE, I have a 4BD1T in a 2.3 ton truck, my brother has 1KZ-TE in a 1700kg truck. There's no contest regarding power or torque, for some reason toyotas don't seem to live up to the numbers.
The put out less torque in factory configuration than a cummins 4BT, because they're tuned to not smoke.
Intercooling or not is up to the installer. I'd suggest you do for any turbo engine.
But both the Isuzu and the cummins are large and heavy engines, the Toy 13Bt would be mean a lot less modification to your vehicle. Being direct injection the 13BT will be a lot more fuel efficient than the 1KZ-TE while starting easier too.
Old 01-12-08, 03:16 PM   #20
How about ISUZU 3.1 4JG2?
dupa is offline   Reply With Quote
Electricity Suppliers | coupon-coupon.com | Secured Loans | Mortgages | Mortgage Loans
