Islander
FJ45 build with 3B diesel
Hey all, I finally decided I should post my progress and seek more help on the overwhelming options on my project. I'll throw up a bunch of photos so you can see where I've come from and where I am.... I'll later get into the current work I would like everyones experience for.
The first pic is when I picked up all my cruiser parts... a short drive and a ferry ride back to the island where I live. The second and third pics are the new home where I laid everything out to begin the project, I built a shed for the work. __________________ 1978 FJ45 1982 BJ42 Islander |
Islander
FJ45 build pics
The next set of pictures, I cleaned up the axles, used the BJ42 axles with the disc brakes. replaced all the seals, new rotors and calipers, new springs on the front and had the rears re-arched to mate the front.
Pulled the 3B out of the BJ. Put in the engine mounts on the FJ45 frame and dropped the engine in. __________________ 1978 FJ45 1982 BJ42 Islander |
Islander
More progress on the FJ45 3B diesel
Then I connected the transmission and drive shafts, had the cab sandblasted and sprayed the inside and undercarriage with a good box liner. After that I mounted the cab.
In the process the weather got colder and I had to close in the shed and put a wood stove to make work enjoyable. __________________ 1978 FJ45 1982 BJ42 Islander |
Islander
FJ45 3B diesel 24v build
So basically the next pics are where I am at.. I have strung out the wiring harness, connected most of the dash, heater, gas tank re-lined and coated, clutch master cylinder and brake booster on the firewall. I kept most everything on the BJ took it straight off, cleaned or replaced and mounted on the FJ. I also installed the power steering box and pump, had to change the shock mounts so it would fit. Anyways, there you go... the next post I will express my desires for what I need to do and find out how you all might be able to direct me. By the way this is the first major project that I have ever worked on. I'm just learning as I go, most of the time I have no idea and spend way more time researching or asking someone else what they did? cheers.
Islander
FJ45 3B diesel help
So now I am in the process of finding a turbo to mount onto a 13bt manifold that I am having sent up this week. I have read about the adaptor you can buy to mount a garrett t3 flange onto. I asked BB but the shop he got his from didn't have them listed. Does anyone know where to get an adaptor for the 13bt manifold.
any other suggestions about what turbo I should use would be great. I'm also looking for the slave cylinder for the clutch, mine is pretty siezed. The ones I have found locally have a wider mount than what fits on my engine. The 3B came out of an 82 BJ42 and I'm in Canada. I'll start with those two things... any help would be appreciated. __________________ 1978 FJ45 1982 BJ42 Islander |
#6 | |
Hey man, I'm digging your build. I learned the same way you are, by piecing together an old fj one bolt at a time. Please keep the pics and progress coming. The bj clutch slave is shorter than the h or f piece. They do not interchange. I picked up a new clutch slave from the local Toyota dealer here in FL. They ordered it for me, and it took only a few days to receive. The slave is rebuild able and Toyota offers a kit for the job. I decided just to replace mine since it was really rusty. I have the Toyota rebuild kit if you are interested. (FREE) pm me The phone number you need for the adapter is 541 267 4331. They can also sell you everything you need to attach the oil fittings and the turbo gaskets. A Garrett Ta 310 is a great turbo. It is from a 85 Mercedes 300td and has a 9psi waste gate. It is an upgrade from the 301 from the 81-84 300d. The 301 waste gate is set a 7psi The 310 has a 2.5 exhaust outlet vs the 301s 2.25 exhaust outlet. Both Mercedes turbos are oil cooled. Some Volvos have Garrett t3s. A few guys here are running them. The Volvo turbos are water cooled and oil cooled. __________________ "if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64 Last edited by mel lowe; 01-07-08 at 10:03 PM. |
Is that a 45 cab?
Humm maybe I should read instead of just looking at the pretty pictures Dude awesome, cab and frame, it looks awesome are you on Quadra? |
Islander
I live in the Comox Valley on Vancouver Island
Cheers __________________ 1978 FJ45 1982 BJ42 Islander |
Islander
Hey thanks Mel, I'll have a look at the turbo suggestions.
#10 |
rust and moth consumables
Really nice work. You should be proud.
__________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
#11 |
I built my turbo system around a turbo a friend had laying around.
The ct-26 turbo from any Toyota (other than a supra) would also be a good choice. You won't need an adapter. __________________ "if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64 |
#12 |
TLCA# Reset to Zero....
Looking good man, gets exciting when it actually starts to resemble a truck and not just a pile of junk that yer wife can't believe you actually paid money for eh?
![]() looks exactly like my project did a year ago at this time... cheers, ryan __________________ I disagree. 87BJ70 BJ109/55. Bluefish & Grover. |
#13 |
Islander
Started my truck... getting closer
Well I fired up my truck for the first time since I started the project over a year ago. I actually started to drive it, but had to hold off as I'm not quite ready. Anyways here are some more photos of what I've been keeping my neighbors up late for... I'll bet they can't wait for me to be done. Pictures are.. my discs onto the rear full floater, my rad sandwiched between the electric fan and intercooler for my turbo... and last pic is the roll bar and rock sliders I've been working on.
#14 | |
Diesel for blood
How will the tray look,somthing like your avatar perhaps? Why the electric fan?Most of us use the standard belt driven fan,it seems to pull more air through __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#15 | |
__________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#16 |
Cool
Keep the pics coming,,,,,,,,,,,,, Love the FJ45's,,,,,,, You guys have so many out west.
1984 BJ42 |
#17 |
Islander
Not sure the details of the flatbed other than it being wood on the frame work... I kinda make it up as I go.
As for the fan.. because I added the power steering the belt was in the way of the fan blade so I would need to space the fan out... and being that I have the intercooler in front I had to pull the rad back. It wasn't lining up. And on top of that the electric fan pulls 4500 cfm.... a powerful fan... plus with it running on a thermostat the fan will continue running even if the engine is stopped which will help the cooling. I have a second alternator to charge a third battery specifically for the fan and other accessories totally separate from the main system. It's all kinda an experiment. Cheers __________________ 1978 FJ45 1982 BJ42 Islander |
#18 |
Islander
Hey Dougal, any info would be great... I'm almost ready to start with the turbo.
#19 |
Islander
Engine question....
Hey guys... I had the engine fired up. I can't believe how smoothly it fired up right away after sitting for almost 2 years...
I had it running then it began to sputter out.. I found a small leak in the return line which I fixed and seemed to help. But shortly after it began to run rough and die. I don't have much for an exhaust on it as I will be changing it all out for the turbo and change everything anyways. Do you think it may be clogged injectors or and issue with the exhaust. It did seem like it was getting the fuel to run then just started to sputter... Any help? Cheers __________________ 1978 FJ45 1982 BJ42 Islander |
#20 |
Location: the bush, Coombs, Vancouver Island, B.C. Canada
the 45 is killer....keep up the good work......fellow islander
__________________ "legalize wheelin" ![]() moterra@telus.net bj60 RIP 71'fj40/3b 6061 aluminum tub in progress
#21 |
Looking good.
That sounds to me like you might have a problem with fuel tank venting. Does it run with the fuel cap off? How about if you just attach the inlet fuel line to a plain old gas can, does that make a difference? How about the fuel filter? Has it been replaced, or has it been idle for the two years? Dan __________________ 1976 HJ-45 (needs restoration) http://forum.ih8mud.com/fj45-owners-...self-into.html 1991 "Faux-Lux"Pickup 4x4 2LT-E/R-150f http://forum.ih8mud.com/79-95-toyota...onversion.html 1979 FJ-40 to BJ conversion http://forum.ih8mud.com/diesel-tech-...ml#post3811936 "Dandelions. You see flowers in these weeds." --Five Iron Frenzy |
#22 |
If it ran and then started to die and sputter , that means that there is air in the fuel system. Get yourself (if you dont already) some fuel conditioner fire it up and slightly crack each injector the farthest one from the Injector pump first and then close it till it really spurts (at idle speed) Be carefull not to spray your eyes or any thing else . If it idles but runs rough and sputters with blue smoke (misses) it is your fuel filter clogged. Awesome Project are you coming to Cruiser Days July 19 on the Mainland ?
Aaron __________________ 2.5 OME Heavy coils, ARB rear locker PRADO STOLEN ![]() 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
#23 | |
I haven't yet finished all the drawings though, give me a few more days. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#24 |
Islander
progress
hey thanks guys, I'll try and figure it out in the next few days... been fabin up the supports on the roll bar, I'm going to rap some kind a steel gratting and protection around the back of cab. Also looking at the trailer hitch... how far out it should stick.
all the best.... Cheers Aaron __________________ 1978 FJ45 1982 BJ42 Islander |
#25 | |
250 597 2500 is for Radd Cruisers. ~john __________________ 1978 FJ40 - parts vehicle - PM me 1987 HJ61 VX 5spd - loaded - daily driver 1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa |
#26 |
I passed you on the freeway in Duncan a couple weeks maybe a month ago, you had the cruisers on a trailor with tarp?
Small world, nice project. __________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
#27 |
you can get the adapter from the states. REAL nice and only $75... i have used a few over the years.
nice build, congrates. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#28 |
The bj45 is looking great!
