Old 12-12-07, 12:38 PM   #1
Finding Part Numbers? RHD Vs LHD
I have a JDM 1989 HJ60 and I need some parts for it. They sold the HJ60 in Canada but I need to some way to check the part numbers are the same between the RHD and LHD 60. It is also easier for me to order parts from the dealership if I have the part number. I have read something about this EPC but does it show RHD LHD differences?
I need a speedo cable and wonder if it's the same?
also need the part number to the Throw-Out bearing.
1989 HJ60 JDM Lifted Locked Winched. 60's The coolest wagons =]
CDN_Cruzer is offline   Reply With Quote
Old 12-12-07, 01:49 PM   #2
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
if you download the EPC you can put your JDM vin number in it and find the exact part number. Also if you put the region as Japan in the EPC they will all be RHD part numbers if there is a difference.
Try to get the download. I use mine all the time.
-91 FJ80, wife's ride
Old 12-12-07, 03:20 PM   #3
amaurer's Avatar
Is there a separate version of the EPC for each region? I downloaded it, and it came with some note about having the JDM database or something.
I've never run it because it has a bunch of weird instructions for installing it, like burning it to CD and copying it around or something... is there an easier version?
"... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908
1982 BJ42 "Krull"
amaurer is online now   Reply With Quote
Old 12-12-07, 03:49 PM   #4
Diesel for blood
roscoFJ73's Avatar
Any Toyota cable that is long enough works. Ive been using a $25 Hilux cable for 4 years.The only difference in the cables is that the Landcruiser has a thick sheath on the out side ,I think that can be slid over your new cable.
Otherwise ,a new cable from the dealer is $$$ No RH or LH cables,just cables.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 12-12-07, 07:21 PM   #5
Thanks for the info!
I installed the one from yankeetoys.com but it keeps giving me the not enough disk space error. I tried a few of the fixes but I can't seem to get it to work!!!
anywhere else I can get it from?
Old 12-12-07, 07:38 PM   #6
st1age's Avatar
try yankeetoys.org instead...
eschew obfuscation
1990 LJ78 - runs well now, after heart transplant
1985 BJ70 sold
st1age is offline   Reply With Quote
Old 12-18-07, 02:23 AM   #7
brownbear - I have the EPC and Japan database and I'm able to look up part numbers. However, I have not used this particular function
Originally Posted by brownbear View Post
...you can put your JDM vin number in it and find the exact part number. ....
How does one find out the JDM VIN number on an HDJ81?
Looking at the vehicle plate in the engine compartment, I can only find the following:
Model No: S-HDJ81V-RNPEX
Engine: 1HD-T 4163cc
Frame No: HDJ81-0005095
Color Code: 183
Trim: FC10
Trans/Axle: A442F K294
Plant Code: A11
How long is the JDM VIN Number
1990 HDJ81 VX Limited 4.2 TurboDiesel
(converted RHD to LHD) 124Kms - still going strong
And lovin' every minute of driving a legend
podiev is offline   Reply With Quote
Old 12-18-07, 11:55 AM   #8
I believe the JDM vin is 12 digits and in your case it would be what you have listed as your frame number
on a side note I did get the one from yankeetoy.org but can't get it to work or the one I got from a torrent =[ I will keep tryin!
Old 12-18-07, 01:53 PM   #9
lostmarbles's Avatar
I believe the JDM vin is 12 digits and in your case it would be what you have listed as your frame number .......Frame No: HDJ81-0005095 ............
I agree.
My experience is that "VIN" and "Frame No." are two different terms for the same thing. As long as the frame number includes the "simplified model code" at the beginning - like "BJ42" (or "HDJ81" in this case).
Name's really Tom & I have a 1979 BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A trunk is really a boot...........
lostmarbles is offline   Reply With Quote
Loans | Mortgages | coupon-coupon.com | Vacation Spots | Property for sale in Spain
