Old 01-08-08, 01:50 PM   #1
jmylie's Avatar
glow plug removal
I checked my glow plugs today and 5 out of 6 are ok.
The bad glow plug is the one closest to the firewall. It almost looks like the other 5 were changed but not the one that is bad.
Is there some reason that removing the 6th glow plug is more difficult than the other 5? Is there some trick that is needed for the 6th plug that the PO did not know about?
Thanks,
Joe
TLCA # 6363
Yankee Toys
Gotham City Land Cruisers
Connecticut Open Access Land Trust
Northeast Association 4 Wheel Drive Clubs
Tread Lightly - Tread Trainer
National Off-Highway Conservation Council
1977 FJ55 - for fun (x2)
1979 FJ40 - the wife's
1986 HJ60 - my dd
2007 FJC - my second dd?
jmylie is offline   Reply With Quote
Old 01-08-08, 02:00 PM   #2
Ron R's Avatar
Not AFAIK. It's a bit difficult to get to it but do-able as long as you have decent tools available.
If all you have is just a hammer and chisel it might get difficult
Ron R
1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks.
http://www.ourwebspot.nl/English_index.html
Ron R is offline   Reply With Quote
Old 01-08-08, 08:49 PM   #3
Diesel for blood
roscoFJ73's Avatar
Thanks,
Maybe when the PO did them last time it had 5 bad and 1 good
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 01-09-08, 11:00 AM   #4
jmylie's Avatar
Well, I hope to find out this weekend (assuming the glow plug come in).
Joe
TLCA # 6363
Yankee Toys
1986 HJ60 - my dd
Old 01-09-08, 12:16 PM   #5
Tapage's Avatar
Not dificult at all .. only I take care on no broke it on the head Wayne said, there it's no problem if it brole, but I use WD-40 and all in my case come easy ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 01-14-08, 02:14 PM   #6
jmylie's Avatar
Very easy, less than 1 banana. Only "issue" was the heater hose making it a bit tight.
My local dealer received the glow plug on Thu (ordered on Mon - 14 left in CA warehouse). Swapped it out on Fri.
Now I'll have to wait for some really cold weather to see if it helps. We won't see single digit temperatures until Sunday.
Joe
TLCA # 6363
Yankee Toys
1986 HJ60 - my dd
Old 01-16-08, 12:15 AM   #7
UpsideDown's Avatar
In general it's a good idea to change out all the plugs at the same time. If they are not exactly the same, there may be some problems with the glow circuit working properly.
The NGK part numbers are generally easy to get and quite affordable. If you want current pricing, please PM me.
1978 FJ40 - parts vehicle - PM me
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
UpsideDown is offline   Reply With Quote
Old 01-16-08, 09:21 AM   #8
Tapage's Avatar
If you need PN just let me know ..
if it's usefull ..
Old 01-17-08, 08:35 AM   #9
jmylie's Avatar
Part numbers are always useful.
Tried getting the glow plugs from NAPA but they could not match any of the part numbers I had. Ended up at the local Toyota dealer.
Joe
TLCA # 6363
Yankee Toys
1986 HJ60 - my dd
Old 10-24-08, 07:53 PM   #10
ohrly?'s Avatar
Got my 24 volt glowplugs in my hand, NGK 3030 Y-178T
-24 volt 1980 BJ40.
-Five 24 Volt Hobbs heavy duty equipment lights.
-32x11.5 GWrench AT's.
ohrly? is offline   Reply With Quote
Old 10-24-08, 09:31 PM   #11
Joe Egolf's Avatar
glow plugs
Hey Joe, What Ct dealer got you the plugs and are they12 or 24 voltsystem?? I had to go to OZ for mine 1981 Bj42 with 3B
1981 BJ42
Joe Egolf is offline   Reply With Quote
Old 10-28-08, 02:05 AM   #12
jmylie's Avatar
Branch Toyota in Watertown.
Talk to Bill in parts, he is the only one there that knows about older LC's.
(203) 758-8261
Joe
TLCA # 6363
Yankee Toys
1986 HJ60 - my dd
Old 10-28-08, 09:22 AM   #13
seapotato's Avatar
TLCA# Reset to Zero....
previous owner of my old bj40 said he had trouble with one of the glowplugs , he got it unthreaded, but the carbon on the element kept it stuck in the hole, and no amount of wiggling or twisting could get it out.
so he bumped the starter.
He said he heard it land on a roof a couple doors down the street, but he never did find it....
not quite the best or safest way, but makes me chuckle when I think of it...
I disagree.
87BJ70 BJ109/55. Bluefish & Grover.
seapotato is offline   Reply With Quote
Old 10-28-08, 03:24 PM   #14
lostmarbles's Avatar
Least he never left the hood/bonnet down
Name's really Tom & I have a 1979 BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A trunk is really a boot...........
lostmarbles is offline   Reply With Quote
Old 10-28-08, 04:07 PM   #15
kim
kim's Avatar
TLCA# 17328
Where there's a will, there's a way.
87 HJ60,86 HJ60 auto,73 FJ40, 82 BJ60, 89 FJ62 and counting...
kim is online now   Reply With Quote
Loans | Reptile Products | Loans | Web Advertising | Mortgage Calculator
