Old 01-09-08, 04:45 AM   #1
BUSTED100's Avatar
Lack of drive on hills
I have a 1HDT auto 80. When out wheeling if I go to drive off from a stand still on any incline/angle, the revs will not go over 1200RPM and there is no drive. It doesn't happen all the time but enough to piss me off. The motor, turbo are all fine, the injectors and fuel pump have been rebuilt, No mater if the gas pedal is flat to the floor the rev's don't get any higher, put it into N and the revs are back.
Help me PLEASE
Any Ideas?
V8 100 GXL - F&R AIR LOCKERS, SNORKEL, ARB FRONT BAR, KAYMAR REAR BAR, WINCH, IPF LIGHTS & 33" MTR's.
T/D 80 Saharra - F&R e-LOCKERS, SNORKEL, ARB FRONT BAR, KAYMAR REAR BAR, WINCH, IPF LIGHTS, 35" MTZ's & 50L WAECO FRIDGE
BUSTED100 is offline   Reply With Quote
Old 01-09-08, 06:40 AM   #2
Diesel for blood
roscoFJ73's Avatar
Help me PLEASE
Any Ideas?
Can you hand throttle it by pulling on the lever at the fuel pump? Was it there before the pump rebuild?
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 01-09-08, 06:51 AM   #3
BUSTED100's Avatar
yes, the problem was there before the rebuild of pump, injectors and the replacement of the turbo. it is a little sluggish of the mark, but I'm getting used to it but when your out wheeling and you stop behind someone and you go to take off ......yeh
Old 01-09-08, 10:42 AM   #4
So if you rev the engine in N it's fine, in D you get this intermittent problem only on inclines?
I don't know much about the 80, but there may be a 'limp' mode that's been activated, which keeps revs below a certain rpm just to get you home when something is amiss...
http://www.4wdtraveller.com/
4x4 travel, adventure, news, and reviews.
gbcruiser is offline   Reply With Quote
Old 01-09-08, 10:58 AM   #5
canucksafari's Avatar
I would check out the TPS. I have seen two similar cases like this on a TD4.2 - lots of revs while parked but put it in gear and bounce it around and you get nothing over a high idle speed. In one case it had to be replaced because it was on an auto (needed for the tranny to work) and in the second case on a standard the owner just removed it. On the Bosch rotary type pump, you will find it on top. I don't have a clue on how to test these things but maybe Rosco knows.
Old 01-09-08, 12:19 PM   #6
Tapage's Avatar
Interesting issue .. I never ear about it .. it's a tranny issue then
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 01-09-08, 01:11 PM   #7
No and yes. Yes in terms that the TPS helps the auto tranny shift correctly in relation to throttle. No, in terms that when these things go they control the butterfly valve. Just like MrMOMo's stuck buttefly valve and no power, a messed up TPS can keep that buttefly valve closed when it shouldn't be.
http://forum.ih8mud.com/diesel-tech-...brownbear.html
Old 01-09-08, 02:55 PM   #8
jus cruzin's Avatar
Help me PLEASE
Any Ideas?
check your gearbox/torqe converter oil levels
Experience is something that you get just after you needed it!
It is better to ask a silly question than to explain a stupid f*** up!
jus cruzin is offline   Reply With Quote
Old 01-10-08, 02:00 AM   #9
BUSTED100's Avatar
levels are fine, check that once back on the flat
Old 01-10-08, 01:04 PM   #10
prado t's Avatar
TLCA# 17424
It does seem like a limp mode. I am not to familiar with the 80 , but it could be a sensor if it happens on an incline it sounds like a fluid level. I heard that you checked all the fluids . coolent ? brake,?
2.5 OME Heavy coils, ARB rear locker PRADO STOLEN
89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
prado t is offline   Reply With Quote
Old 01-10-08, 01:14 PM   #11
mac
rust and moth consumables
mac's Avatar
What year is the 80? A440 or A442 tranny? That will determine whether or not you have a TPS. That said, no 1HDT is electronically controlled so I can't see why it wouldn't rev passed 1200rpm even if your TPS was malfunctioning. The TPS sends a signal to the tranny ECU and doesn't control engine speed. I suppose if the TPS was telling the tranny to put itself in the wrong gear it, i.e., top gear, it could cause it to bog badly.
I would be looking at a fuel supply/ filter blockage.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 01-10-08, 03:39 PM   #12
BUSTED100's Avatar
1993 model
Old 01-10-08, 05:26 PM   #13
Diesel for blood
roscoFJ73's Avatar
I would eliminate the fuel lines and fuel pick up 1st.
There might be something like piece of plastic in the tank wrapping around the fuel pick up on an incline.
33 in BFG A/T
Volvo 740 GL
Old 01-10-08, 08:41 PM   #14
mac
mac's Avatar
1993= A442 electronically controlled tranny w/TPS.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-10-08, 09:58 PM   #15
BUSTED100's Avatar
sorry not sure what the TPS is
Old 01-10-08, 11:40 PM   #16
mac
mac's Avatar
Throttle position sensor.
I'm not sure that is the terminology that Toyota uses on the 1HDT but it is essentially a sensor on the throttle linkage of your injector pump that lets your tranny know what gear it should be in.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-11-08, 03:45 AM   #17
BUSTED100's Avatar
Mac, would that only be affected when on the incline?
Old 01-11-08, 11:00 AM   #18
mac
mac's Avatar
I personally doubt it but stranger things have happened. I only raise the TPS issue because it was mentioned earlier by other posters as having caused issues with other vehicles- I think a Nissan Patrol was mentioned. Maybe just check it for proper adjustment and make sure it is secure and the plug contacts are ok.
I, as I stated before, would be looking first at a fuel supply issue. Check your fuel filter. When you experience this issue again, pull the fuel line to the injector pump and see if you can hand pump a good quantity of fuel using the hand primer on top of the filter. As Rosco mentioned, you may have something in your tank. Any enemies??
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
Old 01-11-08, 05:31 PM   #19
Tapage's Avatar
It's the TPS the Black part over the IP with blue letters Toyota / Denso ?
Old 01-11-08, 06:10 PM   #20
IT looks similar to the TPS on the Patrol:
There are quite a few threads on Outerlimits4x4 of TBS faults causing similar problems in both Toyota and Nissan diesels. They all say that the TBS also controls the butterfly valve's opening and closing. I have no first hand experience with it. only repeating what i have read. I asume the quick test is to observe the butterfly valve on the intake when Busted100 has the problem. If he can't bring the revs past 1200 when sitting on the side hill and the butterfly remains closed then I would assume it is probably related to the control mechanism of the butterfly valve. But there must be another way of testing if the TBS is working properly. I just don't know it...
Old 01-11-08, 09:26 PM   #21
BUSTED100's Avatar
I'll ask some mates regard s to testing this TPS, some one may know
thanks, will let you know how I go
Old 01-11-08, 10:04 PM   #22
mac
mac's Avatar
No butterfly on the 1HDT.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
3dge Viral Emails | Books | Electricity Suppliers | Advertising | Free Credit Reports
