Old 07-22-04, 03:44 PM   #1
snorkle?? what can't get wet in engine?
I have a 3b engine in a 77 fj40 and was wondering what cannot get wet in an engine while doing water crossings?
kiwiwonder is offline   Reply With Quote
Old 07-22-04, 06:29 PM   #2
The Dude's Avatar
TLCA# 8113
I have had my 3B and my 12H-T totally submerged. They both still ran.
Brad T
88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs...
78 BJ 40/42/60
The Dude is offline   Reply With Quote
Old 07-22-04, 06:39 PM   #3
so there is no problem with the alternator or anything else electrical in the front, will water not short the battery out?
Old 07-22-04, 06:45 PM   #4
The Dude's Avatar
TLCA# 8113
Actually, On my 12H-T the "charge" light did come on briefly. I believe it was due to the belt slipping. On my 3B I disconnected my batteries first.....
Interesting. I wonder what the proper procedure (well the best anyways) is?
Brad T
78 BJ 40/42/60
Old 07-22-04, 08:29 PM   #5
DieselROCKS's Avatar
Doesn't disconnecting the battery while its running burn out the regulator on the overly expensive alternator??
Geoff
81 BJ60 300k kms hibernating for the winter
DieselROCKS is offline   Reply With Quote
Old 07-23-04, 12:40 AM   #6
s79bj40's Avatar
dont disconnect the battery, it should be fine in water, but if you are going deeper than headlights and baffling the radiator isn't enough, you should just remove the fan belt. It stops the fan pulling into the radiator. The field in the alternator should be allright, even covered in water. Other than that, those engines will run fully submerged.
'83Hj47 4.0Id ToyHino
'79Bj40 3.0Id ToyHatsu
'02STGU 4.2Id-T Patrol
s79bj40 is offline   Reply With Quote
Old 07-23-04, 12:49 AM   #7
Greg_B's Avatar
TLCA# 7091
Try this link...
The amazing underwater car...
http://www.geocities.com/Athens/Atla...car/index.html
gb
Old 07-29-04, 03:24 PM   #8
I don't wheel
hj60's Avatar
TLCA# 11004
A good diesel engine will run through some very harsh conditions.
We had an air-cooled I-6 diesel at school that ran in 110°F ambient air for hours at a time,
no load, from idle to governor and back, frequent stops and restarts and no oil changes.
Never skipped a beat. Hardly any smoke at startup, except 1st thing in the a.m.
Only real caveats for submerging a diesel are watch your EGTs prior to dunking. The rapid
drop in temperature could warp or even crack the manifold. I hose down alternators while
running at work all the time, with no ill effects. As long as they have sealed bearings and no
pre-existing damage, water will not harm them. The belt will slip and squeal and glaze
slightly. Carry a small brass brush and at the end of the day, run it along the contact surface
of your belts and it'll de-glaze them without harming them. Make sure it's a fine bristle,
though.
If you have a leak-free fuel system, no worries. If you have a leak in the pressure side,
you'll just contaminate the water a bit. If you have a leak in the suction side, you're going
to risk injector nozzle damage. So make sure your fuel lines are good.
That's about it.
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001 and member of the Happy Hour Gang.
'94 80 Commuter Wagon.
My other ride's your mom.
hj60 is offline   Reply With Quote
Old 03-23-07, 08:37 PM   #9
ScottsHZJ80's Avatar
The main reason for running a snorkel is to stop the thing ingesting water.
The compression in most diesels being relatively high, they will be quite happy trying to compress water. When the water won't compress, things start bending and breaking, like con rods for example.
Getting water in a diesel is great way to ensure you WILL be rebuilding your motor!
A snorkel is a pretty cheap insurance policy.
'93 HZJ80 Std Wgn, 1HZ, 5 speed manual.
ScottsHZJ80 is offline   Reply With Quote
Old 03-23-07, 09:46 PM   #10
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
I thought, forgive me if I am wrong......
You idle for a bit on low idle, and let everything cool off, which it will do at idle.
Then keep a pressure wave going in front of you as best you can...
-91 FJ80, wife's ride
Old 03-24-07, 02:46 AM   #11
Garry's Avatar
I've had my rig in some pretty deep water, lapping around the bottom of the front windscreen. (you just have to make sure the windows are wound up or you'll get wet ) The alternator usually stops charging for a moment, but comes right after it dries out
1984 HJ60 Big Red Wagon!
Garry is offline   Reply With Quote
Old 03-25-07, 05:16 PM   #12
TLCA# 14443
Originally Posted by Greg_B View Post
Try this link...
gb
no way.... that's AWESOME!!
can't do that in a gasser....
-db-
Heaven goes by favor. If it went by merit, you would stay out and your dog would go in.
- Mark Twain -
'87 FJ60: http://web.mac.com/p2larowe/iWeb/The...e/Arrival.html
dogboy2 is offline   Reply With Quote
Old 03-25-07, 07:25 PM   #13
BlueHZT60's Avatar
TLCA# Yep
What can't get wet - the intake. I've had everything else stuck under water - no problems. There was another thread: wet intake = BIG$$$$. You can get around a snorkle 90% of the time by waterproofing the intake and tucking it up high toward the firewall. In No. America - short of ANY TRIP WITH WHATLEY or WAYNE, you really don't need a snorkle. Any trip with them = mandatory
Bob
BlueHZT60 is offline   Reply With Quote
Old 03-25-07, 07:46 PM   #14
matt 105's Avatar
Ha
A thread brought back from the dead - 2004!!!!
Has someone else got too much time on there hands?
lol
Matt
a white Landcruiser - now with Track Tactical!
matt 105 is offline   Reply With Quote
Old 03-25-07, 08:08 PM   #15
Originally Posted by matt 105 View Post
Ha
lol
Matt
Whoops. Guess that was me. I must have stumbled across this while looking for something else and replied without taking any notice of the date.
Another lesson learned by the noob
Old 03-25-07, 10:08 PM   #16
bigbrowndog's Avatar
One of the Kiwi Boys posted this a fair while ago. cheers
bigbrowndog is offline   Reply With Quote
Acs Student Loans | Credit Counseling | Loans | Apply for Credit Card | Remortgages
